Old 11-10-2009, 09:31 AM   #1261
SammyZ's Avatar
Trader Rating: 138 (100%+)
Jimmy, where do you buy your Orca products?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 11-10-2009, 09:39 AM   #1262
Elwyn Lee's Avatar
Hobby Haven Malaysia.
PM me for anything u need.
Hobby Haven Sdn Bhd
Tel / Fax : +603-7499 4191
Email: [email protected]
http://www.hobyhaven.com.my - http://www.hobby-haven.blogspot.com - http://www.teamyokomo.blogspot.com
Elwyn Lee is offline   Reply With Quote
Old 11-10-2009, 10:34 AM   #1263
Korey Harbke's Avatar
Also check http://www.muchhobby.com/shopping/
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 11-10-2009, 10:09 PM   #1264
tandman's Avatar
Send a message via Yahoo to tandman
MuchHobby is awesome, Patrick Chan is very helpfull and ships the orders quickly.
Dwayne Flodell
Team Mad Scientist
-When you need mad rip.....call the Mad Scientist
Team Sweepracing-R1 Wurks Team Canada
tandman is offline   Reply With Quote
Old 11-11-2009, 12:16 AM   #1265
5000 40C with standard chassis and top deck.
-rv- is offline   Reply With Quote
Old 11-11-2009, 05:19 PM   #1266
JimmyMac's Avatar
I was asked about droop measurement on the BD5. As some may know, the Yokomo Factory Team measures droop a little differently than most. So if you see a setup sheet and see 9.5mm or 8.5mm droop... what does that mean? Here is my understanding of this measurement. Measure droop from the center of the outer hinge pin as seen in the pic below. This one is 8.5mm droop.
You can also try this way as long as the arms are level (no kickup or squat, etc.)
And of course, here is the traditional way, but it does not give you the Yokomo way. I think you could say 5mm droop is equal to 8.5mm Yokomo droop. Or close to it.
Hope this helps.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is online now   Reply With Quote
Old 11-11-2009, 10:58 PM   #1267
SammyZ's Avatar
jimmy,
you can whiten your belts with bleach soaked on a towel
Hotbodies USA
SweepRacing USA
Old 11-12-2009, 12:48 AM   #1268
altreyx's Avatar
Hope this helps.
Thank you for the photoes, now everything is more clear.
Yokomo BD7 - Yokomo R12C
Orca-Gm120
Reedy-Lrp
Helios EX10
altreyx is offline   Reply With Quote
Old 11-12-2009, 02:27 AM   #1269
Elwyn Lee's Avatar
New!!! Yokomo Beltec 7N (New Compound) Slick Tire.
Specially design slick tires for onroad racing. 7N using newly developed tire compound. Providing the consistent grip without using any traction compound on the tires.
7N slick tires is suitable to use on Low ~ Med temperature road surface.
Recommended insert: Yokomo 039M medium insert and Team bomber insert.
Source: H
Hobby Haven Sdn Bhd
Old 11-12-2009, 03:06 AM   #1270
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
if you measure the thickness of the wishbone, where the hingepin is, you will find it to be 7mm
which is 3.5mm when divided by 2
which means
5mm droop on a droop gauge / hudy blocks = 8.5mm hingepin height EXACTLY
I use 9.5f/8.7r 90% of times as it just feels best balanced
for that I set 6.0/5.2 on the fine hudy gauges
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 11-12-2009, 03:13 AM   #1271
JimmyMac's Avatar
Basically, the simple way to convert, is use the tradition method, then add 3.5mm to get the "Yokomo" measurement found on Team setup sheets. So 5mm on the gauge, plus 3.5mm equals 8.5mm. Simple enough.
I remember back when Yokomo tires were the shiznit in the '90s! I wonder how these new tires will hold up against Sorex....?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 11-12-2009, 05:09 AM   #1272
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Mike what springs are those on your car. Are they HPI?
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 11-12-2009, 06:25 AM   #1273
yes looks like hpi silver
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 11-12-2009, 05:06 PM   #1274
JimmyMac's Avatar
Yeah, HPI silver rear and gold fronts. I ran those when I ran asphalt mod. I'll start out with them on carpet as well. But I need to pick up some other HPI springs. What, Blues and Pinks? Something like that.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 11-12-2009, 07:43 PM   #1275
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
what the effect of using the outer hole of rear Hub ??
I saw ronald was using it at JMRCA.....
i just help my fren build a brand new BD5 which is new stock from Hobby Haven, i saw the shock body is different from mine. It's alittle bit grey.(new shock body? ) The bladder that come with the kits is still transparent but the shape and the hardness are same like the black bladder unlike mine, which is way softer..
Give the best while u can !
kschu is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
