Old 03-05-2009, 08:32 AM   #31
RC_Dan's Avatar
Send a message via MSN to RC_Dan Send a message via Yahoo to RC_Dan
Nice work Bob, very well thought out. I really like the minimalistic rear pod design, looks nice and light.
AE TC6 B4 & 18T, Kyosho Lazer ZX-5
CRC Gen XL & Battle Axe, Hot Bodies Ve8
460whp CRX on E85
RC_Dan is offline   Reply With Quote
Old 03-05-2009, 01:57 PM   #32
Bob-Stormer's Avatar
Originally Posted by jdeadman View Post
Bob, With the use of that large of pinions are you worried about any issues with rotational mass taking away accelleration?
Those things are so light it's amazing. I think the rear tires outweigh the pinion by a factor of 20:1, and that weight is 3 times further out. But to play Devils advocate, the pinion has to spin 2-5 times faster than the wheel. And when you think about the weight of the rotor, the pinions the small part of the equation. that said, I'm not in any hurry to ever run a steel pinion...
Originally Posted by automator View Post
Any plans for a solid t-bar, one without the cutout? Can this t-bar be used with the stock serpent pod? Can the stock serpent side to side damper still be used?
The reason it has the hole is so you can get to the Serpent tweak bridge screws through the bottom of the car. Also, I widened the hole to the point that the bar has a cross section more similar to a thinner T-bar. But it still centers up nice. It's a shade softer in all directions than the Serpent 2mm. I like the way it feels.
Can be used with the Stock Serpent pod.
BUT, you'd need to use our rear chassis brace so it clears the pivot socket. We rotated the rear pivot socket 90 degrees to put more meat on the back of the T-bar to make it stronger in the heat of battle.
If you pick up our t-bar conversion you can use all the stock parts.
https://www.ssl-stormerhobbies.com/c...s&pn=STO411002
Originally Posted by WIITA View Post
Question for the experts. With the rapid popularity of the single sell lipo and them being allowed in more and more races(Omaha last month). What do you think will happen with the saddle pack designed chassis. Do you think it is possibe to make a 3.7 saddle?
There is all kinds of rumor and speculation about what is going to happen for the 2009-2010 season. I think it's going to be interesting to say the least.
Originally Posted by HarryN View Post
Ohhh baby... *grabs some lotion*
How long did it take you to make all this? Are you milling the parts yourself?
...lol... The design has been in my mind for a while. Got it knocked out this winter. I'm trying to work with some industry people who's work I like, rather than scrounge any old shop with a low price. It's hard though, it adds to the price.
Originally Posted by Lightin' View Post
Sweet stuff you got there Bob.
I guess that leaves us to the dirty question of HOW MUCH?
I'd like to see a conversion in the $150-$180 range, But with the same quality work that shows on that pod in the pictures. Problem is that this is some SERIOUSLY low production, obscure, stuff. You don't get much of a break when you ask if they can make 12 of something... ...lol..
www.stormerhobbies.com "Where the world shops for radio control."
www.facebook.com/stormerhobbies
www.twitter.com/stormerhobbies
looking for....vintage 1/10-1/12 pan, need Schumacher 1/12th cars and parts.
Bob-Stormer is offline   Reply With Quote
Old 03-05-2009, 02:59 PM   #33
looks to me like bob's been buggin jari again.
shaggy1 is offline   Reply With Quote
Old 03-05-2009, 03:03 PM   #34
Scottrik's Avatar
Trader Rating: 245 (100%+)
Thought I'd post a picture of Bob and the Stormer Cobra on the podium after his 3rd place in 1/12 SuperStock at the Magic City Carpet Classic this past weekend. Not too bad at all for a car that had turned it's very first wheel on the track about 16 hours earlier!!
Yours Truly qualified 3rd (best of the rest class) but "pookied" my tires WAY too early and suffered the consequences. Teach me to not go look at the heat sheets a second time...
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 03-05-2009, 03:11 PM   #35
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Bob-Stormer View Post
Check these monsters. That's a 65 tooth pinion. Still doesn't hit up against the spur. Never used a 65 before... setting the mesh looks like a good time... ...lol...
Why not try the Dynotech spur to pinion converter...when 1:1 isn't enough
Old 03-05-2009, 03:37 PM   #36
chris moore's Avatar
Trader Rating: 88 (99%+)
Very nice piece of artwork Bob, its very well thought out and looks great. Now I have to find a way to add it to my allready way too large collection of 1/12's
Sponsered by:
CMDezigns Paint Works
https://www.facebook.com/pages/CM-Dezigns/259989190822177?ref=hl
chris moore is offline   Reply With Quote
Old 03-05-2009, 04:27 PM   #37
Tubaboy's Avatar
Any chance the rear pod could be made to work with an L4 chassis?
That car was a beast. I "pookied" Scottrik's tires making him run hard in the first few minutes.
Speaking of which, you guys going to post the results anywhere? I'd like to see the main results for SS sometime.
Paul
www.wyomingrc.com | www.wyomingmodelerspark.com
Tubaboy is offline   Reply With Quote
Old 03-05-2009, 06:07 PM   #38
Scottrik's Avatar
Mains results are posted (as are the heats) on the club site.
"Pookied" I was referring to applying compound...did it WAY too early. Tires started out heinous and got progressively worse. My best lap in the main was a second slower than my best in qualifying heats. That bad.
Old 03-05-2009, 06:16 PM   #39
Maybe now would be a bad time to tell ya I ran a 17.5 in the 13.5 superstock class.
l
"maybe". It's starts with the knowledge that the T-bar pivot ball spacing is the same, so that's good. Have to worry about what hits what after that. Without measuring, my gut says it's possible.
Old 03-05-2009, 06:22 PM   #40
Wow Bob that looks excellent, The hard work has paid off. A slick looking car with performance to match. Congrats!
Phil
filbert is offline   Reply With Quote
Old 03-05-2009, 06:40 PM   #41
Scottrik's Avatar
And you know we'd expect nothing less. Or more. Awesome job either way.
Old 03-05-2009, 07:05 PM   #42
HarryN's Avatar
Send a message via AIM to HarryN
Oh baby... I love it when you talk clean!! *grabs more lotion* Those pictures... can't stop looking!!
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
