Old 09-23-2001, 11:11 PM   #121
Hello Guys,
I am from Malta and had recently bought an HPI PRO3. Lately I was using a TC3. In late night I did lap times 0.2s faster than the TC3. However, during midday where temeratures where above 30C I had some problems. The back end of the car was simply unstable round tight corners. The setting was as instructed by the manual. Then I changed lots of settings and the problem remained. Lately I tried to use the hardest springs that I could find on the front and it worked. I recon that on our track we want a rigid chassis. Infact next time out I will fit some turnbuckle for the time being to make the chassis rigid until the neew parts arrive. Do you know a better solution for my problem.
Ray
Remo is offline   Reply With Quote
Old 09-24-2001, 05:24 AM   #122
Cosmo's Avatar
Here's how I run my Pro 3. It works good on our track, which is a prepared asphalt track:
Front:
50wt oil
#3 piston
Blue linear springs
medium sway bar
Rear:
45wt oil
#3 piston
Blue linear springs
no sway bar
I run a front one-way diff, 1 degree negative camber all the way around, neutral front toe in, and the kit standard setting for rear toe in/anti-squat.
I run the Penguin carbon chassis right now, but this is the same setup I was using with the standard chassis and it worked pretty good there too.
www.MBRSpeedShop.com - indoor carpet onroad and offroad racing in Roanoke, VA
Cosmo is offline   Reply With Quote
Old 09-24-2001, 07:05 PM   #123
Aurra Sing's Avatar
Beleive it or not, I have my Pro 3 for sale. http://www.rcracing.com/msgthread.cf...SiteMessages=1
Aurra Sing is offline   Reply With Quote
Old 09-24-2001, 09:16 PM   #124
Regional Moderator
kansasracer's Avatar
Now why would you do a thing like that?
Your not going to Losi, are you?
kansasracer is offline   Reply With Quote
Old 09-24-2001, 09:36 PM   #125
Aurra Sing's Avatar
Nah, never to Losi or Associated or whatever!
Well, i'm not sure if I want to keep it or not!
Old 09-27-2001, 09:22 AM   #126
TMHippo's Avatar
Hey where are all the PRO3 people, well here is a pic of the body I entered in the HPI Challange (PNW) didn't win but came in 2nd in ele sport. [IMG]e/imq_0241[/IMG]
TMHippo is offline   Reply With Quote
Old 09-27-2001, 09:43 AM   #127
Present! Here!
milf is offline   Reply With Quote
Old 10-01-2001, 05:28 PM   #128
Fangio's Avatar
Are the diff out drives strong enough for a 11 turn mod in the pro3.
Also i am usually a stock guy but my friend talked me into mod is it a big difference?
Fangio is offline   Reply With Quote
Old 10-01-2001, 08:22 PM   #129
Cosmo's Avatar
I have been running a 8x2 motor for a while in my Pro 3. I hve the new model outdrives, and I have not had any problem.
Old 10-02-2001, 06:13 PM   #130
Fangio's Avatar
thanks for the help.
i have another question though. i got a setup sheet off of the internet for my track and on the sheet one of the things is he changed the front piece. the piece to change the toe in it was marked 0 instead of 2. Is this aftermarket or whats the deal. the part number is its on the A 356 tree and its # 7. any help would be greatly appreciated.
Old 10-02-2001, 07:03 PM   #131
Cosmo's Avatar
You can change the front toe in with the tie rods. If it is the rear wheels, I found the car to be way too twitchy with the 0 degree rear block. I'd stick with the 2 degree ones.
Old 10-02-2001, 08:15 PM   #132
TMHippo's Avatar
Default More speed needed
I need help!? I'm using a MVP and just don't have the speed to keep up (only one lap down) the motor is just too hot any ideas on gearing ( 29/81 ). I will try any ideas for chassis tuning also.
PRO 3 racer
Old 10-02-2001, 08:53 PM   #133
Fangio's Avatar
my belt on my car is a little shredded if only ran it for 3 days at the track is it time for a new belt.
Old 10-03-2001, 10:13 PM   #134
Regional Moderator
OK,
anyone have a good carpet setup?
Moving indoors for the winter. I currently have a pro 3 with the Penguin chassis....
Never raced on carpet before, using rubber tires and a stock motor (P2K)...
Any help would be cool...
Old 10-09-2001, 03:45 PM   #135
Paco1001's Avatar
Looking for a carpet setup for indoor racing. Web sites or setups would be great.
Paco1001 is offline   Reply With Quote
