Old 03-16-2009, 05:07 PM   #226
Originally Posted by Skiddins View Post
The track was around 20degC, slightly slippery in the morning but dried out nicely.
In these conditions it's best to use a softer tire in the rear that can deal with the cooler temperatures.
Sabin is offline   Reply With Quote
Old 03-17-2009, 07:52 AM   #227
NiMo's Avatar
Originally Posted by HarryN View Post
Hah! I know what I did wrong now. I went BACKWARDS on my setup. I should have gone purple front red rear!! I had too much steering. However, the only problem thereafter was the torque steering. My car would flip over. And this was with a -2 degree camber.
Now when you say 2 shims front and 1 shim rear... what do you mean? I have an idea, but I want to make sure.
Also I run trailing front axle
NiMo is offline   Reply With Quote
Old 03-17-2009, 09:33 AM   #228
HarryN's Avatar
Send a message via AIM to HarryN
That was what I thought you meant by 2 front and 1 rear. I am 2 rear 1 front right now.
Got a picture of your trailing front axles? I hate the axles that come with the kit. WAY too brittle. I spun out an axles while tightening the lock nut on it. I barely put my left nut into tightening these things and they spin out and not even tighten slightly.
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
Old 03-17-2009, 09:46 AM   #229
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Harry, try rollouts down to 55 mm. The car will really come to life for me with a 21.5 at around 56 mm. My rears are cut to 2.2. I run the Protoform Vette body and the car has no problems keeping up with the Mulsannes.
John
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is online now   Reply With Quote
Old 03-17-2009, 09:56 AM   #230
NiMo's Avatar
It is the axle in the kit
Can be set straight or trailing (offset)
Old 03-17-2009, 11:19 AM   #231
HarryN's Avatar
Ahh ok, you flipped it backwards then.
I was hoping for an upgrade. Something in steel or titanium. Aluminium is not working too well for me. And with a LiPo car, I need something a bit heavier than Aluminium.
Old 03-17-2009, 02:20 PM   #232
NiMo's Avatar
You race indoors or outdoors?
Old 03-17-2009, 03:38 PM   #233
HarryN's Avatar
Indoors.
Old 03-17-2009, 03:57 PM   #234
NiMo's Avatar
Indoors.
That could be why then, indoors with barriers.
I am outdoors with grass run offs, and a 155ft main straight.
Old 03-18-2009, 05:38 PM   #235
shanedc's Avatar
I just tried a Hpi Camaro.I like it alot.Better than the Firebird.The nose is lower,so there is a bit more downforce.I had to put stiffer front springs in the front.It has MORE stick through long sweepers.Good for long fast courses.
shanedc is offline   Reply With Quote
Old 03-18-2009, 05:51 PM   #236
sportpak's Avatar
Trader Rating: 26 (100%+)
I just got the Parma DB-9. Holy cow that thing is slammed!
-Tamiya TA05-R - Tamiya M05 - Summit Raceway Ft. Wayne, IN
www.summitrcraceway.com
sportpak is offline   Reply With Quote
Old 03-19-2009, 05:29 AM   #237
another 'realistic' zonda for you guys. I use this body when I race 27t stock class. It's fun looking at the faces of the people who race the blob/wedge bodies and wonder how I can keep up.
Old 03-19-2009, 07:19 AM   #238
JCarr's Avatar
I like that, it looks good. You guys are running rubber tire, or are those on there just for show?
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 03-19-2009, 07:34 AM   #239
HarryN's Avatar
I switched the green springs to the front and red to the rear. Now it grips, and it steers beautifully. The Sophia GT body works a little better, but the Protoform C6-R Corvette body still dominates. When I didn't coat the front tires with Jack the Stripper, the Sophia GT was pushing way too much into turns. The Corvette was SOLID!! I coated the front tires, the Sophia GT was a little better, but still was pushing. The Corvette was much better since I could push into turns harder.
I am trying to wonder why the doorstop design was chosen. If it was to provide more downforce, I only see it in the rear. The front grip is vague at best. But as far as I understood it, and reading John Stranahan's post, don't you WANT a higher nose to provide better downforce for the front? And if the nose is low, shouldn't you use a front lip? I am not liking the Sophia GT body still.
I may try the Parma Aston Chicky Doorstop-9 next. Hopefully that body will provide better results.
Score: Scale "Realism" 2. Doorstops .5 (because of great rear downforce and adjustable wing position).
Old 03-19-2009, 03:02 PM   #240
Between John's post on frontal down force and your testing, I'm sold too. Unless your running real high speed long straights the Sophia has no advantage. I'd rather have the steering any day.
World GT Club Racing - To spec or not to spec is the question???? Mr. McGoo Electric On-Road 722 11-01-2014 07:05 AM
Parma DB-9 WGT body chicky03 Electric On-Road 89 11-28-2012 05:36 AM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 02:43 PM
