Old 09-07-2009, 09:12 PM   #1006
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
Originally Posted by Elwyn Lee View Post
Got you mail and Pm. Thanks
Hi Elwyn. Got your PM but no email Anyway, i replied as well. Thanks!
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 09-08-2009, 12:35 AM   #1007
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
jimmy, i think this is good news as got 1 company come out with a DCJ for trf416..so i think this might suit our bd5
www.kkeprc.com
Give the best while u can !
kschu is offline   Reply With Quote
Old 09-08-2009, 02:42 AM   #1008
JimmyMac's Avatar
Interesting. I only wonder if they will clear the caster block hole. That's why on the 009, the caster block hole is very large. It has to accommodate the movement of the axle joint. If the hole is too small, then the joint will hit. Therefore, it will not work. But if it fits the 416 and works with the stock caster blocks, then it might work with the BD5. How do you get these?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 09-08-2009, 03:14 AM   #1009
kschu's Avatar
my fren in hk send to me these pictures....
they selling around usd45/pair....
is that mean our bd5 can use it ???
Old 09-08-2009, 03:16 AM   #1010
JimmyMac's Avatar
If I had a way to get some, I would test them out in my BD5. If they did not work, I can always use them in my TA05.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 09-08-2009, 03:25 AM   #1011
kschu's Avatar
u can buy here
www.egrracing.com
Old 09-08-2009, 03:56 AM   #1012
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
double joint cvds are definately not necessary
they just create understeer ... that's it
rather spend your money on hard suspension parts as those actually increase the cars performance
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 09-08-2009, 03:34 PM   #1013
Elwyn Lee's Avatar
Hi Gerry,
U got an email.
Cheers
Elwyn
Hobby Haven Sdn Bhd
Tel / Fax : +603-7499 4191
Email: [email protected]
http://www.hobyhaven.com.my - http://www.hobby-haven.blogspot.com - http://www.teamyokomo.blogspot.com
Elwyn Lee is offline   Reply With Quote
Old 09-10-2009, 06:47 PM   #1014
kschu's Avatar
Bump up for this thread...
Old 09-16-2009, 06:38 AM   #1015
Elwyn Lee's Avatar
New!!! BD5 Option Parts From Yokomo Japan
BD-002P Main Chassis for BD5 ( Straight Pack)
BD-003CS Upper Deck Set for BD5 Square Type Battery
BD-201R8 Center Link For BD5 (8mm Type)
BD-301FF2 Aluminum Front Suspension Arm Mount for BD5 (Front
42mm)
BD-301FR2 Aluminum Front Suspension Arm Mount for BD5 (Rear 42mm)
BD-301RF1 Aluminum Rear Suspension Arm Mount for BD5 (Front 41.3mm)
BD-302FL1 Front Bulkhead Cap (Left) 3.5mm Wide I Arm Pivot
BD-302FR1 Front Bulkhead Cap (Right) 3.5mm Wide I Arm Pivot
BD-302RL1 Rear Bulkhead Cap (Left) 3.5mm Wide I Arm Pivot
BD-302RR1 Rear Bulkhead Cap (Right) 3.5mm Wide I Arm Pivot
Source: H
Hobby Haven Sdn Bhd
Old 09-16-2009, 08:07 AM   #1016
SammyZ's Avatar
Trader Rating: 138 (100%+)
how do you strap in the Lipo with that chassis plate?
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 09-16-2009, 08:17 AM   #1017
it's meant for stickpack style batteries and therefore doesn't use any battery tape whatsoever but a battery strap with additional plastic mounts
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-16-2009, 08:17 AM   #1018
Elwyn Lee's Avatar
That Chassis is design for Straight pack Sub C battery, not design for Lipo.
You need to do some modification to fit the Lipo into this chassis.
For Lipo battery, is recommended to use the original chassis with the new upper deck.
Hobby Haven Sdn Bhd
Old 09-16-2009, 08:47 AM   #1019
standard chassi, standard topdeck for lipo
or p-chassi with new topdeck .... but then you need to use a lipo with no battery placement thingis
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 09-16-2009, 10:37 AM   #1020
Elwyn Lee's Avatar
Martin, is the combination of the standard chassis and new top deck a good combo?
Hobby Haven Sdn Bhd
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
