Orion V2
Old 10-26-2004, 01:48 AM
  #211
dontfeelcold's Avatar
Trader Rating: 22 (100%+)
What is special about the Surikarn and Spashett edition motors?
dontfeelcold is offline
Old 10-26-2004, 03:04 AM
  #212
Eirik's Avatar
dontfeelcold,
The differences are in the armatures, tuned for as much power as possible!!
The Surikarn armatures are very similar to the Hara version I think, but without the twisted communtator.
The Spashett motors have slots milled down in the armature. This gives a tremendous magnetic field increasing the RPM allot!!
They are wicked fast!!
Eirik is offline
Old 10-26-2004, 06:12 AM
  #213
Michal101's Avatar
Originally posted by pink pac man
i have the adaption kit on my peak hellfire and i found is reduces rpm/torqe and improves greatly on comm wear and heat dissipation
Pink,
So, basically it decreases performance???
I had a buddy who tried one and he showed me the dyno sheets before and after and it reduced the the overall power numbers by over 13%. I thought that he was not doing something correctly, but it sounds as though you have had similar results.
Anybody else?
Thanks, Mike
Michal101 is offline
Old 10-26-2004, 06:17 AM
  #214
berger's Avatar
Hmm, notice at the reedy the top four drivers all ran peak/orion 7 singles and the trinity and reedy guys ran 8's or 9's yet they still had the power to keep up. Easier on the batterys and wear so you can run a lower wind but slightly less power maybe?
berger is offline
Old 10-26-2004, 06:46 AM
  #215
Eirik's Avatar
Michal101,
If you dont run inn the brushes properly, the motor will not perform 100%
It is very important that the brushes are perfectly seated!!
Just run the motor at the track once and it will be all good for the next run!
berger,
Keep up?
The Orion/Peak drivers took the top 4 spots so I guess the others could not keep up that well....
Also, in Europe we only use 12t and the Reedy and Trinity motors etc. are not any faster at all, just allot more work IMO!
I have tested allot with the V2's and I have found them to be better than anything else I have tested. It is not just me either, all of my friends tells me the same thing!
Eirik is offline
Old 10-26-2004, 07:29 AM
  #216
vtl1180ny's Avatar
Ok... When are the 19 turns making it to the US???? Or where can I get them from online abroad???
vtl1180ny is offline
Old 10-26-2004, 07:56 AM
  #217
Is there some new stuff coming out for the V2's, bigger brushes? (thats one rumor I have been hearing lately)
Old 10-26-2004, 08:08 AM
  #218
Michal101's Avatar
Originally posted by Eirik
Michal101,
Eirik,
I appreciate your reply, but I have never seen a 13% decrease in a stock motors overall power due to the brushes not being totally broken in. And please keep in mind that the EPIC monster stock motor was brand new so I do not think that the stock EPIC brushes were broken in either.
Please do not take this post the wrong way...I already have two V2 mod motors and absolutely love them and would take them over other brands of mod motors. I am just trying to correlate the same performance and efficiency over to my stock motors.
Thanks, Mike
Old 10-26-2004, 08:40 AM
  #219
Eirik's Avatar
No problem Mike!!
I was a litle surprised about the result my self...
I just wanted to state that the V2's are a litle sensitive on the brushes when they are brand new....
What springs did you put on by way?
I think Joe Pillars said something about Medium/Hard worked the best for stock motors.
@dontfeelcold,
There is a new brush out, "Edge Brush" they are smaller, not bigger (the sides are cut)
I have heard they are really good, but I have not tried them yet.
Eirik is offline
Old 10-26-2004, 08:46 AM
  #220
raving-monkey's Avatar
i ran some of the new edge brushes abot 1 1/2 weeks ago and i didn't notice any difference..saying that i was having problems with my esc so i can't really comment on them...getting a new esc this weekend and i will be getting new brushes to so i'll tell ya if they are any good or not.
raving-monkey is offline
Old 10-26-2004, 08:52 AM
  #221
Michal101's Avatar
No problem Mike!!
Eirik,
I believe that he was using Med springs and sprint brushes. I am hoping to get the motor this week and do some testing my self with my Turbo dyno since I believe it gives more realistic numbers for us sedan racers.
I will let you know how it goes.
Mike
Old 10-26-2004, 10:51 AM
  #222
berger's Avatar
Michal101,
berger,
Keep up?
I still feel that some of the reedy motors have a slight edge over the orion equivalents, but at the weekend my 12x1 HS touring had too much torque and i had to swap out for a wimpy double wind.
berger is offline
Old 10-26-2004, 07:53 PM
  #223
Gary Guest's Avatar
Team Orion has done a lot of testing with the Edge brush and it does give an increase in power. I immediately noticed a significant increase in punch. Almost all of our drivers in europe have been using the edge brush in almost every application with great results.
Gary Guest is offline
Old 10-26-2004, 09:50 PM
  #224
Can't seem to find what brush/spring combo the Hara edition motor comes with. Can anyone help. Also I plan on running the Orion mod motor in Pro10 carpet class this year. The track we are running on will be 100X48. Any suggestions on what Orion mod I should run? I was thinking a Hara 8X1. I haven't tried one yet so I might be alittle out of my element here. Also what should I gear the car at?. Any thought would be appreciated. Thanks
og_capone is offline
Old 10-27-2004, 11:29 AM
  #225
rod_b's Avatar
Is the Peak/Spashett motor available yet? Anyone know where I can get one?
rod_b is offline
