Old 06-19-2009, 09:32 AM   #631
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
I usually don't use any weight as my car is at 1403g without any lead added
I just used the 5g weight for safety and as I did not have a black one with me I put it somewhere where you could not see it *G*
I hate things that are neither black nor blue *G*
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 06-19-2009, 03:32 PM   #632
ok, thank you very much
manchu is offline   Reply With Quote
Old 06-19-2009, 08:35 PM   #633
finally got those damn stripped screws out!!!
since ive taken apart my entire rear and front end, including suspension, what size springs are standard. short or long?
and can tamiya short springs be used?
also, im not sure if i have the one-way or spool front diff(havent been in this hobby long enough...). how can i tell?
thanks,
total3d is offline   Reply With Quote
Old 06-19-2009, 10:06 PM   #634
JimmyMac's Avatar
Hey Martin, when using the outer hole on the steering blocks, did you have to switch to longer tie rods for the steering link? I think kit ones are 27mm long. But they seem too short when using the outer hole. Seems the ball cups flex too much. Your thoughts on this?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 06-19-2009, 10:22 PM   #635
On my car, I use BX cups as I think they look nicer
but I just had a look at my teammates car and he's using the standard ballcups without any problems.
Seems fine so I wouldn't bother too much really.
We are on our way to a national qualification race
6am and the highway is nearly empty, very relaxing lol
track will be tight and (hopefully) rather high traction
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 06-19-2009, 10:47 PM   #636
JimmyMac's Avatar
Sounds good. Thanks. I'll have to try that setting tomorrow. Suppose to be 100F. Maybe I'll fry some motors!
Best of luck to ya! Let us know your setup for a tight track. I wouldn't mind trying it at a local track. Thanks.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 06-21-2009, 02:31 PM   #637
Jochim_18's Avatar
I'm assuming just looking at the BD5 the suspension will be direct fit with BD? Like CVD, C-hub, arms, steering knuckles etc....
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 06-21-2009, 02:54 PM   #638
JimmyMac's Avatar
I can't remember off the top of my head, but you would need to change over the whole suspension, and even then, I'm not sure if it would work. It's been years since I had a regular BD. The new BD5 uses thicker inner suspension pins compared to the old suspension if I remember correctly. So mating the new suspension to the old car will depend if you can fit the new suspension pins to the old suspension blocks. Or, not sure if the holes line up to run the new suspension blocks on the old BD. I don't remember. But I do know the axles are different from the BD5 to the BD.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 06-21-2009, 03:39 PM   #639
Hi,
The parts stated are NOT compatible,
the belts, the center pulley and main direct gear adapter will fit
Ralf is offline   Reply With Quote
Old 06-21-2009, 04:04 PM   #640
Jochim_18's Avatar
I'll get a set of each suspension parts and try it out. BD still a very competitve car.
Old 06-21-2009, 04:11 PM   #641
Jochim18,
the suspension parts will NOT fit, I have a BD and it won't work.
Old 06-21-2009, 04:28 PM   #642
Jochim_18's Avatar
Have you tried it?
Old 06-21-2009, 05:31 PM   #643
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
I agree, BD is still very good car. Why would you want to change the suspension parts?
Shopkeeper is offline   Reply With Quote
Old 06-21-2009, 05:44 PM   #644
hey all,
any1 know if the titanium screw kits are universal?
i saw a set for sale, but it says its for the BD. im guessing it might fit the bd5...
Old 06-21-2009, 06:03 PM   #645
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by total3d View Post
hey all,
titanium screw kits are universal..but some size might cannot use on BD5...
Give the best while u can !
kschu is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
