Orion V2
Old 09-19-2005, 03:55 AM
  #316
dontfeelcold's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Rookie Solara
Yes, that is exactly what JOE (from Team Orion) told me before I purchased the Touring version for my Pro 4.......beside soldering the wires on the endbell is a pain, this motor is AWESOME.
the wires are easy to solder on, keeping them on in warm to hot weather is a different story all together, it happens way to easily.
dontfeelcold is offline
Old 09-19-2005, 07:37 AM
  #317
Spud_J's Avatar
Originally Posted by Team-RTR
hey people, when i go full throttle with my V2 motor the motor stutters really badly and then takes off. the comm has just been freshly cut and the motor is in perfect running condition. the ESC is a novak GTX.
Check that the red LED lights up inside when powered up - showing that the capacitors are connected. If not, take off the endbell and check the little copper connectios inside. This is more likely your problem
Spud_J is offline
Old 09-19-2005, 07:14 PM
  #318
Team-RTR's Avatar
the light was on. i found out the problem. i slightly overtightened the cap screws that holds the endbell on and a deformed the ring that the endbell screws onto. i straightened it out again and the motor is fine.
Team-RTR is offline
Old 10-31-2005, 12:48 PM
  #319
Trader Rating: 14 (100%+)
Hello,
I recently purchased one of these V2 hoods and I'm not sure how to rebuild it.
Could someone either take pictures of how to rebuild it or explain what steps I need to take?
Thank you,
Rudy
Deznuts05 is offline
Old 10-31-2005, 01:10 PM
  #320
Arun's Avatar
Originally Posted by Deznuts05
Hello,
Thank you,
Rudy
Hey Rudy,
Curtis from DC did a write-up on this. Click on the link below, then click "V2 Spring & Brush Replacement"
http://dcmotorsports.net/tips_tricks.html
Arun is offline
Old 10-31-2005, 02:05 PM
  #321
thank you very much
Old 08-09-2006, 03:22 PM
  #322
rampal's Avatar
hi, just get the marc reinhard 12x2 edition.... it is my first brushed mod (got 5.5r brushless) does anyone knows the web, springs and brush type it comes with? what would be the proper range for gearing (technical track), something between, 8.5 and 9? what would be a good start?
thanks a lot,
al
rampal is offline
Old 08-10-2006, 02:06 PM
  #323
rampal's Avatar
thanks a lot,
al
please, thanks!
al
rampal is offline
Old 08-10-2006, 03:02 PM
  #324
TLRacing
Todd Hodge's Avatar
thanks a lot,
al
4mm web, Enduro brush, and for springs I would say the Revolution MR032 4.3 N/mm (8 coil) (ORI41383).
For gearing it really depends on the track size. A 8.5 would be good for a tight technincal short track. For a larger track you may want a 8.0 or lower.
Todd Hodge is offline
Old 08-11-2006, 08:18 PM
  #325
nino_pohan's Avatar
I newbie want to buy V2 motor team orion, what the best edition of V2 team orion motor
nino_pohan is offline
Old 08-11-2006, 11:10 PM
  #326
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 100 (100%+)
Originally Posted by nino_pohan
I newbie want to buy V2 motor team orion, it was to many edition. what the best V2 marc ed. , hara ed. or ??? i play TC.
Umm? English and vocabulary sentence structure please?
BSchorr is offline
Old 08-11-2006, 11:11 PM
  #327
Switch Blade's Avatar
Im in quite a dilema. I took apart my vantage to give the comm a cut, and when I removed the endbell, one of the copper looking pieces being the tubes where the brushes are inserted fell out. I took the board off of the endbell and tried to slide the copper looking piece back in, but it broke. Is there any way i can get a new piece or do i need a new motor? Or maybe can I just buy an endbell adaption kit?
Switch Blade is offline
Old 08-12-2006, 03:13 AM
  #328
Yeah those bits are available seperately. I have also just soldered a link accross when i've been desparate at the track. However, you have to be very careful doing this as you can end up with too much there and it'll hit the comm tabs!
MattW is offline
Old 08-12-2006, 06:27 AM
  #329
nino_pohan's Avatar
What the best team orion V2 motor, Marc edition or Hara edition?
Old 08-12-2006, 02:23 PM
  #330
Guo Chean's Avatar
oscar jansen edition it come with the new alum endbell and new armature
Guo Chean is offline
