New Yokomo TC, the BD-5 >
Old 07-28-2009, 05:18 PM
  #826
JimmyMac's Avatar
No need to apologize. I would of dug up the page. But I was on my phone at school when I answered the question.
JimmyMac is offline
Old 07-28-2009, 06:08 PM
  #827
fpart's Avatar
Trader Rating: 40 (100%+)
I don't know if this helps but I am running a trinity 5000mah 40C Lipo in my BD-5 with Banana's and it fits. I just had to make a right angle bullet for the negative side to fit under the top deck. Works great. TQ'ed and won sedan at Blue Diamond with it.
fpart is offline
Old 07-28-2009, 10:36 PM
  #828
ROBORAT's Avatar
yup, was actually thinking along the same lines of maybe a battery bar and bullet connector to make that "right angle" connection ... if needed. offhand, i actually like moving lipo packs out to the edge of the chassis. this makes balancing out the car left to right much easier with less use of lead weights on the pack itself. the IP based packs by trinity have the little humps under the pack which slot them into the chassis slots (which can easily be ground down with a dremel anyway) .... the reedy's dont which makes them easier to position around the chassis.
thanks for the inputs ... these are all helpful indeed. there are definitely some options to make the packs work.
ROBORAT is offline
Old 07-29-2009, 07:30 PM
  #829
Does Yokomo released spool for bd5? Id yes, what is the part number, where I can order? thanks
ioxqq is offline
Old 07-29-2009, 07:47 PM
  #830
JimmyMac's Avatar
Spool has been out for awhile. Here is the link.
http://www.teamyokomo.com/jpn/partsl..._bd_501s5.html
Can find it at any Hong Kong shop, Elwyn on here has some at his shop (just shoot him a PM), or Japan shops carry them as well.
JimmyMac is offline
Old 07-29-2009, 11:00 PM
  #831
Elwyn Lee's Avatar
ioxqq,
The part no for the BD5 spool is BD-501S5, and I have some In stock.
Please check your inbox, you got PM.
And, Thanks JimmyMac.
Cheers
Elwyn
Elwyn Lee is offline
Old 07-30-2009, 03:53 AM
  #832
fpart's Avatar
Elwyn
Did you get any of the graphite parts in yet?? Like arms, hubs?
fpart is offline
Old 07-30-2009, 09:01 AM
  #833
RC MARKET's Avatar
Graphite & wing mount parts arrived !
Attached Thumbnails New Yokomo TC, the BD-5-bd_008_01.jpg   New Yokomo TC, the BD-5-yo-bd-008fg.jpg   New Yokomo TC, the BD-5-yo-bd-008rg1.jpg   New Yokomo TC, the BD-5-yo-bd-413g.jpg   New Yokomo TC, the BD-5-yo-bd-110.jpg
RC MARKET is offline
Old 07-30-2009, 06:19 PM
  #834
JimmyMac's Avatar
I want those wing mounts!
JimmyMac is offline
Old 07-30-2009, 08:33 PM
  #835
kschu's Avatar
Trader Rating: 16 (100%+)
jimmy, do those wing mount really useful ??
i wonder what ronald volker use for his ball stud till the ball cup can be mount lower...
kschu is offline
Old 07-30-2009, 08:46 PM
  #836
JimmyMac's Avatar
Aerodynamically? I don't know about the wing mounts, but I want them to strengthen the wing down a little better. Too many times if someone lifts the car up by the wing, it will bend or deform the wing. I was hoping this would keep it from bending at the screw holes.
As for Ronalds ball studs/cups, I noticed that too. Not sure which ones he is using. I'm using Photon ball studs/cups on mine so that I can also have more adjustment on my links. They sit 1mm lower than stock. So to be at stock height, I need 1mm shim under them.
JimmyMac is offline
Old 07-30-2009, 08:49 PM
  #837
kschu's Avatar
with 1mm lower, then can put extra shim w/o having d ball cup hitting d rim....
but from what i see from ronald car, it's lower more than 2mm or mebi 3mm...
kschu is offline
Old 07-30-2009, 10:09 PM
  #838
Elwyn Lee's Avatar
Yokomo shipment have arrived. All full range of spare parts and graphite parts for Yokomo BD5 is in stock. And others Yokomo products.
We have a new shipping method than EMS with very cheaper rate and faster transit time below 2Kg weight. (excluding car kit and bodyshell)
Drop me a PM or contact me at [email protected]
Old 07-30-2009, 10:14 PM
  #839
Elwyn Lee's Avatar
Elwyn
fpart,
The graphite parts for Yokomo BD5 is in stock now.
Old 07-31-2009, 01:51 AM
  #840
JimmyMac's Avatar
Elwyn, set me aside a set of graphite parts. I will PM you later. On my way to a warmup race this weekend. Thanks.
JimmyMac is offline
