Old 07-06-2004, 06:44 AM   #91
Lonestar's Avatar
stuck: I doubt it'll run as good as specifically designed stockers, which manufacturers have spent dozens of hours on, to squeeze that extra hundredth of a watt out of them... unless you time the crap out of it, in which case not only it is illegal, but it's also unfair to your fellow stock racer friends. If you do your testing during a race, that is. In practice you can do whatever you want... experimenting is cool
don't feel cold: weird... on of the characteristics of the (non-twisted comm) V2 is that it runs way cooler than the other motors, which helps prevent magnetic field decrease at the i4-min moment... Maybe Surikarn was just performing some testing...
Later
Paul
When the flag drops, the BS stops.
The train stops at the train station. The bus stops at the bus station. In my office I have a workstation.
Lonestar is offline   Reply With Quote
Old 07-09-2004, 02:28 AM   #92
BerNardLee's Avatar
Originally posted by BerNardLee
I just have my first V2 modified 9x2 from Peak Racing.
Was participated in a race yesterday and found that the result was far behind expected.
Compare to my D5 10x2, I can feel that at least >20% more power than the V2???
The V2 tested with ratio 8.85 and 8.55, the 8.85 give better run time but still does not produce any good performance, no punch and no top end.
Tested with motor management, it shows max RPM at 44000, but I have 55000RPM when tested with the Jukka Steenari version 8x2.
Is anyone know the main different between these two V2 motors?
Good news.
I have a very good result after I trued the comm yesterday.
It hits 52800RPM now.
BerNardLee is offline   Reply With Quote
Old 07-10-2004, 04:47 PM   #93
OK, I got my new motor.... and have a question....
I am putting it in a TC3, I purchased at 9 double. Running with rubber tires.
Track has 40 foot sweeper entering a 90 foot stragiht exiting into a 40 foot sweeper, with a less then techincal infield other then a real real real slow "S" section.
Can someone help me out with a gear to start with?
Smalls is offline   Reply With Quote
Old 07-11-2004, 01:09 AM   #94
glide 1's Avatar
try 75t spur and 21t pinion or 72spur 20pin, should give you an fdr of around 8.8 - 9
glide 1 is offline   Reply With Quote
Old 07-11-2004, 11:56 AM   #95
John_S's Avatar
hi guys im havin quite a lot of trouble with my hara spec 12x1 hs . One thing i noticed is that the green light on the endbell doesnt come on anymore whats this one do again? as i have lost my instructions iv tried skimming it and rebrushing it and no difference. The problems that i am having is that it is real slow and im getting radio glitches with it in
John_S is offline   Reply With Quote
Old 07-11-2004, 07:36 PM   #96
I believe that the if the led is on its telling you that your capicitors for reducing glitching are working...so if the light is off that's why you're experiencing some glitches. So i guess just check all the solders on those caps and see if they are all ok...pretty much just try to get that led back on...as far as it being slow you got me there...sorry
Jayboy is offline   Reply With Quote
Old 07-11-2004, 07:48 PM   #97
Ran my V2 today for the first time geared 24/100 with cs27's, man this thing was a freakin rocket, we even turned the timeing down a tad. I can't beleve how effiecnt these motors are, I had 68 seconds left in my packs ( twice ) today... but I am not sure if the increased HP is heling cause this problem....
Please read if you think you can help...lol
http://www.rctech.net/forum/showthread.php?s=&threadid=44862
Old 07-12-2004, 09:55 PM   #98
glide 1's Avatar
Hi all, I see someone mention a "bigbrush" version of the V2, anyone hear or know anything about this?
Old 07-13-2004, 03:44 AM   #99
take the endbell of and you see a circuit board.
this has got a connection using a metal strip that goes to the brushe tube.
if this isnt touching the tube then the caps wonts be working and causing the glitching.
if they are touching but the LED isnt coming on then the board may have blown.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Old 07-13-2004, 03:46 AM   #100
i havent heard of a big brush but in europe were we have 12 turn limit some of us cut the brushes down to make the littler.this gives more power but less overlap and increases effeciancy.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
Old 07-13-2004, 05:27 AM   #101
defMondo's Avatar
Do you have a picture of what they look like when you cut them down?
I guess t's more efficient due to less drag on the com because of the reduced surface area...
Tony
defMondo is offline   Reply With Quote
Old 07-13-2004, 11:47 AM   #102
i have no pics yet bt will try to get some taken.
theres less drag on the motor plus theres less overlap=more effciancy.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
Old 07-13-2004, 06:44 PM   #103
noline's Avatar
I just purchased an Orion V2 Touring 8 Double Modified what how many Degree timing shoud I use also with a 98 pur what pinion should I use. I race on a Med/sized track. Any help would be greatly appreciated.
noline is offline   Reply With Quote
Old 07-13-2004, 09:04 PM   #104
tornado
Guest
Posts: n/a
Try the final ratio of 9.1
Old 07-13-2004, 10:31 PM   #105
azenis's Avatar
Hi
Thinking about buying one of these motors for my Pro4, wondering which version to get.
Our tracks change every two meets but are mostly pretty tight, usually with one straight about 20-25 meters or so (sorry never measured it)
What would be the best version to get?
Is there a website that will give me the specs of each version?
Nige
X-Ray T4 '14 | 3Racing Sakura D3 CS | Durango DEX410v4 | HPI Blitz | Tamiya WR-02 VW Bus
azenis is offline   Reply With Quote
Orion 3200 Lipos. Orion Charger, Orion balancer *new price* Mike Marshall R/C Items: For Sale/Trade 4 08-07-2008 09:26 AM
FS: Orion Advantage Charger w/2 Orion Carbon Edition 3200 Packs smarking1212 R/C Items: For Sale/Trade 4 05-26-2008 02:44 AM
Orion Advantage Charger with 2 lipos orion/peak Rock Racing R/C Items: For Sale/Trade 1 04-21-2008 05:31 PM
Orion advantage carbon edition charger + Orion 3200 spec LiPo $150.00 vintagetamiya R/C Items: For Sale/Trade 9 04-09-2008 05:05 PM
New Orion 1100 micro battert and Orion Mod Elite for Sale Nightbreed R/C Items: For Sale/Trade 0 01-29-2003 02:11 PM
