Old 11-05-2009, 07:23 AM   #1231
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
You used a 0,05mm shim or a 0,5mm shim?
A 0,5 is absolutely wrong
and I don't get the "loose screws" point really
you can just tighten them
I don't even use loctite or anything
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 11-06-2009, 05:20 PM   #1232
JimmyMac's Avatar
Thanks for the shipment Elwyn. I finally got it today. I dunno why customs held on to it?? Weird. First time that's happened in the several years that I have mail ordered form overseas. But it's bound to happen every now and then. Thanks for clearing it up. Great Service!!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 11-06-2009, 05:22 PM   #1233
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
bought new options????
Give the best while u can !
kschu is offline   Reply With Quote
Old 11-06-2009, 05:34 PM   #1234
JimmyMac's Avatar
I just wanted to get the new bladed diff. But I forgot to order the aluminum chubs. I need those for indoor carpet because the tracks I race on have hard walls. Some walls have tape on them. If you get too close, the tape will grab the tire and crack the chub without you knowing it. The Yokomo graphite chubs are very hard, but crack easy. Much like the Tamiya 416 graphite chubs. Seems like even small taps from other cars will crack them. Of course, I'm sure others don't have this problem. Outdoors it's fine.
If you look close, you can see the crack. Though small, it causes slop/flex.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 11-06-2009, 05:45 PM   #1235
kschu's Avatar
[QUOTE=JimmyMac;6573478]I just wanted to get the new bladed diff. But I forgot to order the aluminum chubs. I need those for indoor carpet because the tracks I race on have hard walls. Some walls have tape on them. If you get too close, the tape will grab the tire and crack the chub without you knowing it. The Yokomo graphite chubs are very hard, but crack easy. Much like the Tamiya 416 graphite chubs. Seems like even small taps from other cars will crack them. Of course, I'm sure others don't have this problem. Outdoors it's fine.
yeah, i notice it's quite easy to break the graphite c-hub...i broke mine after someone tap me from side...so now i oni will use graphite c-hub in big race...
you going to mod your old diff to fit in the blade? i just did mine few days ago but havent test yet...u need to file the outdrive 2mm deeper in order to fit it perfectly..
Old 11-06-2009, 05:48 PM   #1236
JimmyMac's Avatar
No, I'm going to continue to run the diff until it goes bad. Then I will toss it and run the new style diffs. But this weekend, since I'm running 4.0 mod and lipo, I will be using the MaxConcept harden steel diff!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 11-06-2009, 06:17 PM   #1237
JimmyMac's Avatar
Crap, I might not have the right size spur to run mod at 9ish final. Will a 108 spur fit in the BD5?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 11-06-2009, 09:49 PM   #1238
DaSkills's Avatar
Good luck this weekend Jimmy. Try not to tear up the BD5 this weekend. Running a 4.0 and a lipo, it might not be an easy task.
TRF416 - Tamiya 801X - Xray XII - 4PK - Fantom Racing - Reedy - SMC - Jaco -LRP - Sorex -Tekin -Orion - Thunder Power
AKA: "No Limitz"
DaSkills is offline   Reply With Quote
Old 11-06-2009, 09:53 PM   #1239
JimmyMac's Avatar
Should be no problem, I actually have an esc that can handle it!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 11-06-2009, 09:53 PM   #1240
kschu's Avatar
vritra tc spec?
Old 11-06-2009, 10:00 PM   #1241
DaSkills's Avatar
I can't wait to get mine.
AKA: "No Limitz"
Old 11-06-2009, 11:27 PM   #1242
Originally Posted by kschu View Post
vritra tc spec?
I have to wait until December to get my ORCA
-rv- is offline   Reply With Quote
Old 11-06-2009, 11:32 PM   #1243
Yeah I used the wrong shims. Need to go to HobbyShop to get the right one.
By the way can you recommend a good basic setup for this track? Thanks.
Old 11-06-2009, 11:40 PM   #1244
you actually brake a c-hub?
Me, steffen and Johann are testing on a track with similar outer walls as you describe your track markers and haven't broken a C-hub yet!
actually I have not yet broken any C-Hub on the Bd5 but if you find them to break you might want to go with the standard plastic c-hubs
Alloy is no solution as it will, unlike graphite, bend or even worse make the wishbone/steering knuckle break
btw to all: as I see that broken C-Hub
keep checking your inner and outer hingepins
they bend in some accidents and even the smallest of bent hingepin can have a horrible impact on car handling!
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 11-07-2009, 05:23 AM   #1245
Hi all,
Anyone played with the lipo chassis?
My conections are quite wide, I just did some small alterations to make it work for the stock chassis.
monstercol is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
