Anything else?
Old 08-28-2001, 08:48 PM
SpitFire3's Avatar
Anything else?
what else should i get (or remove) for my HPI Sport 2?
i have:
Reedy Pulse R
Novak Cyclone
MIP CVD's (FRONT)
HPI Purple Sway Bars (FRONT)
HPI Orange Sway Bars (REAR)
Futaba Magnum Junior (AM)
Yellow springs (Rear)
Blue Springs (Front)
64 Pitch Spur gear
32 teeth Pinion Gear
RRP Ball Diffs
Graphite Upper Deck
Belt Tensioner
Purple Side Plate Heat Sink
6 SMC 200 Battery Packs
Honda Civic Si
Honda NSX
Lex GS 400
SpitFire3 is offline
Old 08-28-2001, 10:03 PM
Tires are always a good thing and can help your car become faster. Also good servos make a HUGE difference!!! i did not believe it a first buy when i bought a new controller which came with a faster servo... my lap times improved on average 1.5 seconds on a 13-15 second lab!!! i now place either high B mains or low A mains (got a 3rd once on the A main!). Hope this helps.
Peter
petersiu007 is offline
Old 08-28-2001, 10:07 PM
If you're racing, definately get tires. Also a variety of shock oil and springs. A high speed servo always helps, and an FM radio wouldn't be a bad idea either.
JeffC is offline
Old 09-12-2001, 09:11 PM
SpitFire3's Avatar
thanks a lot
Old 09-13-2001, 02:57 PM
TFR
TFR's Avatar
do you have a picture of the car?
TFR is offline
Old 09-13-2001, 06:42 PM
fatdoggy's Avatar
Turnbuckles if you don't already have them. It makes changing setup much easier.
fatdoggy is offline
Old 09-13-2001, 06:57 PM
Trader Rating: 81 (100%+)
are your packs side by side? if youre using the stock battery holders, you might want to try converting to saddle packs. you can use strapping tape or get the hpi pro2 battery tray with velcro holders. if your packs are side by side, it is easy to convert them to saddle by just replacing the center battery bar with a jumper wire. however, your lower chassis will have less room for electronics with a saddle pack.
marvi is offline
