Old 03-02-2009, 09:43 AM   #1
Default 13.5 Gearing help?
Well its that same old gearing question again!!
I currently run on a medium sized carpet track 25m x 12m with a LRP Vector X11 Stock Spec
Last week I just could not get the temperature down below 85-90c!! I was running 5.46-5.01 now I know I am heavy on the thumbs but I thought that was about right!!!
one thing I always get conflicting advice on is if the motor is stressed and not maxing out it will get hot but others advise that it can also go the other way revving out can also cause heat, so whats correct??
I was trying out the new Granturismo Version 2 with punch turned down timing reduced and very little drag brake!!
Could also do with gearing advice on the Orion Vortex 13.5 Race Spec as I am about to try one of those
Thanks for any help
008-Racer is offline   Reply With Quote
Old 03-02-2009, 09:52 AM   #2
John Tag's Avatar
Trader Rating: 42 (100%+)
17.5 low timing on speedo 3.90-4.0 is decent place to start 13.5 4.80-5.0
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 03-03-2009, 02:30 PM   #3
Toy Tuning's Avatar
Thanks for any help
I ran exactly the same motor, indoors on a large carpet track with a bit of advance on the motor geared at a 5.08 was very fast but was corncerned about motor temps aswell.
Those are the two theorys that the motor is revving out or working too hard both causing heat and both are correct.
You could, quite simply run a heatsink with a fan on the motor to help a little bit.
Its all trial and error really. But as long as the temps arent excessive and performance is relatively good I wouldnt worry too much about it.
Lee
Toy Tuning is offline   Reply With Quote
Old 03-03-2009, 07:28 PM   #4
trailranger's Avatar
The temps could be cuased from an very pushy car or a car with bad bearings.
How are your lap times compared to other drivers?
"If everything seems under control, you're just not going fast enough." - Mario Andretti
trailranger is offline   Reply With Quote
Old 03-04-2009, 12:48 AM   #5
Thanks for all your replies very kind
The car is really free (Ceramic bearings all round!) and to be honest it is one of the fastest I run alongside some 10.5's and have been winning!!
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 08:58 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
AZ ONROAD RACERS i am cornholio Arizona-New Mexico Racing 2506 05-30-2015 08:53 AM
Tamiya DB-01 Durga. The next budget racer? streetracer745 Electric Off-Road 923 11-25-2014 11:16 PM
The J82 Thread AndyMoore Electric Off-Road 461 01-16-2012 01:27 PM
The One True 13.5 Thread syndr0me Electric On-Road 713 02-02-2008 02:53 PM
