What should my charge current be set at for my 6500 mah 2S 30c Lipo?
I have a Tunigy charger and I can set the current charge between .05A-5.0A . What should the current be set at.
1C would be 6.5A so 5A from your charger will be fine.
Will it charge the battery completely
how long do you think it will take?
Well the battery is brand new? So im guessing it doesnt come with a charge?
It had better have a partial charge (probably around 7.0 volts). A LiPo is fully charged at 8.40 volts. You shouldn't discharge a LiPo much below 6.4 volts (3.2V per cell) or you can do irreversible damage to the pack. Plug it in and charge it a 5A. The current will ramp up until the pack hits 8.40V, then the current will drop slowly until around 0.10A. Some people say it's charged as soon as it hits 8.40V, but there could still be a few hundred mAh still left to go. The last 10-15% of the capacity takes the longest, since the current is lowest at that point in the charge cycle.
If charging from flat expect it to take about 1 1/2 to 2 hours
