Old 09-16-2009, 12:57 PM   #1021
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
the new topdeck is 2.5mm so quite hard
in combination with the kit chassi the whole car get's quite stiff
the new topdeck is more meant to be used with the P chassi as thatone features a softer carbon fibre which in combination with the new topdeck gives very good flex
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 09-16-2009, 05:01 PM   #1022
JimmyMac's Avatar
So, do you think the new topdeck and standard chassis will be good for rubber/carpet racing? Did you post up a carpet setup before Martin? I can't remember. I'm getting ready for the carpet season next month, so I'm looking at starting setups to point me in the right direction.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 09-16-2009, 06:49 PM   #1023
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
i think it'll be good for carpet racing as it's make the car stiffer...i saw martin is using this combination in his latest build carpet car.......
Give the best while u can !
kschu is offline   Reply With Quote
Old 09-16-2009, 07:29 PM   #1024
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
hi elwyn! got the package! thanks again as always for the great service!
by the way, you've got mail. have a question there for you.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 09-16-2009, 07:40 PM   #1025
ROBORAT's Avatar
Martin: given IFMAR has already sanctioned LiPo for next year's on road worlds, have you started testing already with the new lipo chassis/upper deck combos with rubber asphalt? im would assume other teams are doing the same, for example i've read that the tamiya 416X is already being designed with LiPo in mind. other teams such as xray are due for a new car since the release one every year like clock work so i would also think they would have LiPo in mind when working our new designs.
currently i am still using the standard chassis and upper deck with lipo packs and the car is great. but i would like to think that a purpose built chassis and upper deck for LiPo would provide even better performance. would be great to hear how your own testing is going .... thanks.
Old 09-16-2009, 07:58 PM   #1026
JimmyMac's Avatar
I think Martin said that the new chassis is for stick packs, not lipos. Use the standard chassis for lipos. I would have to agree. One of the new top decks comes with upgraded servo mount and center brace that provides side support for lipo packs. So I would use that. Also, the new stick pack chassis is wider than the standard chassis. I wouldn't say that's a performance upgrade.
I notice how the 416X moves the motor 1mm closer to center. The BD5 already has this. I noticed this when I first got the BD5 and comparing it to my old 416.
I tried 4.0 and lipo a month or two ago.... That's just crazy! Make sure you turn your throttle expo to like -50% or -70%. The torque is just insane!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 09-16-2009, 09:50 PM   #1027
kschu's Avatar
anyone try the 8mm ankerman plate yet???
Old 09-16-2009, 09:55 PM   #1028
JimmyMac's Avatar
Hopefully next weekend I'll be trying it. But then again, my whole car will be different next weekend.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 09-16-2009, 10:02 PM   #1029
kschu's Avatar
changing everything to new options?
new toe block, upperdeck ?
Old 09-17-2009, 12:20 AM   #1030
JimmyMac's Avatar
Hehe, something like that. What I really need to do is one option at a time to see if I note any noticable changes. But the first thing I will surely do is the 3.5mm bulkhead caps. My TA05 is soo much more nicer to drive with shorter camberlinks on our track. I am very happy Yokomo came out with this option! Especially when I go indoors to race.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 09-17-2009, 12:22 AM   #1031
kschu's Avatar
u will change front and rear???
Old 09-17-2009, 12:33 AM   #1032
JimmyMac's Avatar
On my TA05, Im running middle hole on the inner camber link setting. This is about a 4mm shorter link than long setting. But I'm only running this up front. So first, I will only try the 3.5mm caps up front. Then go from there.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 09-17-2009, 12:41 AM   #1033
kschu's Avatar
if running short camberlink for front, will increase steering right ? cos less angle change ?
Old 09-17-2009, 12:53 AM   #1034
JimmyMac's Avatar
I think it let's the front react quicker, and depending on roll center, maybe more camber change. I also ran this setup when I had a 009. It helped a lot in the corners on our track. It was the one thing I hated about the BD5, not having adjustable camber length.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 09-17-2009, 01:28 AM   #1035
kschu's Avatar
oo...but i think this new option make will u love d car more .....
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
