T.O.P. Racing "Photon" 1/10 EP Touring Car >
Like Tree9Likes
Old 08-25-2009, 10:19 AM
  #2026
Jordan-Howe's Avatar
I ran the new TIR spool and driveshafts last weekend at the BRCA National and I found them very good quality and made the car very smooth.
I am loving this car at the moment I have only had the car for a month or two but am having some of my best results finishing 3rd at the BRCA Juniors and 8th at the lastest BRCA National.
So top job to all the guys
Jordan-Howe is offline
Old 08-25-2009, 08:35 PM
  #2027
Team STPN's Avatar
Originally Posted by STLNLST
I'm purple and I can do what I want. You ever gonna run that red thing any time soon???
I have ran it 4-5 times already...you just haven't been at Speedworld.....
Team STPN is offline
Old 08-25-2009, 10:06 PM
  #2028
Goingfast's Avatar
Trader Rating: 29 (100%+)
Hi
I did the same ting..but i uesd the TFK05 rear Diff ..two diff half together with no diff ring...works great...
Goingfast is offline
Old 08-26-2009, 05:22 AM
  #2029
STLNLST's Avatar
Trader Rating: 32 (100%+)
I'll be there Sunday so make sure you practice pulling over
STLNLST is offline
Old 08-26-2009, 02:14 PM
  #2030
RC MARKET's Avatar
Do you have test new Medium upper deck ?
RC MARKET is offline
Old 08-26-2009, 05:44 PM
  #2031
STLNLST's Avatar
The only thing I will be testing is settings for the Tekin RS and the new 200 software. Are you talking about the Photon top deck????
STLNLST is offline
Old 08-27-2009, 12:47 AM
  #2032
xray racer's Avatar
Trader Rating: 22 (100%+)
Originally Posted by xray racer
Hey guys,
Has anyone played around with Chassis flex much?... Josh you might be able to shed some light on this.
I've run the medium rubber wings so far, and preferred them over standard, but i'm curious as to what people have found in running the wings as opposed to the medium upper deck etc.
Is it better, or more noticeable running a stiffer top deck compared to different wings?... or do you prefer one over the other etc?
I am running Rubber/Asphalt by the way
Cheers
Robbie
....Anyone?
xray racer is offline
Old 08-27-2009, 06:21 PM
  #2033
Team STPN's Avatar
He is always testing...
You may need to pull over when my 17.5 passes your 13.5
Old 08-27-2009, 07:16 PM
  #2034
STLNLST's Avatar
Not running anything orion anymore so that will never happen again.
STLNLST is offline
Old 08-27-2009, 07:17 PM
  #2035
kschu's Avatar
Trader Rating: 16 (100%+)
Just to inform ,that Team Roche hv launched a SPool for BD5 which fit TOP Photon as well....and Team Roche is working on the Red Anodize colour now....
pls visit here for the spool infos. KKEPRC
p/s: i been using this spool on my bd5 for 35 packs lipo with 8 min each run...11.5t motor... no sign of wear at all...im driving on technical track which require me to brake alots.
kschu is offline
Old 08-28-2009, 09:21 AM
  #2036
pmc
Hello
What is the best chassis plat to run rubber tires with
lipo the 2.5 mm for 6-cell or the 2mm for lipo??
someone has tested both with lipo?
thanks in advance.
Best regards:
Pedro Silva
pmc is offline
Old 08-28-2009, 08:03 PM
  #2037
tallyrc's Avatar
pretty sure i have the original spools, can i get a detailed description of "the fix" till i can get some updated units?
tallyrc is offline
Old 08-28-2009, 08:19 PM
  #2038
adamge's Avatar
tally, I think the best strategy right now is to hold it together with wood screws, drop CA into the screw holes to tighten up the hole, drop CA onto the screw threads to further threadlock and tighten up the hole, then CA the outdrives into the spool. At least, that's where I'm at right now so I can continue driving.
adamge is offline
Old 08-29-2009, 02:58 AM
  #2039
amnesia's Avatar
Anyone else having problems with the set screws coming out of the top of the rear hubs ? I am finding that the plastic that the hubs are made from is quite soft... going to have to glue them in I think.
This chassis is awesome - I wrung out another 2 laps on our track last night. I am so much more consistent and accurate with the Photon over my old TRF415. It has held up to some pretty big 'offs' too.
Nice one T.O.P.
amnesia is offline
Old 08-29-2009, 05:56 AM
  #2040
Luke Hobson's Avatar
I've not had any issues with the rear hubs stripping.
Maybe put a longer set screw in if you have any or just screw it further in and put a dab of thread lock on the top of the screw where the link goes on. If you decide to screw it further in.
hth
Luke
Luke Hobson is offline
