Old 03-23-2009, 01:50 PM   #46
Soldering is PITA, I hate it.
chris.v is offline   Reply With Quote
Old 03-24-2009, 05:14 AM   #47
Tucker101's Avatar
Send a message via MSN to Tucker101
Originally Posted by ta_man View Post
I said before and I'll say it again: It all depends on what you consider an acceptable solder joint. My opinion is that the way to get an acceptable solder joint every time (by my standards: look at the pics I posted) is to use [separate] flux each and every time you heat up a joint to solder it.
If the iron is pulling the solder away from the joint that is because the solder was not flowing onto the materials to be joined because of the presence of oxides. Flux removes the oxides. Flux in the solder won't do as good a job as flux applied separately beforehand.
What sort of flux? I heard there are different types, is acidic okay on electronics?
Tucker101 is offline   Reply With Quote
Old 03-24-2009, 05:27 AM   #48
Tucker101's Avatar
Sorry about the double reply.
Internet went spaz on me.
Old 03-24-2009, 08:50 AM   #49
ta_man's Avatar
Trader Rating: 151 (100%+)
You should not use acid flux on electronics.
I used to use "Nokorrode" brand flux when I started soldering (40+ years ago - on slot cars) but the formulation was changed sometime in the intervening years since I got into RC. The best stuff I have found that is readily available in the U.S. is Rubyfluid brand soldering paste. One place to get it in the U.S.: http://www.artsuppliesforartists.com...ring-paste.php
A tin lasts me about a year and I'm sure I do more soldering than most people. I am not sure what brands would be available in Australia.
ta_man is offline   Reply With Quote
Old 03-25-2009, 02:51 AM   #50
Tucker101's Avatar
Thanks for that ta man, i'll have to see what i can get over here in Australia.
2009 T.C.S. Three MSRA (Memphis, TN) 510 06-23-2009 03:14 PM
LiPO question zardoz Electric Off-Road 98 10-25-2007 03:42 PM
ROAR to 4 cell.... Advil Electric On-Road 1394 12-21-2006 10:50 PM
Soldering vs connectors! speedxl Electric On-Road 54 06-15-2005 02:13 PM
Soldering iron question trackdesigner71 Rookie Zone 10 02-26-2003 10:15 AM
