Old 11-17-2009, 09:12 AM   #1291
JimmyMac's Avatar
I have a few times. First time it happened out of no where. Dunno why? Next time was a tap in the rear. Happened one or two more times after that. I suspect the plastic end hole was molded slightly too big. Therefore it is easy for the shock to come un-threaded. That, of the material is too hard. I will be switching to different ends shortly.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 11-17-2009, 01:36 PM   #1292
altreyx's Avatar
Originally Posted by kschu View Post
thanks for your picture....
what if you hit the curb island ? will it damage the holder?
during this indoor season i never had a problem for that. Same for my friends using this way for to fit the lipos.
I fit the lipo with the HUDY Reinforced Tape or something like that, so i use this system for to keep the lipo more fixed into the car and i use some external weight for to balance my car.
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 11-18-2009, 05:53 PM   #1293
morris's Avatar
Trader Rating: 40 (100%+)
do they make a lipo plate for this car?
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 11-18-2009, 06:30 PM   #1294
JimmyMac's Avatar
Lipo plate? You mean chassis? If so, then no, they do not make a lipo chassis. But they do make a stick pack chassis. It has no cutouts to tape down your battery. It does have a battery strap. Just not sure how you would make the battery fit with the stick pack outer brace (unless if you just flipped it around). It is a wider chassis. So you will have more chassis scrub. I'm not even sure if a lipo will fit into the milled section. Here is the link to the kit car. You can buy the chassis separate.
http://www.teamyokomo.com/jpn/produc...r4tc_bd5p.html
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 11-18-2009, 08:42 PM   #1295
DaSkills's Avatar
Hey Jimmy, man you missed all of the fun on Sunday. The weather was perfect.
TRF416 - Tamiya 801X - Xray XII - 4PK - Fantom Racing - Reedy - SMC - Jaco -LRP - Sorex -Tekin -Orion - Thunder Power
AKA: "No Limitz"
DaSkills is offline   Reply With Quote
Old 11-18-2009, 09:19 PM   #1296
JimmyMac's Avatar
Yeah, I had a lot of homework. Plus my Yok is all apart right now. Gonna re-sand the lower deck before carpet season starts up in VA (or just order a new one). But I may bring my TA05 out there one weekend. I need to order new wire for my esc so that I can redo everything. I pulled the heat sink and fan off the ORCA. Gonna make an aluminum plate to go on top. I'll catch ya sometime soon!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 11-18-2009, 10:59 PM   #1297
JimmyMac's Avatar
Is this the elusive lipo plate?
http://akira01.dtiblog.com/
http://10.dtiblog.com/a/akira01/file/20091117225637.jpg
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 11-18-2009, 11:45 PM   #1298
Elwyn Lee's Avatar
Originally Posted by JimmyMac View Post
Apparently this carbon graphite brace is design for Yokomo BD to hold on straight pack battery.
But I guess we can mod it to use on our BD5 for Lipo use.
Hobby Haven Sdn Bhd
Tel / Fax : +603-7499 4191
Email: [email protected]
http://www.hobyhaven.com.my - http://www.hobby-haven.blogspot.com - http://www.teamyokomo.blogspot.com
Elwyn Lee is offline   Reply With Quote
Old 11-18-2009, 11:48 PM   #1299
Trader Rating: 26 (100%+)
Send a message via AIM to kriiiss
hey elywn are you able to get that yokomo part?
kriiiss is offline   Reply With Quote
Old 11-19-2009, 03:02 AM   #1300
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
no it's not the lipo plate
but so far the standard 6cell plate works just fine.
you actually have the option to fill the battery slots with leadweight and thus get perfect balance without any visible leadweight in your car
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 11-19-2009, 09:44 AM   #1301
morris's Avatar
i was meening something like ae has.it fits in the battery slots that are there.and has cornered edges to keep the lipo planted.
its kool though.dont have any lipo batts just yet.still running old 4600 packs for now.untill the new yr anyways.
thx for the info
Old 11-19-2009, 02:39 PM   #1302
I use this lipo weight tray in my BD http://www.ppdbillet.com/RC_accessories.html
TcORC president
Yokomo bd7 sedan, bd7 usgt
Roche rapide p12
magnum is offline   Reply With Quote
Old 11-19-2009, 04:40 PM   #1303
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
same ones i use and they are great because they work perfectly with any current chassis by making use of whats already there (ie. battery slots). the side weights also look clean and help balance off the car nicely (left to right) without adding too much weight.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 11-19-2009, 04:46 PM   #1304
JimmyMac's Avatar
I used that as well when I had my 416. But the batteries I use now have numbs on the bottom. Plus it will not balance out like that on my car (just bottom plate). So I can't use it. Plus adding the side weight and bottom plate will make the car way over weight.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 11-19-2009, 06:10 PM   #1305
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
i heard using those plate will make d car have unbalance flex left and right....
but it's really hard to make the car 1500g without visible leadweight on the chassis....
Give the best while u can !
kschu is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
