Old 12-01-2009, 01:15 PM   #1336
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
you put CA on the front tire sidewalls.
The thing with the xenon tires is that they are HUGE.
Which means the sidewall can build up a lot of traction.
This is why you CA it.
if you put a lot of shims under the front inner ballstud the CA edge is reached faster when the car rolls and this this stops the car from traction rolling.
That is called "the edge theory" :-)
you usually get maximum traction with 1.5 - 2mm under the front inner ballstud. which is what I use most of the times. unless the car is traction rolling ofcourse.
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 12-01-2009, 05:25 PM   #1337
JimmyMac's Avatar
Would a better way to explain the shims under the front inner link be less camber gain. More shims = less camber gain. So like what Martin said, you reach the CA faster on the sidewall. With less shims, you have more camber gain, so the car will roll more before you reach the CA. That would be my take on it.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 12-02-2009, 04:31 AM   #1338
yeah that'S about what I wrote ..
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 12-02-2009, 09:53 AM   #1339
RC MARKET's Avatar
Steel outdrives
DVD
New Yokomo TC, the BD-5-yo-d-046.jpg   New Yokomo TC, the BD-5-yo-dvd-09tse.jpg
RC MARKET is offline   Reply With Quote
Old 12-02-2009, 10:37 AM   #1340
Kajman's Avatar
Hi Guys,
Any idea where I can buy BD5 currently? And maybe some proposal of upgrades to buy with it in the same moment to race in 9.5 class?
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 12-02-2009, 05:53 PM   #1341
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by Kajman View Post
Hi Guys,
Contact Elwyn @ HobbyHaven
Give the best while u can !
kschu is offline   Reply With Quote
Old 12-03-2009, 06:15 AM   #1342
altreyx's Avatar
sorry for the late reply , many thanks @Martin, Jimmy for the explanations.
I'll try this during the next race.
Thank you guys
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 12-04-2009, 09:34 PM   #1343
kschu's Avatar
guys, issit necessary to use graphite rear hub??
Old 12-05-2009, 07:08 PM   #1344
Sterlzy's Avatar
Trader Rating: 29 (100%+)
Default Selling my BD5
Hi guys selling my BD-5 if anyone is interested.
PM ME for details
Sterlzy is offline   Reply With Quote
Old 12-06-2009, 07:58 AM   #1345
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Well I raced my bd5 at my local carpet track in Horsham pa last night I didn't do as good as I expected(tq'ed the B main). I was basically running martins latest setup and tried changing springs(front gold to front pink). I also changed shock top position to no avail. The car kind of pushed entering the corner an a little on exit. We all run Jaco blues as tires. In the main the car got better but started to traction roll. I didn't glue the sidewalls because it was pushing in the heats. Everyone I talked to including Larry Fairtrace and Jason Schreffler told me I needed 6 degree blocks. I was wondering:
1 what everyone felt about 6 degree blocks. Also does anyone know if any other manufacturers blocks fit.
2. Is the anything more I can do to get more entry steering without traction rolls.
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 12-07-2009, 10:02 AM   #1346
are you talking foam tires?
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 12-07-2009, 11:08 AM   #1347
fpart's Avatar
Martin. No, I am talking rubber Jaco Blues. Sorry
スクービーは私のヒーローです!
Old 12-09-2009, 01:43 AM   #1348
then use the one where I used sorex tires in ingolstadt (big very technical track) I posted not too long ago
this should have more than enough turn in
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 12-09-2009, 05:18 PM   #1349
fpart's Avatar
OK Martin thanks!. I'll give it a try next week. Just in case I was able to rig up a set of Pro4/Cyclone 6 degree caster blocks in case that doesn't work. They actually work with just a few mods.
スクービーは私のヒーローです!
Old 12-10-2009, 12:00 PM   #1350
Default foan tyres
Hello someone tested foan wheeled car, which setup to use, and what types of wheels
manchu is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
