Old 02-26-2009, 05:04 PM   #1
jhock's Avatar
Default 1/12 typical tire diameter
I am starting to get serious in 12th scale. I ordered a bunch of tires and want to know what is the typical size you guys are trueing them too? i want longevity out of them but not a big deal. Front tire and Rear tire. I see the pros with no foam on there tires when they true them and others with normal amount. I just measured my twister tires and the front are 44.6mm and rear are 46.8mm.
jhock is offline   Reply With Quote
Old 02-26-2009, 05:43 PM   #2
scootr117's Avatar
I run a .1 split front to rear...1.62 front and 1.72 rear.
I run a little taller for club races , but the split stays constant..
Scooter EXperimental
RK Designs
CD SuperPro Motors
Mike Pulfer is my HERO....
scootr117 is offline   Reply With Quote
Old 02-26-2009, 09:59 PM   #3
Jeff Brown's Avatar
Well, those size tires are not too bad to run at club racing and such. We used to race with those sizes a while ago. If you are serious about racing then I would look to start at 1.62" (41.2mm) and 1.72" (43.7mm) like scootr117 mentioned.
Jeff
Jeff Brown is offline   Reply With Quote
Old 02-27-2009, 04:23 AM   #4
Also depends on the track.... the track I race at its better to start with full rears (crc pro-cuts) and you can race em untill they hit the 43mm mark.
From then on the rear will be unpredictable at certain parts of the track.
On another track I know, anything above 43mm will make you flip...
What i mean with this is, dont be dumb and true all the tires you receive to 43mm cause it can seriously backfire!
Make it idiot-proof, and someone will make a better idiot.
Quante is offline   Reply With Quote
Old 02-27-2009, 05:22 AM   #5
Trader Rating: 41 (100%+)
Yes it is all dependant on your track. our little club track is very bumpy. We have to have a ride height of 4mm+ to just clear some of the bumps. so we tend to leave the tires as tall as possible. when mine get down to 44 mm traction is horrible and so inconsistant and also some tire compounds work well at some tracks and not at others.
Our carpet is old and if you are running magenta rears and need just a bit more byte, don;t even think of going to pinks. you have to go all the way to white. at our track pink is instant death. 2 of the corners will be loose and the rest will be too tight.
Just FYI check to see what everyone else is running and try that. Or do what I did and bug the fast drivers to "try" their old tires when they switch to new ones.
lol
jdeadman is offline   Reply With Quote
Old 02-27-2009, 06:04 AM   #6
Trips's Avatar
Trader Rating: 16 (100%+)
For club racing I start my rears at 1.75" (44.5mm) and the fronts at 1.65 (42mm). Any bigger than that and they can be a bit grabby and tend to chunk easily. Nothing ruins my day like leaving them on the large side for longer life then chunking on the first run.
I run them as long as I can. They just get better and better here at our track. They usually peel before I run out of ride height adjustment.
If I'm doing my part and staying off the wood I can get two to three race days out of a set of tires.
MARSHAL!!
Trips is offline   Reply With Quote
Old 02-27-2009, 07:28 AM   #7
Kwikvdub's Avatar
Trader Rating: 91 (100%+)
Send a message via AIM to Kwikvdub
........He said WOOD!!.............
Alex Valdes
TQRacing / 360 v2 RC Raceway / Team Downgrade Designs
Kwikvdub is offline   Reply With Quote
Old 02-27-2009, 08:15 AM   #8
RC_Dan's Avatar
Send a message via MSN to RC_Dan Send a message via Yahoo to RC_Dan
I usually start mine somewhere between 1.75 and 1.72 for rears and 1.68 and 1.62 for fronts depending on the track.
AE TC6 B4 & 18T, Kyosho Lazer ZX-5
CRC Gen XL & Battle Axe, Hot Bodies Ve8
460whp CRX on E85
RC_Dan is offline   Reply With Quote
1/12 forum ovalnator Electric On-Road 46182 Today 08:07 AM
NEW XRAY T2 ddesros2 Electric On-Road 5873 02-12-2012 06:56 PM
1/12 set up guide evirobs Electric On-Road 15 03-04-2009 05:11 PM
Need help with micro setup microdude Electric On-Road 12 02-29-2004 08:25 PM
