Old 11-12-2009, 08:53 PM   #1276
JimmyMac's Avatar
Looks like Yokomo has a new kit out that comes with the graphite arms and bladed diff. Sounds like a good deal. No need to buy all that stuff separate now for new buyers.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 11-12-2009, 11:09 PM   #1277
Elwyn Lee's Avatar
Default Yokomo BD5E
NEW!!! Yokomo BD5E (limited Edition)
Yokomo Japan Have launch a limited edition car kit based on the winning car from JMRCA 2009 super expert class. Only 300 units available.
The car kit come with standard aluminum bulkhead but all the plastic material parts have change to graphite material and come with the new aluminum diff outdrives with plastic C blade.
Specifications:
- BD-008FG Graphite Front Suspention Arm for BD5
- BD-008RG Graphite Rear Suspention Arm (40.5mm) for BD5
- BD-413G Graphite Front Steering Hub Carrier
- BD-415SG Graphite Front Steering Block
- BD-415RG Graphite Rear Hub Carrier
- BD-500P Aluminum Protect Diff Joint Set for BD5
Source: H
Hobby Haven Sdn Bhd
Tel / Fax : +603-7499 4191
Email: [email protected]
http://www.hobyhaven.com.my - http://www.hobby-haven.blogspot.com - http://www.teamyokomo.blogspot.com
Elwyn Lee is offline   Reply With Quote
Old 11-13-2009, 02:37 AM   #1278
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Outer hole on the rearhub make the car more stable / gives more rear end traction
no new shock bodies, maybe just a different batch
the kit bladder is just as hard as ys-8hd but gets bigger and softer as soon as it comes in contact with oil. This is why everyone is using the newer black one
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 11-15-2009, 05:26 PM   #1279
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by altreyx View Post
I'm using this system for to fit the Lipos on the BD5, i'm using the new upperdeck and the T.O.P battery brace set.
Feel free to comment my idea. Thank you.
Ciao
hi, just wan to ask...will the top brace set rubbing the track surface during you cornering ???
Give the best while u can !
kschu is offline   Reply With Quote
Old 11-15-2009, 06:41 PM   #1280
JimmyMac's Avatar
You should ask the Top guys. I think they could answer best since they've run it like that since their car came out.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 11-15-2009, 06:44 PM   #1281
kschu's Avatar
the idea of using top brace set in bd5 might be a good....since d brace can keep d weight low...
our rules here is 1500g with PT for stock class...so it's very messy to stick all d weight all around the chassis....
Old 11-16-2009, 02:01 AM   #1282
Elwyn Lee's Avatar
Specifications:
Source: H
Update!!!
After getting confirmation from Yokomo Japan.
The new Yokomo BD5E (Limited Edition). Comes with 2 different types of chassis and 2 types of upperdeck.
This is a great deal.
Hobby Haven Sdn Bhd
Old 11-16-2009, 02:53 AM   #1283
altreyx's Avatar
no when the car is rolling is touching before the chassis, anyway i'm thinking to put some shims like 1mm for security.
There is need only to pay attention to the "killers" that brake in late and they center you on the right side a my friend has broken the plastic support for that reason but this is not a system fault only a normal crash
EDIT: i have updated the reply with a foto pushing on one side the car, there is 1,1mm shims under the support for to keep it up. I'm sorry if the photo is not a real high quality
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 11-16-2009, 03:02 AM   #1284
altreyx's Avatar
Basically, the simple way to convert, is use the tradition method, then add 3.5mm to get the "Yokomo" measurement found on Team setup sheets. So 5mm on the gauge, plus 3.5mm equals 8.5mm. Simple enough.
Originally Posted by Martin Hofer View Post
if you measure the thickness of the wishbone, where the hingepin is, you will find it to be 7mm
which is 3.5mm when divided by 2
which means
5mm droop on a droop gauge / hudy blocks = 8.5mm hingepin height EXACTLY
I use 9.5f/8.7r 90% of times as it just feels best balanced
for that I set 6.0/5.2 on the fine hudy gauges
Yes everything is clear, my doubts were because on the old BD people were talking about drops like 6 5 4 or sometimes 7...now looking on some setup there was write 11 10 etc. So i was a little bit confused while on a car people were using different systems for ceck the value
Anyway now is perfect and 0 chance to made a mistake.
Thank you again for the explanations
Orca-Gm120
Reedy-Lrp
Helios EX10
Old 11-16-2009, 01:43 PM   #1285
wkl
Martin,
Any advice on the shock end ball cap?
Because sometimes when someone crash from the back of my car the shock end ball cap will pop out or after a period of time of wear and tear the ball cap will pop out by itself when on the track.
wkl is offline   Reply With Quote
Old 11-16-2009, 05:52 PM   #1286
kschu's Avatar
Originally Posted by wkl View Post
Martin,
guess it's time for u to replace it ??
Old 11-16-2009, 05:52 PM   #1287
kschu's Avatar
Guys, i saw japan are selling the Yokomo Lipos....
anyone hv more infos on it ???
Old 11-16-2009, 06:55 PM   #1288
kschu's Avatar
thanks for your picture....
what if you hit the curb island ? will it damage the holder?
Old 11-16-2009, 09:07 PM   #1289
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
looking at the hard case and how the bullet connectors are lines up more to the center of the pack, these could be reedy packs
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 11-17-2009, 06:43 AM   #1290
Martin,
Never ever had that happen
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
