Old 08-13-2009, 08:47 PM   #916
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
do u guy notice martin's bd5 shock tower is lower than standard ??
New Yokomo TC, the BD-5-img_4465.jpg   New Yokomo TC, the BD-5-img_4463.jpg   New Yokomo TC, the BD-5-img_4462.jpg
Give the best while u can !
kschu is offline   Reply With Quote
Old 08-13-2009, 08:58 PM   #917
JimmyMac's Avatar
Looks like he just shaved off the top brace. Maybe allow more flex in the shock tower.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 08-14-2009, 05:06 AM   #918
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
I want Martin's top deck!
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 08-14-2009, 05:16 AM   #919
yokemad's Avatar
Check this out !
This will flex dudes LOL
If you want that top deck why don't you buy trf416?
yokemad is offline   Reply With Quote
Old 08-14-2009, 03:51 PM   #920
JimmyMac's Avatar
What does a top deck have to do with buying a 416????
I saw that chassis a few months back. I don't like it much. I just need a different top deck for low bite asphalt. Kinda like how the top deck changed from the 416 to the 416WE. I'm just gonna buy another one cut it for more flex.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 08-14-2009, 08:53 PM   #921
ROBORAT's Avatar
Send a message via Yahoo to ROBORAT
Elwyn: hi there! you've got mail!
[YOKOMO BD7][REEDY RACING][TEAM ORION]
[Sanwa][LRP][Protoform]
http://www.hobbyhaven.com.my/
ROBORAT is offline   Reply With Quote
Old 08-14-2009, 10:48 PM   #922
Elwyn Lee's Avatar
Got your email.
Hobby Haven Sdn Bhd
Tel / Fax : +603-7499 4191
Email: [email protected]
http://www.hobyhaven.com.my - http://www.hobby-haven.blogspot.com - http://www.teamyokomo.blogspot.com
Elwyn Lee is offline   Reply With Quote
Old 08-15-2009, 06:22 AM   #923
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
no, standard shocktowers
exactly, but all I did it for was to make them look better *G* I did not like the chunky look of the standard items *G*
the car doesn't need a different topdeck for low bite asphalt as the standard topdeck of the bd5 is supersoft already, cutting it won't help a lot, what you can try is leave out the screws in row 2, 4 and 5 counting from the front
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 08-15-2009, 07:14 PM   #924
JimmyMac's Avatar
Hey Martin, Thank You for the tip on using the MuchMore Joint Grease! It may be a little premature saying this, but so far, no wear on my aluminum out drives. But I only have 4 runs on them so far. I'll keep a long term report on the wear of them with the MM grease. I think part of this is due to the new layout. They torn down the whole outdoor track and redid everything. We now have an Asian/European style track. Very awesome I think for us. So the track was flowing. Not like the typical parking lot ON/OFF throttle driving. It was more smooth style, which I like. Anyways, only thing I did not like was the rocks/dirt collecting on there. Gotta clean them out almost every run.
Thanks for the tip on removing the screws. I keep forgetting to do that. I'm just scared of tweak if I do. Some of the parking lot tracks can be brutal.
Anyways, I may try one of your setups for our new track layout. It may be a good starting point. My car pushed today and the Tekin esc lacks good brakes for the hair pin. I think I need a little midcorner steering. Do you think adding 1mm to the steering rack will help out some?
Kschu, I didn't get to try raising the rear diff today. Not enough time between rounds. I'll try it next weekend. But I did set fast lap and won today. Not too bad I guess.
I started rewiring my esc last night. But didn't finish. Look at my huge fan! I fried two motors in one day last month. I ain't gonna do it again!!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 08-15-2009, 07:34 PM   #925
Timmie's Avatar
Dang Jimmy, you have so much grease on them you wouldn't be able to see any wear!:sne aky::
Gratz on your win!
:: Serpent America ::Desoto Racing :: Track Star Racer Services ::Skyrocket Racing::TOP::
Timmie is offline   Reply With Quote
Old 08-15-2009, 11:20 PM   #926
kschu's Avatar
jimmy, ur wiring look very neat!!
btw, how you fried your motor ?? too hot??
your car full with graphite!! and options too!
do u guys notice the crossjoint and the PIN of the CVD wear out quite fast??
Old 08-16-2009, 12:21 AM   #927
JimmyMac's Avatar
Thank you! I'm still working on the wiring. No where as neat as Martin's car!
Fried motor? Well, testing new esc software. So gearing and timing was all guessing. Plus Roar went from 5 to 6 minute heats/mains. So that adds more heat to these damn 17.5 stock motors. And air temp from 90F (32C) to 100F (38C). It was a bad funny day. haha.
I don't really notice my cross joints wearing out. But I have been oiling them after every other run with MuchMore Joint Lube. I'll usually spray them down and blow them off during the week. Then lube them up with 4 small drops of MM Lube for each axle. I'm staying on top of the maintenance for this car like I did on my 416.
Well I just threw the steel diff back into the car. Not gonna risk the aluminum diff in a parking lot track. I pulled the screws out of the top deck like Martin suggested. Now I gotta pull the roll center shims out from under the blocks and go down on all my spring rates. Then I'm off to bed!
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 08-16-2009, 08:02 AM   #928
ROBORAT's Avatar
sorry i know this is a lame question but what's the internal drive ratio of the bd5? cant seem to find it written down in the manual... thanks in advance!
elwyn: thanks! im excited to get the stuff!
Old 08-16-2009, 08:22 AM   #929
kschu's Avatar
2.0
Old 08-16-2009, 08:56 AM   #930
ROBORAT's Avatar
kschu: thanks!
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
