Old 06-30-2004, 09:58 PM   #31
jedi's Avatar
Default Surikarn Vantage
I have an 11x2 geared at 8-8.2 on a flowing track with a 50 meter straight and at 8.3-8.5 on a 35 meter straight. This is with the stock 18 degree timimng . Gear up a tooth if you go to 12 degrees timing. Great motor. Should be good for about 10 runs with the installed sprint brushes. When you change brushes, use the enduro ones. Cut the com after 20-25 runs. Change the brushes after 2 or three cuts.
jedi is offline   Reply With Quote
Old 06-30-2004, 10:45 PM   #32
tsolokoy's Avatar
Post Soldering V2 Motors
hi guyz,
Just asking about soldering the motor wires, were exactly do you solder it. I been having these problems during every heat of the race, it keeps on getting loose especially when the motor is kinda hot but i have the right gearing of my car...of course the motor will surely gets hot...but not loosing on the soldered wires. To be exact the soldering lead on the motor can't resist the heat.
tnx
Rodjard
tsolokoy is offline   Reply With Quote
Old 06-30-2004, 10:50 PM   #33
Send a message via AIM to ZER01
It looks like anywhere on the round copper brush hoods as the rest of the endbell has a nonconductive plating on it to prevent your motor from shorting out.
ZER01 is offline   Reply With Quote
Old 06-30-2004, 11:20 PM   #34
tsolokoy's Avatar
Post
Webspinner,
yeah i know its on the copper brushhoods, exactly where? is it on the slotted area? can u show some pics? tnx
Old 07-01-2004, 08:17 AM   #35
Joe Pillars's Avatar
I am really glad to hear that everyone likes the motors. One thing I noticed on an earlier post that had something like when do you know when to cut the motor? I have found that when the motor needs to be cut, it will loose a little punch, but still have about the same RPM.
Kyosho America, Team Orion, Peak Racing, AKA, KO Propo, DiBrino Designs, JTP, RCE, Rockstar Energy Drink, www.thebigrc.com, Portland R/C Raceway (www.prcr1.blogspot.com)
Joe Pillars is offline   Reply With Quote
Old 07-01-2004, 08:40 AM   #36
Send a message via Yahoo to Doug Gaut
Rob, you will love this motor! I finally bought a couple. Last weekend was the first time out with the 10x1 and WOW. I am sold!! Cant wait till the endbells become available individually.
Doug Gaut is offline   Reply With Quote
Old 07-01-2004, 09:04 AM   #37
Thad Garner's Avatar
Hope this helps
R1Wurks - Awesomatix USA
Thad Garner is offline   Reply With Quote
Old 07-01-2004, 09:06 AM   #38
one more..
Old 07-01-2004, 09:09 AM   #39
top view
Old 07-01-2004, 09:46 AM   #40
Someone told me I should use more timing(18degree+)with smaller pinion rather than less timing(12degree) and biger pinion in small indoor track,is it correct? I saw Thad Garner use 18degree on his motor in Cleveland race. Can you comment, thanks.
caveman is offline   Reply With Quote
Old 07-01-2004, 09:59 AM   #41
At Cleveland we used very low timing, 6 degrees and geared up on the Revolution motors.
Old 07-01-2004, 10:36 AM   #42
In what situation more timing is needed? Big outdoor track? I'm talking about modified motors, 8-12turns, thanks.
Old 07-01-2004, 10:46 AM   #43
Using more timing changes the powerband of the motor. It can also be used to get more top end.
Old 07-01-2004, 11:56 AM   #44
tsolokoy's Avatar
Post
Originally posted by Thad Garner
Hope this helps
Thad Garner,
Thanks a lot for the pics bro, i have the same way on how u soldered the wires on the motor. But can u think of a cause of why my soldered wires still get loose.( i have a correct gearing on my motor). tnx.
Old 07-01-2004, 02:34 PM   #45
Originally posted by Eirik
Hello Josh,
I will try and explain the differences the best I can!
The Peak Vantage Modified is tuned for Off-Road, the armature and wire size gives you a smooooth power curve!
It is Timed at 18deg and comes with Enduro Brushes.
The Peak Vantage Touring is tuned for Touring Cars, it has a slightly diffrent armature that has a "wilder" power curve that is best suited for the high traction TC tracks.
It is timed at 18deg and comes with Enduro Brushes.
The Peak Surikarn Editions is also tuned for Touring Cars and I believe it comes with a armature that has more power than the std touring version, but with a litle less efficiency.
It is timed at 24deg and comes with Sprint Brushes.
I could be wrong about this information, it has not been confirmed by Peak or anything so I am not 100% sure!
Should not be far of though!
However, there is a difference, not just the stickers!!!
Which ever you choose, I guarantee you will love it, trust me!!!
All the best!
Eirik
the surikarn/atshui versions have twisted comm to produce more overlap0 creating more rpm at the expense of efficiancy.
Tamiya
Much More Racing
LRP electronic
Futaba
Speedtechrc
trf racer is offline   Reply With Quote
Orion 3200 Lipos. Orion Charger, Orion balancer *new price* Mike Marshall R/C Items: For Sale/Trade 4 08-07-2008 09:26 AM
FS: Orion Advantage Charger w/2 Orion Carbon Edition 3200 Packs smarking1212 R/C Items: For Sale/Trade 4 05-26-2008 02:44 AM
Orion Advantage Charger with 2 lipos orion/peak Rock Racing R/C Items: For Sale/Trade 1 04-21-2008 05:31 PM
Orion advantage carbon edition charger + Orion 3200 spec LiPo $150.00 vintagetamiya R/C Items: For Sale/Trade 9 04-09-2008 05:05 PM
New Orion 1100 micro battert and Orion Mod Elite for Sale Nightbreed R/C Items: For Sale/Trade 0 01-29-2003 02:11 PM
