Charging with GFX
Charging with GFX
Just got my new GFX charger. In the menus I don't see any way to select # of cells. There are settings allready programed for 4 and 6 cell and 8 cel tx. Am I missing something?
It automatically detects how many cells its charging so there is no need to set anything and its not even an option.
rcpilot
Thanks!! I figured as much but every charger I've had before required it so I wanted to be sure.
Thanks again for the fast reply!!!
The only mode that requires the # of cells is the discharge mode. It needs it to calculate the cutoff voltage.
I dont know what gfx you guys are using , but you do need to select all your charge and discharge info unless you use the pre selected programs. In the profiles you can scroll down and change and save and load all the settings you select. cells , current,lockout, etc. you can then name and save these settings, but you do need to save and load them first. Read the instructions, its all in there. i have noticed the peak cut off needs to be at .05 for a truely peaked pack anything lower and the cells dont even get warm to the touch.
TX cells
I have the GP2000 Cells. What are ya'lls settings for those on the GFX?
I've tried 1A w/.3 cutoff, but I don't seem to get much life out of that. (I have an R1 radio, which is a juice sucker anyway).
Thanks for any help I get.
you have to go all the way to last page, (before the charge one) and change your machine profile according to how many cells you're charging, i believe theres 8 pre programmed profiles, 6 cell, 4 cell, tx pack, rx pack, 8 cells.. etc.
TX cells
I purchased mine used, so the standard settings are no longer there. But Thanks.
acyrier, .3 or .03 peak detect? 1A charge should be sufficient for AA's batteries, I charge my 1800 NiMH's between .4 and .6A's with a peak detect of .02V and have plenty of capacity. I use a KoPropo radio though.
TX cells
EEks, yes. .03. I'll try charging at a higher amp rate. and .02. Maybe I'll have better results. I did have the old sanyo 700mah AAnicad's. I wasn't getting any better life out of the 2000's, so I figure I'm not charging them correctly.
Re: TX cells
