Old 10-07-2009, 08:10 PM   #1096
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Jiimmy, why u didnt use the steel diff nowadays??
Give the best while u can !
kschu is offline   Reply With Quote
Old 10-08-2009, 12:43 AM   #1097
JimmyMac's Avatar
I think it's too heavy for 17.5/stock. Plus my aluminum diff is not wearing out (Thanks to Martin and suggesting MuchMore Joint Grease, use it every 1 to 2 runs). I have about 30 or so runs on it. I will test it out back to back one weekend. I will run one qualifier with the aluminum diff, and one qualifier with the steel diff. Then note the lap times.
I need to still write down my setup for this past weekend. Been busy not sleeping because of school work and tests. But my car is torn down right now and I'm rebuilding the diff. Let me see if I can do it now.........
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 10-08-2009, 12:51 AM   #1098
kschu's Avatar
i unable to lube my diff every 2 run....d place we run, dont even hv table n chair......
is it u running anti dive? what effect if running anti dive? more steering in entry, mid or exit ?
Old 10-08-2009, 01:15 AM   #1099
JimmyMac's Avatar
Bring a folding table and chair! That's what I use. The table folds up into the same size as a folding chair.
I use kick-up like in this setup. The track has some bumps, so kick-up helps. Also, I notice more steering with kick-up. I generally use kick-up on stock cars.
Anti-dive. Not sure if some will agree, but I think it might help with initial steering because you have less caster. But I feel you loose steering overall. I think it's good for mod cars to help stabilize the car.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 10-08-2009, 01:58 AM   #1100
kschu's Avatar
how bout anti squat? this will gv more on power steering right ?
Old 10-08-2009, 02:46 AM   #1101
JimmyMac's Avatar
I rarely mess with the rear squat. But yeah, anti-squat will give more on-power steering but may give less off-power steering.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 10-08-2009, 02:53 AM   #1102
kschu's Avatar
why u make your rear wider than front?? i saw u use 5.5mm hex...will this gv more initial steering ??
i did try before adding 0.5mm shim in the hex but i dun feel anything....
Old 10-08-2009, 03:04 AM   #1103
JimmyMac's Avatar
I think a wider rear will increase the grip and make it more stable, but also increase steering. I think mostly on-power. My car had pretty good on-power steering in some of the smaller sweeping turns. A lot of drivers noticed this as one of the sections I was faster in. I think you'll notice the difference more when the traction is higher. But I always look for ways to make my car have a lot of on-power steering through certain parts of the track where I can dominate and overtake other cars.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 10-08-2009, 03:09 AM   #1104
kschu's Avatar
do u hv any video of your race??? what shell u using now ? speed6 or ltc-r ?
do u hv MSN ?? add me if you [email protected]
other racers feel free to add me too ....
Old 10-08-2009, 03:24 AM   #1105
JimmyMac's Avatar
Sorry, no MSN. Only Yahoo. I'll try and get someone to record a few laps. I use Speed 6. I like the balanced feel of it. Plus I drive a MazdaSpeed 3.
Oh, you might want to try an R9-R body. It has tons of steering. My friend likes it a lot. I've only used it when I ran a 009 a few months back. But I have not tried one on the BD5. I might have to try one out soon if I am looking for more steering on tight tracks.
Well I'm off to bed!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 10-08-2009, 09:11 AM   #1106
kschu's Avatar
MSN also can add yahoo ...gv me your email...
i add u....
Old 10-09-2009, 12:45 AM   #1107
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
well generally a wider frontend/narrower rearend has more steering in turn-in/mid of the corner
I usually don't look for any extra onpower steering really so I keep prefering the standard suspension mounts
I also use the standard camberlink mounts exclusively really ... feels better to me
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 10-09-2009, 03:12 AM   #1108
kschu's Avatar
im playing in this track...that y i need more U-turn angle n steering.
Old 10-09-2009, 06:15 PM   #1109
JimmyMac's Avatar
Kschu, if I'm ever on Yahoo, it's under [email protected]
I think the difference between Martin and myself is that he's running mod and I'm running stock. I can use full throttle on-power steering in a lot of turns because of the speed of stock motors, where-as Martin cannot because of the high speed of mod motors. He would have to slow down for the turns that I go full throttle on. So different setup tips from both of us.
I think Kschu would be kind of in between. But looking at that track, it's very similar in the technical aspect of what I race when I go to parking lot races. The setup I posted would work great on that track for me. Have you tried a diff up front Kschu? If you are pushing badly with a spool, try a diff. Sometimes they are faster on very technical layouts. Gotta break the old habit of the "standard" setups. Sometimes it slows you down when you think of what everyone else is running. Gotta think "out side the box."
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 10-09-2009, 08:24 PM   #1110
kschu's Avatar
Unhappy
i havent try a diff yet. i tried it before in my old car S400....it's push alot when exiting corner....i might gv it a try tonite in my bd5 if not raining......
i notice stock class need lots of on power steering as the power of the motor is limited. so i guess a car tat have more on power steering, will gv alittle faster laptimes.....
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
