Old 10-16-2009, 04:06 PM   #1171
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
you don't use alloy cvds for weight saving matters ...
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 10-16-2009, 11:24 PM   #1172
SammyZ's Avatar
Trader Rating: 138 (100%+)
then why do you use them...
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 10-16-2009, 11:34 PM   #1173
JimmyMac's Avatar
I think it's all point of view. Less rotational weight equals quicker acceleration and deceleration. Plus it's aluminum, so it'll flex and absorb shocks more than the steel ones. That's why they twist.
So in one point of view (his I think), you don't use them to save weight (6.8g total) to make the car lighter. But you can use them to save weight from rotational weight.
How's it's going Martin? Any links to the ETS?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 10-17-2009, 04:00 AM   #1174
Thumbs up ETS
Lucky Martin on ETS, and told us to come so you greetings
manchu is offline   Reply With Quote
Old 10-17-2009, 01:58 PM   #1175
ETS...
http://www.myrcm.ch/de/djka/16102009...ock/index.html
il-gufo is offline   Reply With Quote
Old 10-17-2009, 03:03 PM   #1176
I just use the alloy dogbones as they are blue and take out some shocks and thus smoothen up the ride
just feels a little nicer and looks better
that's about it
I'm just sitting in the hotel room reading what's new on redrc
the race isn'T too bad
traction roll used to be an issue but I solved that.
tomorrow will decide if wether me or alex will take TQ
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-17-2009, 08:38 PM   #1177
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
Martin How did you solve that. I had the same problem using your rubber carpet track (Horsham, PA). Car was great except for the occasional roll. It kept me form being higher qualified in the A Main.
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 10-17-2009, 08:51 PM   #1178
JimmyMac's Avatar
Nice, did you widen the car with wheel shims? That should help some. Or raise your roll centers. Put some shims under your suspension arms. Good job Martin! Have you tried that Orcan body yet? That A5 looks running around there looks sweet! I see Protoform is coming out with one. At least now he can't accuse everyone of copying him. hehe. Good luck out there Martin, and post up your setup when you are done. I could use a good carpet setup.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 10-17-2009, 10:43 PM   #1179
on carpet I always use 0.5mm rollcenter shims, and higher rollcenter traction rolls just as much as that. actually 0mm rollcenter rolls less with regular tires
I doubt this setup will work anywhere else as the carpet is super strange and the Xenon tires are HUGE
if traction roll occures very minor you can just drive smoother and/or put some more shims under the front inner camberlink ballstud
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-17-2009, 11:17 PM   #1180
JimmyMac's Avatar
Sorex SJR and Jaco tires are huge as well. So it might work out. You never know, I race on all kinds of different carpet.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 10-18-2009, 11:21 PM   #1181
JimmyMac's Avatar
Good run Martin. Maybe next time you won't race on an empty stomach..
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 10-18-2009, 11:44 PM   #1182
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
i saw martin car less corner angle if compare with stocker's car....stocker's car can take tighter corner....
i just saw from the video...i might b wrong though....
i saw ronald r running the TC5 shock cap...i guess it's to eliminate the the air trap inside the bladder??
Give the best while u can !
kschu is offline   Reply With Quote
Old 10-19-2009, 10:03 AM   #1183
actually my car had more steering thatn alex'S but I overdid it with the CA when glueing up the tier edge to counter traction roll
wasn'T an issues as there was super muchs teering untill the chassi started to rub on the carpet ... then the ca was too muchbut it didn't wear off as I thought and thus my car started to push slightly
xenon tires are much much much bigger than any sorex tire
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 10-19-2009, 10:30 AM   #1184
pheyhoe's Avatar
R/C Tech Charter Subscriber
Wooohooo Yok is still alive.
I was looking all over and could not see a trace of a BD at Speedtech.
Hope its still going strong.
Ciao. Paul.
[SIZE=1][COLOR=navy]Paul Heyhoe[/COLOR][/SIZE]
pheyhoe is offline   Reply With Quote
Old 10-19-2009, 03:23 PM   #1185
here's the ets setup
I really doubt it will work anywhere else or with any different tire but anyway
ronald used that setup aswell for the 2nd and 3rd main ..
as I built his car for those 2 and he thanked me afterwards as these where the only 2 runs where the car was really good
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
