Novak Sentry as Brushless Dyno
2 Attachment(s)
John Stranahan has suggested to add the moment of inertia of the rotor to the formula, and I agree. This means this will increase the power rating seen. Also I plan on calculating a 'friction factor' based upon the deceleration once the throttle has been released. This will also further increase the power rating.
If anyone has any ideas where I can find a heavier flywheel, please let me know |
I think a heavier flywheel would work best.
I have an EagleTree System and I may just try to duplicate what you did with it. |
Originally Posted by trailranger
(Post 5506539)
I have an EagleTree System and I may just try to duplicate what you did with it. I have a steel flywheel from an older dyno that I used before. |
Is the eagle tree flywheel heavier? where can I get this flywheel? A heavier flywheel is very much needed as noticing the hacker 13.5 reached over 7000 rpm in .1s and reached max power in .2s. Part of the reason it spins up so fast too is that I am using a LIPO battery to run it. The Fantom just uses 5V.
For testing my setup for velo racing, I have a home made chassis dyno that uses an old pod/tplate mounted to my scale table.
I have CAPPED tires on it, it uses a stock motor (as a slave) geared with a 4.00:1 ratio, and a resistor soldered across the motor (The gearing was tuned to pull 20 amps on a 21.5 motor at W.O.T.) I use the eagletree to monitor Voltage/Amp Load/RPM in my car. I can divide the MOTOR RPM by the cars gear ratio and find the AXLE Speed, and calculate estimated speed (minus Aero Drag) It's crude, but it's been pretty effective and accurate. |
Nice job, but I'm guessing that you either have a fantom dyno or have access to one. Why not just use the Fantom dyno instead of re-inventing your own?
I know the fantom is not "brushless ready" but I do know people are using them with brushless motors. IT's not all that difficult. I've done some testing of brushless motors on my Robitronic, the same procedure should work for the fantom or any other dyno for that matter. |
I can't run the RS Pro off of the Fantom power supply. I even added a receiver pack and with no voltage to the controller, it doesn't even turn on. And when the Fantom gives it juice, the controller goes through its arming procedure and by that time, the Fantom registers an error because the controller hasn't even begun spinning the motor yet.
Strange... my RS powers up and finds its neutral the moment I plug a receiver pack into the receiver... whether there's any power to the RS input leads doesn't seem to matter... it comes on and initializes either way.
The motor will even creep forwards if I pull the trigger with no input power to the RS, it must be "sneaking" some power from the rx pack to creep the motor. I just wait until I hit the "run motor" button on the dyno screen and then yank the trigger at the same time... It's interesting that your RS pro won't even boot up without input power... have you tried it leaving the RS switch in the off position? that's how I do it here. I'm using a small 2 cell LiPO from a foamy to power the receiver/RS here... maybe the higher voltage is what makes it work for me? |
I have the RS Pro in the on position. I actually have it hooked up to a 2S A123 and going through an HV BEC from Novak so it should be 6V at the receiver. Even when it is in the off position, it doesn't come on. Maybe I have it hooked up wrong. You have the BEC hooked up into the receiver right? And then you have your RS with an adapter with the red wire removed to the receiver?
I just ran another test with the Sentry dyno with a fully charged lipo battery and I believe ideal test conditions except no current reading yet, and I finally figured out excel too! :P actually it is open office, but here it is.
This test is with 0 boost on the controller. Next test will be with 10 boost. I will be testing the Novak 13.5 next too as soon as I get my motor back from James. http://arcadechamp.net/radio/135chart.JPG http://arcadechamp.net/radio/135dynoideal.JPG |
Originally Posted by mattnin
(Post 5508602)
I don't think the RS will come on if you have the red wire removed... if you have it that way, there's no path for the power to get to the RS from the rx pack... it would then NEED to get power from the "main" pack (or dyno) to come on... Try it with the red wire in place and the switch off... bet it'll work then. On the other hand, you seem to be doing VERY well with the Sentry method so far... |
If anyone wants to do this, I will show exactly the equations and how to do it (while my battery is topping off again).
First, convert RPMs to rad/s as I shown in the first post as an example. 2nd, calculate the moment of inertia (I) of your flywheel using .5MR^2 3rd, find the angular displacement. 0 (theta) = .5(Wo +W)T, Wo is the initial angular velocity in rad/s, and W is the current angular velocity in rad/s, and T is time 4th, find the angular acceleration. a (alpha) rad/(s^2) = (W^2 - Wo^2)/(2*(0 theta)) 5th, find torque t (N*m) =I*a 6th, find watts power (watts) = (torque (N*m) x 2pi x RPM)/60 7th, convert torque from N*m to gm*cm if you want to Multiply t * 10197.162 I won't go into all the math, but you can make a full equation by entering in the equation for theta into the angular acceleration formula, and then and then entering in the angular acceleration formula into the torque formula, and then simplifying. The simplified equation for torque if the time between readings is .1s is, t = ((RPM - RPMo)pi)/3 * I, where RPM is the current RPM reading and RPMo is the previous reading. The equation turns the data into rad/s so no worry about converting. t comes out in N*m as well. So as an example, lets calculate some data from the previous chart @ 3.8 seconds. The moment of inertia of my flywheel is 47.59E-6 kg*m^2 or 0.00004759 kg*m^2. t = ((11406-6282)pi)/3 * 0.00004759 = 0.2553603 N*m convert that to gm*cm 0.2553603*10197.162 = 2603.95 gm*cm find watts power = 0.2558969*2pi*11406/60 = 305.01W |
Trips, I thought the red wire was supposed to be removed? That won't blow up my speed control will it? :P This one is brand new :)
The steel flywheel that I have is from an old old dyno that I had and tore apart for another project.
For the RS guys wanting to run on the Fantom, here's what I've done in the past. 1) Run power from a receiver pack to the receiver (turns the system on) 2) Leave the speedo/radio at neutral (and no drag brake) 3) Hit the button to start the dyno run and at the same time hit the throttle on the radio to start the run. I've found that running like this is not very repeatable because of how the start of the run is calculated. It is very repeatable on a Turbodyno by the way. |
