Old 03-08-2009, 07:47 PM   #1
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
Default Do I need a bigger power supply
do you think I can charge a 4 cell lipo at 6 amps and a 2 cell lipo at 5 amps off my Eagle Racing 14A/17A max power supply?
is it as simple as just adding up the amperag?
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 03-08-2009, 09:30 PM   #2
wingracer's Avatar
Trader Rating: 24 (100%+)
Should work. Yes it is as simple as adding up the amps plus a bit more for the power the chargers themselves draw. One problem could be that starting the second charger could cause the other to peak if the supply isn't up to snuff.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 03-08-2009, 10:13 PM   #3
Trader Rating: 16 (94%+)
Amperage Spike - if the chargers you are using are adjustable on the fly, start the charge rate at 2amps, then after started, bump up the amperage to desired. Since you're only looking at 11amps, and the power supply is 14amps nominal, I doubt you will have any problems.
kn7671 is offline   Reply With Quote
Old 03-09-2009, 02:47 AM   #4
sosidge's Avatar
Charging a 4-cell pack Lipo would mean that the charger must have a step-up transformer in it? So it is going to use more current than a charger that was just using the input voltage as it comes.
DAVAO CITY R/C CLUB bash n thrash Manila Racers 1215 02-10-2015 08:20 AM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 07:04 PM
ROAR to 4 cell.... Advil Electric On-Road 1394 12-21-2006 10:50 PM
Tamiya Asia Cup Qualifying Series 2006 CheeYong Malaysian R/C Racers 768 09-20-2006 01:29 AM
Brushless vs Brushed stock class racing Poweredbysbc Northwest Racers 212 09-13-2006 04:25 PM
Bigger Sale !!! BDR609 R/C Items: For Sale/Trade 36 01-27-2006 09:54 PM
