Orion V2
Old 08-25-2004, 08:57 PM
  #136
azenis's Avatar
That is nuts!!
I am ordering one as soon as Tower get the Hara edition in stock again
azenis is offline
Old 08-25-2004, 09:22 PM
  #137
raving-monkey's Avatar
Originally posted by speedxl
this thread has dropped way down time to bring up to the top.
I have gotten 35 runs out of enduros with one cut on a 10x1 blue enbell motor! how is every body elses motors holding up.
on enduros....u get about 30 runs on my steenari motor (12x1)..it is amazing how much more life you get between cuts compared to a regular motor.
raving-monkey is offline
Old 08-25-2004, 10:19 PM
  #138
Tech Legend
Wild Cherry's Avatar
13d V2
off-road truck
first cut & replace bursh > 35 runs
Wild Cherry is offline
Old 08-26-2004, 12:38 AM
  #139
tornado
Guest
Posts: n/a
Originally posted by azenis
That is nuts!!
Please note that Hara edition comes with screw com and sprint brushes.......these brushes don't quite last like the enduros. Only the regular V2s come with enduro brushes.
Bryan
Old 08-26-2004, 12:41 AM
  #140
Lonestar's Avatar
Trader Rating: 14 (100%+)
I cut mine usually every 15 runs or so (2 outings)... One or two passes is all it takes
With the enduro brush, I ran about 30 runs on them before I switched to sprint brush and hard springs for more ooomph... I replaced my first set of spring brushes yesterday when the car started glitching.... I figured out they were too short and not making good contact... They had around 35 runs...
Seriously... this product is killer... I love it, it puts the fun back in electric.
One thing to check though: DO NOT overtighten the head screws, it binds the head and misaligns the bearings. The motor then overheats and brushes become toast. When you tighten the screws, stop when it becomes slightly harder to screw them on, ie when the screw heads touches the Alumiunium head. It will not move.
Later,
Paul
Lonestar is offline
Old 08-26-2004, 01:45 AM
  #141
tornado
Guest
Posts: n/a
Anybody tried Surikarn Edition by Peak ? Heard they have screw like come similar to Hara Edition.
Bryan
Old 08-26-2004, 05:05 AM
  #142
dontfeelcold's Avatar
Trader Rating: 22 (100%+)
Later,
Paul
what wind was that with?
dontfeelcold is offline
Old 08-26-2004, 05:07 AM
  #143
azenis's Avatar
what is a screw com?
Bryan
azenis is offline
Old 08-26-2004, 05:20 AM
  #144
Lonestar's Avatar
Sorry, it was obvious to me since we're in Europe... we all tend to get ethnocentric sometimes
It's actually a Corally Gold 12x2 arm in there. Comparable to an Orion HT.
Later,
Paul
Lonestar is offline
Old 08-26-2004, 05:23 AM
  #145
Lonestar's Avatar
I thinks he means "twisted". The comm segments are not straight.
Not that many people use the twisted comms... They're fast, but extremely inefficient. Better have killer runtime batts.
Paul
Lonestar is offline
Old 08-26-2004, 05:30 AM
  #146
azenis's Avatar
Oh OK wasnt aware of this feature on the Hara.
What are the other major differences? I thought it was only the webbing and brushes (and color)
azenis is offline
Old 08-26-2004, 08:00 AM
  #147
OK stupid situation...
I scratched a line on my V2 can to show me where my timing is. ( about 3 degrees). I take my motor apart, cut the com. And I must say about 10 runs, the com was slightly purple but one slight skim and it was gone. I put new brushes in it, put it back to gether put my timing mark back where it was. hook it up to my T-35 and the motor is running backwards. WTF?
Also, does anyone esles brushes show wear that looks like the hood is not alighend. I had about 1/8th of the brushes that was un used from miss alignment.
But getting back to it running backwards... I put the motor to gether exactly as I took it apart, and now it is running backwards. If I turn it around it will run in the correct way, but sounds whimpy and shows ok amp draw.
Smalls is offline
Old 08-26-2004, 08:09 AM
  #148
The only thing that will make a motor run backwards is either having the endbell on backwards or hooking up the positive and negative wires to the motor backwards. You also say "3 degrees of timing", do you mean the third line on the motor? If so that is actually about 18 degrees of timing.
Ozwald Bates is offline
Old 08-26-2004, 08:11 AM
  #149
A few posts up I believe you guys are refering to a "skewed" com.......Hey smalls, you must have flipped it 180deg by mistake...thats the only way I can see that It would be running backwards, aside from hooking up the power leads backwards......Flip it around (get it going in the right direction) and set your timing around 15 to 18 degrees......and see what happens............Joe
Joe B is offline
Old 08-26-2004, 08:12 AM
  #150
I guess I type too slow
Joe B is offline
