What should my  charge current be set at for my 6500 mah 2S 30c Lipo? >
Old 02-27-2009, 01:11 PM
Default What should my charge current be set at for my 6500 mah 2S 30c Lipo?
I have a Tunigy charger and I can set the current charge between .05A-5.0A . What should the current be set at.
RaV3N is offline
Old 02-27-2009, 01:15 PM
loopedeloop's Avatar
1C would be 6.5A so 5A from your charger will be fine.
loopedeloop is offline
Old 02-27-2009, 01:30 PM
Will it charge the battery completely
RaV3N is offline
Old 02-27-2009, 01:37 PM
Regional Moderator
CarbonJoe's Avatar
Yes. It just takes longer at the lower C rate.
CarbonJoe is offline
Old 02-27-2009, 01:40 PM
how long do you think it will take?
RaV3N is offline
Old 02-27-2009, 01:43 PM
Regional Moderator
CarbonJoe's Avatar
Too hard to say, it really depends on how far you've discharged it. Anywhere from 15 minutes to 1 hour or so. If it was fully charged and you ran a 5 minute heat in 17.5 touring car, you'll probably use about 1500 - 1800 mAh.
Old 02-27-2009, 01:45 PM
Well the battery is brand new? So im guessing it doesnt come with a charge?
RaV3N is offline
Old 02-27-2009, 01:51 PM
Regional Moderator
CarbonJoe's Avatar
It had better have a partial charge (probably around 7.0 volts). A LiPo is fully charged at 8.40 volts. You shouldn't discharge a LiPo much below 6.4 volts (3.2V per cell) or you can do irreversible damage to the pack. Plug it in and charge it a 5A. The current will ramp up until the pack hits 8.40V, then the current will drop slowly until around 0.10A. Some people say it's charged as soon as it hits 8.40V, but there could still be a few hundred mAh still left to go. The last 10-15% of the capacity takes the longest, since the current is lowest at that point in the charge cycle.
Old 02-27-2009, 01:52 PM
If charging from flat expect it to take about 1 1/2 to 2 hours
