T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 02-08-2010, 12:48 PM
  #3541
Could my problem be because i run foam spec? or is it because i run with max.steering travel so it lock's the servo saver so it don't work properly? i have been trough 8-10 steering bell cranks
Team_Elli is offline
Old 02-08-2010, 01:23 PM
  #3542
chris moore's Avatar
Trader Rating: 96 (99%+)
Hey guys, I'm looking for a few ARP parts; so if anyone has some leftover parts take a look here http://www.rctech.net/forum/r-c-item...arp-parts.html
chris moore is offline
Old 02-08-2010, 01:26 PM
  #3543
Sal Amato's Avatar
Trader Rating: 27 (100%+)
I would think that might be your Problem I have only broken a bellcranck when my car went full speed down a 100 ft straight and slammed into the wall (lost steering) and The bellcranck was the least of my problems.. back off some steering throw and make sure the bellcrank arm isnt hitting the servo or anything for that matter...I am using a spool up front (lots of stress on front end parts) and have hit things and never broke a bellcrank that way, I am not using full steering lock .
Sal Amato is offline
Old 02-08-2010, 02:40 PM
  #3544
stiltskin's Avatar
Trader Rating: 103 (100%+)
Originally Posted by Sal Amato
Although the durabilty is really good on these parts check out what I just came across http://www.redrc.net/2010/02/t-o-p-p...bs/#more-27823
Those are pretty sexy. Any word on ETA.
stiltskin is offline
Old 02-08-2010, 02:45 PM
  #3545
Thank's will try less steering trow on the next practice session i go to
Old 02-08-2010, 03:20 PM
  #3546
tallyrc's Avatar
are people still throwing blades? namely the right rear? i figure it's my diff bolt so i shaved it a bunch..
tallyrc is offline
Old 02-08-2010, 03:30 PM
  #3547
Nova F1 Racer's Avatar
I resolved the blade issue by doing 2 things:
Getting the shorter drive shafts and using only 2 out of the 4 beveled washers.
Nova F1 Racer is offline
Old 02-08-2010, 04:23 PM
  #3548
Sal Amato's Avatar
Not sure spoke to Mike today and he said they ordered them but didn't get them yet....he said he is expecting foam kits soon and he was hoping the new aluminum parts would bein that shipment ..
Old 02-08-2010, 06:15 PM
  #3549
tallyrc's Avatar
my diff bolt was protruding well past my diff nut.. nearly an eigth of an inch.. using less beveled washers will only cause the nut to retreat.. i guess i could have used a thicker collar on the thrust side. funny even the cad drawing shows the tip of the bolt protruding.. the end of mine was shinny where it had been rubbing.. i see the blades are "out of stock". i must not be alone..
tallyrc is offline
Old 02-08-2010, 06:29 PM
  #3550
Suspended
RaceAce701's Avatar
Trader Rating: 87 (99%+)
hum very informative ill have 2 check that
i went throgh 4 of them last week ( one after every run)
RaceAce701 is offline
Old 02-08-2010, 06:37 PM
  #3551
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
If your still running the original 45mm dog bones and trying to run more then 1.5* of rear camber that's how there breaking. If you go to the 44.5mm pick up the CVD collars at the same time. They really help free up the dog bones.
Also guys see the attached picture of Schreff...
Attached Thumbnails T.O.P. Racing "Photon" 1/10 EP Touring Car-22071_466187280190_331464760190_11107168_2720373_n.jpg
Ron Goetter is offline
Old 02-08-2010, 06:59 PM
  #3552
stiltskin's Avatar
I bet he'll never wash that radio again.
Old 02-08-2010, 07:01 PM
  #3553
schreff's Avatar
HAHA! That wasn't even my radio. I think it was Sonny Brown's radio. I stole that off the Spektrum table cuz I didn't know where I put mine. I should have kept that one anyway. Sonny has more.
schreff is offline
Old 02-08-2010, 08:46 PM
  #3554
smilekt's Avatar
wahh so coolll ..
smilekt is offline
Old 02-09-2010, 04:44 AM
  #3555
Looks great Shreff
grouchy is offline
