Charging with GFX >
Charging with GFX
Charging with GFX
Old 11-19-2003, 01:42 PM
stumper1's Avatar
Default Charging with GFX
Just got my new GFX charger. In the menus I don't see any way to select # of cells. There are settings allready programed for 4 and 6 cell and 8 cel tx. Am I missing something?
stumper1 is offline
Old 11-19-2003, 01:48 PM
It automatically detects how many cells its charging so there is no need to set anything and its not even an option.
rcpilot is offline
Old 11-19-2003, 01:54 PM
stumper1's Avatar
rcpilot
Thanks!! I figured as much but every charger I've had before required it so I wanted to be sure.
Thanks again for the fast reply!!!
stumper1 is offline
Old 11-19-2003, 09:40 PM
Scrad's Avatar
Trader Rating: 16 (100%+)
If you go to the discharge mode and hit page then it will bring up the number of cells. Change it there and then save the setting. Just so you know for sure that you charging the right amount of cells. Good piece of mind.
Scrad is offline
Old 11-19-2003, 11:13 PM
newracer's Avatar
The only mode that requires the # of cells is the discharge mode. It needs it to calculate the cutoff voltage.
newracer is offline
Old 11-20-2003, 04:33 AM
N4S
N4S's Avatar
I dont know what gfx you guys are using , but you do need to select all your charge and discharge info unless you use the pre selected programs. In the profiles you can scroll down and change and save and load all the settings you select. cells , current,lockout, etc. you can then name and save these settings, but you do need to save and load them first. Read the instructions, its all in there. i have noticed the peak cut off needs to be at .05 for a truely peaked pack anything lower and the cells dont even get warm to the touch.
N4S is offline
Old 11-20-2003, 04:34 AM
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
The menu's can be a little confusing at first....
Remember the "PAGE" button...
Tres is offline
Old 11-20-2003, 05:01 AM
Default TX cells
I have the GP2000 Cells. What are ya'lls settings for those on the GFX?
I've tried 1A w/.3 cutoff, but I don't seem to get much life out of that. (I have an R1 radio, which is a juice sucker anyway).
Thanks for any help I get.
acyrier is offline
Old 11-20-2003, 07:56 AM
Rob Hochberg's Avatar
you have to go all the way to last page, (before the charge one) and change your machine profile according to how many cells you're charging, i believe theres 8 pre programmed profiles, 6 cell, 4 cell, tx pack, rx pack, 8 cells.. etc.
Rob Hochberg is offline
Old 11-20-2003, 08:09 AM
Default TX cells
I purchased mine used, so the standard settings are no longer there. But Thanks.
acyrier is offline
Old 11-20-2003, 08:20 AM
acyrier, .3 or .03 peak detect? 1A charge should be sufficient for AA's batteries, I charge my 1800 NiMH's between .4 and .6A's with a peak detect of .02V and have plenty of capacity. I use a KoPropo radio though.
ZER01 is offline
Old 11-20-2003, 08:27 AM
Default TX cells
EEks, yes. .03. I'll try charging at a higher amp rate. and .02. Maybe I'll have better results. I did have the old sanyo 700mah AAnicad's. I wasn't getting any better life out of the 2000's, so I figure I'm not charging them correctly.
acyrier is offline
Old 11-21-2003, 09:25 AM
newracer's Avatar
Default Re: TX cells
If you hold down the "Page" button when you power it up it will reset the memory and should reset to all the factory settings.
newracer is offline
Old 11-21-2003, 02:15 PM
rc-zombies's Avatar
Default Recommended 20amp powersupply
Looking to get one soon.
I was reading the specs on the charger is says 20amp power supply is recommended...
can I get away using a 14amp power supply? I have Integy's SHE power supply.
lmk thanks in advance.
rc-zombies is offline
Old 11-21-2003, 02:59 PM
Tres's Avatar
You will be limited on the amount of amps your motors can draw...
The GFX has up to 20A motor run feature..
Tres is offline
