Cleaning Metal Shielded bearings >
Old 11-22-2003, 08:27 AM
Super Steve's Avatar
Exclamation Cleaning Metal Shielded bearings
Here is how i clean my beaings but i have a question on them (on pic 3)
First i take the shield out, being careful not to dent the sheild
Super Steve is offline
Old 11-22-2003, 08:28 AM
i put them on the bearing blaster
Old 11-22-2003, 08:29 AM
now, should i clean it out with this stuff?
Or go out and buy break cleaner fluid?
read the description, sounds all good
Old 11-22-2003, 08:32 AM
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
I'd use motor spray, and then some thin bearing oil...
Randy Caster is offline
Old 11-22-2003, 08:38 AM
popsracer's Avatar
Default Cleaning Metal Shielded bearings
Guys;
I recently started soaking in Paint Thinner to clean some very dirty bearings and it really worked great to get all of the dirt and grime. Afterwords, a quick blast with Motor spray in a Bearing Blaster and they were done.
Question:
Has anyone found a decent sonic/ultrasonic bearing cleaner that can can accept petroleum based solvents?
Thanks,
popsracer is offline
Old 11-22-2003, 09:30 AM
do those urtrasonic things actually work?
that multilube thing,
it won't hurt my bearings, would it?
i Should i go buy some brake cleaning fluid thing or use that?
Old 11-22-2003, 09:37 AM
Registered User
Calvin Ng's Avatar
I throw mine into acetone and shake em up
acetone is very good at desolving grease's
and u get all the dirt out easily
Calvin Ng is offline
asimo's Avatar
Didn't know those bearing blasters exsisted! Have to purchase one!
Btw - Nice photography work!
asimo is offline
Old 11-22-2003, 11:17 AM
Roger's Avatar
I think RPM makes a bearing blaster.
Roger is offline
Old 11-22-2003, 11:41 AM
Anothe question on top of this...
Which lubrication is the best to use?
Multi-lube
Fantom GoGo Juice bearing oil
Graphite Powder Lube
Old 11-22-2003, 12:04 PM
Someone told me that if you use Drano, it will dissolve any fibres and dirt on the bearing. Any truth to that?
RC Paperboy is offline
Old 11-22-2003, 12:15 PM
Dragonxmx's Avatar
Default Solvant
Goof-off in the metal container is the best for cleaning bearings.
http://www.goof-off.com/goofoff/PRODUCTS/goofoff.html
Dragonxmx is offline
Old 11-22-2003, 10:09 PM
Trader Rating: 14 (100%+)
Super Steve
Yes the ultrasonic cleaners work. we have thrm at work and I clean my bearings in them all the time.......I asked how much they were.....over $600. I guess I'll just use there's. Integy made a small one that was battery powered. it ok just a little to small for me.
bearing lube:
I use Royal Blue, also from work. I think Trinity sells something like it (or so they say). before that i used the Fantom stuff Prolong cut with mineral sprits works well too (the red stuff).
Popsracer:
I did the same thing until they got the cleaners at work. that worked out great. I used something called circ-clean instead of motor spray.
TimXLB is offline
Old 11-23-2003, 09:12 AM
cool,
Tim, I used the red stuff from fantom.
How big is the one at your work? 600 bucks is alot compared to integy's indi sparkle which is only 20 bucks.
I am still not convinced that they work.
Can anyone tell me how exacly these things work?
Old 11-23-2003, 09:19 AM
popsracer's Avatar
Originally posted by TimXLB
Popsracer:
If they sprout any little Feet, could you have one run over to my house?
