HPI Pro 3
Old 12-01-2001, 12:32 AM
  #196
Regional Moderator
mr4-malta's Avatar
ok i think i understand.....they are experimenting...with battrey/motor position and stuff like that......then when they get it right they will release a molded chasis with the new posititions...makes scence.....and the normal molded hpi chasis already has flex....i doubt if more is needed!..
.i might get the hpi graphite chasis its cheap......wouldnt hurt if i got one!
thanks
mr4-malta is offline
Old 12-01-2001, 07:59 PM
  #197
rc-zombies's Avatar
Just received the blue parts for the PRO3 from japan...
rc-zombies is offline
Old 12-01-2001, 08:01 PM
  #198
rc-zombies's Avatar
Old 12-03-2001, 10:01 PM
  #199
purplepro3's Avatar
Default which upper deck?????
there are several pro3 upper decks out there, but the HB appears to be the most popular. how does the others perform???
i am particularly interested in the kai upper deck which runs thru either side of the batteries, allowing easy access to the battery bars & batteries. anyone got a pic? i know i saw it somewhere.
purplepro3 is offline
Old 12-12-2001, 07:36 PM
  #200
TigeRyan's Avatar
Carpet setups...
I know I have seen a few on here, but I am looking for a good Stock Motor, high traction carpet setup....
Anybody??
TigeRyan is offline
Old 12-13-2001, 04:59 AM
  #201
sosidge's Avatar
My old carpet setup (sorry about the tamiya springs)
Body: Protoform Stratus
Motor p2k on about 29/81 or peak 12x1 on about 21/81
GMV12 speedo
KO 713 FET servo
Integy Sanyo 3000's
Front:
Blue Jaco foams (24mm)
Blue tamiya springs (stiff)
40wt oil
6deg caster blocks
Camber links in upper outboard hole, and upper inner inboard hole
Camber set for even tyre wear, erring on the negative side.
Toe in - about 1 deg.
All other settings as kit
Rear
Blue TRC foams (supposedly a little softer)
Blue tamiya springs
60wt oil
Camber links in upper outboard hole and upper inner inboard hole
Toe in 1deg (stock motor), 2deg (mod motor)
Other info:
Fibre-lyte top-deck fitted
shock bladders fitted
various other little tweaks that don't really do anything
Hope this helps - it's set up to turn in hard, and be responsive through chicanes.
sosidge is offline
Old 12-13-2001, 06:07 AM
  #202
Regional Moderator
here is a picture of my pro3
Ko Racer is offline
Old 12-13-2001, 07:35 AM
  #203
Regional Moderator
here are few more
Ko Racer is offline
Old 12-13-2001, 07:37 AM
  #204
Regional Moderator
the bottom
Ko Racer is offline
Old 12-13-2001, 07:39 AM
  #205
Regional Moderator
one more
Ko Racer is offline
Old 12-13-2001, 07:41 AM
  #206
Regional Moderator
the rear and the end
Ko Racer is offline
Old 12-13-2001, 08:05 AM
  #207
antoniop's Avatar
Geez,
Almost box stock...
antoniop is offline
Old 12-13-2001, 08:38 AM
  #208
OSherman's Avatar
That's a car? OOps! I thought it was some cool trophy you won.
OSherman is offline
Old 12-13-2001, 09:15 AM
  #209
Regional Moderator
someone emailed and wants to see the bodies i run
so here we go
Ko Racer is offline
Old 12-13-2001, 10:06 AM
  #210
antoniop's Avatar
Welcome Atshushi,
Now tell me, why don't you run with the Pro 3 if you are sponsored by HPI?
antoniop is offline
