Orion V2
Old 07-01-2004, 01:56 PM
  #46
speedxl's Avatar
Trf not here in the states!
speedxl is offline
Old 07-01-2004, 02:00 PM
  #47
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Joe, do you have any pics of what you guys were doing to the brushes at the Reedy Race? I know you mentioned something about narrowing them. I'm interested in trying this but just want to know where exactly you were shaving them.
Jon Kerr is offline
Old 07-01-2004, 03:40 PM
  #48
Joe Pillars's Avatar
I dont have any pics at the moment. Just narrow the bottom quarter of the brush .30mm
Joe Pillars is offline
Old 07-01-2004, 07:41 PM
  #49
Rob Mincey's Avatar
Joe - any word on a 19T model?
(or, is there already a 19T and I'm just too braindead to have found it?)
Rob
Rob Mincey is offline
Old 07-01-2004, 07:51 PM
  #50
dontfeelcold's Avatar
Trader Rating: 22 (100%+)
from what i hear the v2 motors run hotter than the standard endbell. what part of the motor actually runs hotter and why. Is this a disadvantage seeing as heat is the enemy of all things electric.
dontfeelcold is offline
Old 07-01-2004, 08:03 PM
  #51
tornado
Guest
Posts: n/a
I think it would be the endbell.......friction between the comm and the brushes....
Actually the V2 endbells runs cooler as becos' of the angle of the brushes contacts the comm, there is less brush bounce hence lighter springs and lesser friction and heat.
Old 07-01-2004, 08:08 PM
  #52
Mike Haynes's Avatar
It dosnt run any hotter then the core when geared properly, they dont like to push as much as the cores.
They all seam hotter because all the heat gets sucked into the endbell faster on the v2...its all metal.
Mike Haynes is offline
Old 07-01-2004, 08:11 PM
  #53
tornado
Guest
Posts: n/a
Oh yeah...and that too.
Old 07-01-2004, 08:18 PM
  #54
glide 1's Avatar
compared to a D5's, V2 actually runs cooler, both had same no. of turns, timing, gearing etc. not as much rip as the D5 but a lot smoother power band.
glide 1 is offline
Old 07-01-2004, 09:12 PM
  #55
wrxmy99's Avatar
Hi had my Surikarn 8 x 1 geared at 8.6 on my XRay FK.
Track is large (3 netball courts side by side) with a combination of sweeper and large straight then a semi tech infield.
Kept dumping at 4.5 minutes in 3 out of 3 of the mains.
Dropping to 9.1 in the last main didn't help. Neither did dropping timing back to 6 degrees.
Comm needed a cut albeit a light one but the sprint brushes were purpled and chipped on the edges.
Any tips...was i grossly out of gearing...is the 8 that much more agro then the 9 and 10 mentioned earlier?
HELP!
Cheers
A
wrxmy99 is offline
Old 07-01-2004, 10:29 PM
  #56
Jon Kerr's Avatar
Dumping could be a number of other things. How old are your cells? Have you checked them? You could have a bad cell or something. What rate are you charging at? Driving could have a lot to do too. Every time you hit a dot and lift the tires, especially running a low wind motor, you're going to loose about 10 sec off your run time. Just a few other things to consider.
Jon Kerr is offline
Old 07-01-2004, 10:31 PM
  #57
no way you loose that much, or those of us who cant drive could never make runtime. lol
Kave is offline
Old 07-01-2004, 10:37 PM
  #58
Jon Kerr's Avatar
But are you running 7 and 8 turn motors? When you lift the tires on a car that's going around the track as fast as these cars do, you suddenly unload them and you'll get a big surge in the amp draw from the motor. I'm just going by what I've been told by people who have done about every test on a battery you could think of and know a lot more about them than I every will.
Jon Kerr is offline
Old 07-01-2004, 11:26 PM
  #59
Lonestar's Avatar
Trader Rating: 14 (100%+)
very happy with my V2 Touring 12x2 HS...
Joe, you said narrow the bottom of the brush by 0.3mm... do you really mean 2 tenths of a millimiter? that's close to a hundredth of an inch... do you confirm? sounds too small to me.
Is it worth doing on 12 turns on tight tracks? I'm running sprint brushes btw and they do make a BIG difference...
Thanks,
Later,
Paul
Lonestar is offline
Old 07-02-2004, 12:34 AM
  #60
HELP!
Cheers
A
It may just be the way you use your throttle. I see a lot of mod drivers mash the throttle out of corners and wheelspin for the next 2 meters. try taking it easy especially in the infield where extra power just makes you slower into the turns.
Is this track eastern creek?
Dragonfire is offline
