Old 10-20-2004, 07:36 AM   #196
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
Turn the endbell 180 degrees, problem solved
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Savx - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 10-20-2004, 09:29 AM   #197
rc-zombies's Avatar
Default ADAPTATION KIT
anyone tried it yet? what combintation springs and brushes work well with the Monster stock and Chamelion 19T spec.
Old 10-20-2004, 03:54 PM   #198
Joe Pillars's Avatar
Start with the medium springs and use the sprint brushes for the best performance.
Kyosho America, Team Orion, Peak Racing, AKA, KO Propo, DiBrino Designs, JTP, RCE, Rockstar Energy Drink, www.thebigrc.com, Portland R/C Raceway (www.prcr1.blogspot.com)
Joe Pillars is offline   Reply With Quote
Old 10-20-2004, 05:27 PM   #199
Rob Mincey's Avatar
Originally posted by Pro4Capece
I can't get the 19turn V2 yet so i put a fantom 19x1 arm in the V2 can. It runs backwards when soldiered correctly. Can I reverse the timing on the endbell(turn it around) and still have the same performance as there should be? Will the capacitors short out? Anyone tried this yet?
thanks
chad
Is the arm from a Chameleon 2 based motor? We've discovered that some of the newer C2's have armatures that are "cross wrapped" and will spin backwards in certain cans. I'm guessing that the magnets in the cans have different polarities to account for the arm being wrapped differently.
Joe, or anyone else, for that matter, correct me if I'm wrong.
Rob
Rob Mincey is offline   Reply With Quote
Old 10-20-2004, 06:18 PM   #200
ChadCapece's Avatar
No, that's epic. It came from a Kisbey tuned Yokomo can.
ChadCapece is offline   Reply With Quote
Old 10-20-2004, 06:55 PM   #201
jackfast's Avatar
I am kind of noob with these motors. When I got it, it was hard to determine where I should solder the power wires from the speedo. I am a decent solderer but it was still extremely hard to near impossible to make this sucker work. I cleaned everything sanded down a spot on the brush tube and did my best, but today I was fooling around with the brushes and I noticed that it was soldered right on the brush wire...I give the motor wire a little tug and the brush wire snapped in half.....there must be an easier way to do this! Any tips on soldering with these motors. I don't need any basic soldering tips...but what I need to know is where and how did you solder your power wires on to this motor...thanks!
jackfast is offline   Reply With Quote
Old 10-21-2004, 12:44 PM   #202
jackfast's Avatar
bump!
Old 10-21-2004, 01:04 PM   #203
ChadCapece's Avatar
1. clean off existing solder
2. tin the side of the tube closest to the bearing
3. tin the opposite side of the same tube
4. put a small amount of solder on the brush wire
5. solder the brush wire to the side of the tube away from the bearing (solder it so that it's parallel to the brush)
6. solder the esc wires to the flat spot closest to the bearing.
As long as you have a clean iron, you shouldn't have to worry about solder wicking up the brush shunt or wire.
Old 10-21-2004, 01:19 PM   #204
Another couple of tips when soldering speedo wires to these V2 motors.
1. Remove the endbell from the can. With the end being aluminium the can wiil draw the heat through the end bell.
2. Use something like a 50 W soldering iron with a 4mm chissel bit so that the tip retains its heat.
Using these tips and Pro4Capece tips you should have no problem.
Steve B is offline   Reply With Quote
Old 10-21-2004, 11:54 PM   #205
jihernandez's Avatar
Guys, sorry to ask this question here but don'tknow anymore where to ask.
Would you know the difference between the KATANA 23T of Orion SL vs. TL? Please advice.
Thanks.
jihernandez is offline   Reply With Quote
Old 10-25-2004, 11:52 PM   #206
Michal101's Avatar
Default Re: ADAPTATION KIT
Originally posted by rc-zombies
anyone tried it yet? what combination springs and brushes work well with the Monster stock and Chameleon 19T spec.
So, as Zombies posted...
Has anybody had a chance to run the V2 endbell on a EPIC monster stock motor yet and if so what were the results?
Thanks, Mike
(Team Driver)
R/C America
Team Tekin
ProMatch
Parma
Michal101 is offline   Reply With Quote
Old 10-26-2004, 12:23 AM   #207
tornado
Guest
Posts: n/a
Thanks.
Both are running laydown brushes. The SL being the RPM version while the TL is the torque variant.
The other variants is the stand up brush type SS and TS. SS being the RPM and TS....yeap torque baby!!
Bryan
Old 10-26-2004, 02:17 AM   #208
Send a message via AIM to (V)r>??@uD@ Send a message via Yahoo to (V)r>??@uD@
Default D5 vs V2
hey guys
I want to know whats the differnce between both this motors they are both 10 doubles
1) the rpm and torque
2) the run time you get from both
3) the power differnce
4) the brush wear and how many runs you can get from both
becouse i hate cutting the comm on my D5 and i want a motor that is less maintenance
also do they have the same amount of punch
thanks
regards
(V)r>?[email protected][email protected]
(V)r>??@uD@ is offline   Reply With Quote
Old 10-26-2004, 02:40 AM   #209
pink pac man's Avatar
i have the adaption kit on my peak hellfire and i found is reduces rpm/torqe and improves greatly on comm wear and heat dissapation
pink pac man is offline   Reply With Quote
Old 10-26-2004, 02:45 AM   #210
Eirik's Avatar
(V)r>?[email protected][email protected],
The questions you are asking is not possible to answer, unless I buy a D5 and test it on my Dyno and compare the data with my V2's
However, the V2 are the best motors when it comes to maintenance!!
The new Spashett Editions from Peak is the most powerfull motor I have ever tried, efficiency is outstanding as well....!!
So if you are tired of your D5's, just buy a V2 and see for your self. You will not be disapointed, Trust me!!!!!
Eirik is offline   Reply With Quote
Orion 3200 Lipos. Orion Charger, Orion balancer *new price* Mike Marshall R/C Items: For Sale/Trade 4 08-07-2008 09:26 AM
FS: Orion Advantage Charger w/2 Orion Carbon Edition 3200 Packs smarking1212 R/C Items: For Sale/Trade 4 05-26-2008 02:44 AM
Orion Advantage Charger with 2 lipos orion/peak Rock Racing R/C Items: For Sale/Trade 1 04-21-2008 05:31 PM
Orion advantage carbon edition charger + Orion 3200 spec LiPo $150.00 vintagetamiya R/C Items: For Sale/Trade 9 04-09-2008 05:05 PM
New Orion 1100 micro battert and Orion Mod Elite for Sale Nightbreed R/C Items: For Sale/Trade 0 01-29-2003 02:11 PM
