Old 09-03-2009, 06:32 PM   #976
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by JimmyMac View Post
Yeah, that's what I do on a local parking lot track. But I do not run my BD5 on it. That's what I save my TA05 for. No worry about tearing it up.
seem like u have different car for different track ??
Give the best while u can !
kschu is offline   Reply With Quote
Old 09-03-2009, 06:34 PM   #977
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
JimmyMac: thanks for the link. as for the shocks, personally i run the black bladder and single o-ring set up on mine as well minus the foam insert. i find this smoothens out the car as it is less twitchy - but twitchy isnt always a bad thing so really depends what you are looking for. in modified i prefer the car to be smoother so it's easier to drive. this is actually somthing ive been playing around with my other cars in the past and is generally what i've observed. i suppose its because maybe having the inserts in speeds up the rebound.... my assumption is it affects rebound speed rather than the amount of rebound (which you control through bleeding). but then what do i know haha ... let me know what you experience from your end.
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 09-03-2009, 06:46 PM   #978
JimmyMac's Avatar
Thanks for the input guys.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 09-04-2009, 05:19 AM   #979
Anyone here tried the TiR spool??
Mine doesnt seem to fit
The pin on the drive shaft is longer than the diameter of the sleeve. If i take off the sleeve you can just put the driveshafts into the derlin outdrive, but theres no way at all the sleeve is going to slide on. Just using the sleeve and a drive shaft in my hands you cant even get it on at obscure angels, its not that its a tight fit... its just impossible to get it passed the pin.
monstercol is offline   Reply With Quote
Old 09-04-2009, 09:34 AM   #980
JimmyMac's Avatar
Use Tamiya 46mm bones.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 09-04-2009, 11:18 AM   #981
Thanks for the advise jimmy, but thatís not going to be acceptable for me. Iíll wait to see what TiR have to say otherwise they can have it back.
Old 09-04-2009, 11:23 AM   #982
JimmyMac's Avatar
Did you get the BD spool or BD5 spool? Send it my way, I'll gladly take them.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 09-04-2009, 11:54 AM   #983
kschu's Avatar
jimmy, u mean bd5 can use tamiya 46mm bone? how bout tamiya axle? same ??
Old 09-04-2009, 05:45 PM   #984
JimmyMac's Avatar
Yes, you can interchange Tamiya 416 axles and bones with the Yokomo axles and bones.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 09-04-2009, 05:54 PM   #985
kschu's Avatar
so d whole pc tamiya UJ can put into bd5 right ??
Old 09-04-2009, 07:58 PM   #986
JimmyMac's Avatar
Uhhhh, what you say???!! Haha. The complete 416 axle and bone will fit in a BD5. Or.... You can interchange parts. Bones, axles, or pin/joint set is all interchangable. Why you would want to, I don't know. But for future reference, it all fits. However, I have not tried a Yokomo wheel hex on a Tamiya axle. But the complete 416 axle set and Tamiya wheel hex fits in the Yokomo BD5 steering block.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 09-04-2009, 09:43 PM   #987
kschu's Avatar
sori for my bad english tat make u confuse....
thanks for your infos....
Old 09-05-2009, 09:15 PM   #988
JimmyMac's Avatar
Okay, I have about 16 to 18 runs on my new aluminum rear diff. And I would like to thank Martin again for suggesting that I use MuchMore Joint Grease. So far they have been wearing pretty good. They have not notched yet. Only the anodizing has worn off in the slots. This diff has been run on a flowing euro/asian style track in 17.5, and one carpet track with rubber tires. I have not run it in a technical parking lot. I'm scared to do so. But I'll give it a shot one day. Here are some pics since yall love pics. So far so good.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 09-05-2009, 09:20 PM   #989
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Jimmy there you go with those fuzzy pics again put that 1.2 megapixel camera phone down
Rod
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 09-05-2009, 09:53 PM   #990
SammyZ's Avatar
Trader Rating: 138 (100%+)
thats impressive you got 20 runs on the diff without any notch, whats not impressive is the lack of a CVD blade in a late model car
Not bad though, should be quite easy to file it and stuff a bomber blade in.
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
