T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 11-11-2009, 05:16 PM
  #2746
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
My Carpet rubber car is a box stock foam car with a spool and the outer part of the wings disconnected. When I ran the rubber chassis it had too much flex and would actually try to traction roll.
Originally Posted by AndysD8
All we run around here is indoor carpet, rubber tires. I had just heard and not sure if there is any truth to it, that out of the box the rubber spec is great on asphalt but not so much on carpet. For those running the rubber spec on carpet, what wing and top deck are you using? I'm just curious how a out of the box foam edition, with a spool does with rubber on carpet. If I'm getting on anyones nerves with all the questions, I apologize! Just want to make the right choice with my first "new" car!
Ron Goetter is offline
Old 11-11-2009, 05:17 PM
  #2747
L.Fairtrace's Avatar
Trader Rating: 24 (100%+)
Originally Posted by stiltskin
Car was good today but I've still got work to do. I think the chassis flexes too much on the carpet and causes a very aggressive feel. I didn't get to play with shock fluids today, but I will by this weekend. Car did come around pretty good throughout the day, I just need to calm it down a little. Overall good day with the car.
Try the setup I posted with Long camber links 393 front springs and a 1.4 mm front swaybar.
L.Fairtrace is offline
Old 11-11-2009, 05:18 PM
  #2748
Trader Rating: 40 (100%+)
Originally Posted by Gitsum
You could go either direction really. If you plan on just doing rubber indoors and out get the rubber kit. If you might do some foam and rubber get the foam kit. Keep in mind if you use the foam kit in rubber it is stiff which in turn can make the car edgy. Either way you can't go wrong as there are very good setups for both already to be had.
that's what scares me, the foam chassis stiffness! I know I had a t2 with a bmi chassis and it was just to stiff to be competitive with rubber tires. At least for me it was as I'm still new to onroad and there's so much more to setup then offroad nitro!
AndysD8 is offline
Old 11-11-2009, 05:20 PM
  #2749
Ask away this is what this thread is for. Me personally I run the thin 2.0 lipo chassis with stiff top deck and medium wings on my rubber car. I never built mine with the stock chassis so I can't comment on the handling difference. I feel my car is good and carries a ton of speed but I am in no way box stock. MRrcguy would be the one to ask I believe he has run just about every configuration under the sun from box stock to hoped up. Larry and Jason will probably chime in as well.
Gitsum is offline
Old 11-11-2009, 06:41 PM
  #2750
Thanks! Hopefully in the near future I can buy all I need to get the car where it will need to be, but with Christmas coming up it's hard enough to pull off getting the car. So, any advice on which of the 2 photons would be better out of the box for rubber on carpet except for getting a spool should I get the foam edition would be much appreciated! From what it sounds like either would be great but people have got to have a preference!
AndysD8 is offline
Old 11-11-2009, 07:13 PM
  #2751
stiltskin's Avatar
Trader Rating: 103 (100%+)
Thanks Larry. I did try your rubber tire setup (minus the 2.5 chassis) and the rear would not stay in. We're still racing asphalt, so I'm just trying to find a carpet setup in my free time. I'll be getting the 2.5 lipo chassis as soon as they get them back in stock and I think that should take care of the car's nervousness. Props to you and Jason on your runs at the Gate. The cars both looked real good.
stiltskin is offline
Old 11-11-2009, 08:08 PM
  #2752
Any idea as to why when I try to view some of the setup sheets listed on here all that comes up is a photon modifiable sheet?
AndysD8 is offline
Old 11-11-2009, 08:33 PM
  #2753
Honestly the cars are going so fast now Micheal at TOP is having a hay day keeping up. Cars are going out as soon as they come in. I personally would get a foam car and a spool. My car probably has more flex and bite then anyone on here which is awesome on a green track. When bite comes up I lose a bit of ground because of the flex but is still workable.
As for the setup sheets they all seem to pull up fine for me but i open and save them thru Windows IE.
Gitsum is offline
Old 11-11-2009, 09:09 PM
  #2754
Mini-Mod's Avatar
So... This is the T.O.P forum. I got to say the car is awsome. The car gets better every time I race. I like to see people driving the car.
Mini-Mod is offline
Old 11-11-2009, 09:53 PM
  #2755
Other then the spool, what other changes did you find necessary on the foam car?
AndysD8 is offline
Old 11-11-2009, 09:56 PM
  #2756
haywood's Avatar
Trader Rating: 49 (100%+)
Default Foam Photon
Can anyone post a set-up running foam tires with the foam kit.Thanks
haywood is offline
  #2757
The car I ran at the Classic is basically a foam car with a 2.5 mm lipo chassis and a spool with the posts not on the wings.
Schreff's was similar but he had the stock foam chassis on his car also so it was about as close to a stock foam car as you could get with a spool.
Haywood you should give the foam setup I posted a couple pages back a try.
Old 11-12-2009, 06:40 AM
  #2758
Only thing I changed on mine from the box stock car was I used the medium wings on mine and a spool otherwise my foam kit bone stock.
Again regardless of what car you go with def look for Larrys setups. I have tried them all and his are some of the best for 13.5 and 10.5. If you plan to run 17.5 give Quinton' (MrRCGuy) setup a look and try.
Gitsum is offline
Old 11-12-2009, 12:09 PM
  #2759
brunelli ale's Avatar
Since his debut in Italy in July, I won with the photon both national titles in the category 10.5 rubber
in the coming days I will insert the sheets of setup used and all supporting info that might be useful
the car is a rocket
Forgive my English
brunelli ale is offline
Old 11-12-2009, 12:36 PM
  #2760
CraigM's Avatar
Trader Rating: 34 (100%+)
Nice work! Look forward to seeing your setup. Hopefully the TOP oz team will have a good showing at our nats next weekend
If anyone is looking for setups I've got pretty much every setup ever posted here on my site www.tchub.info
CraigM is offline
