Old 06-16-2009, 09:47 AM   #616
niznai's Avatar
Originally Posted by snoopyrc View Post
I think all of the Drift package Yokomo drive train parts fit the old SSG. You should be able to keep the old girl running for a while.
Yeah, it's not the transmission that's the problem, but the suspension arms. The transmission is still very strong. Just to give an example I have the aluminium diff joints bought a while ago to replace the original plastic ones that came with the kit, but the plastic ones just don't wear! As for the gears, they're as good as new after two full seasons of racing.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 06-16-2009, 09:52 AM   #617
Originally Posted by niznai View Post
Thank you guys.
Are the suspension hinge pins still 2.5 inner and 2mm outer?
does anyone know where I could find a BD5 manual in pdf?
Cheers
http://www.teamyokomo.com/jpn/downlo...bd5_manual.pdf
Ralf is offline   Reply With Quote
Old 06-16-2009, 09:12 PM   #618
snoopyrc's Avatar
Im seeing the lower suspension arms for the Yokomo drfit package as SD-008. Thats the same part number for the SD-SSG. If you cant get them then Im screwed too cause Im running the same car for VTA.
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 06-16-2009, 09:29 PM   #619
niznai's Avatar
There are two other options. SD-008H and SD 008HG. These are still available and are the replacement parts Yokomo has brought out soon after releasing the SD. They are not however identical to the SD-008. SD-SSG cars had identical arms all around whereas the H and HG parts are different front to rear. The reason i wanted the SD-008 is becasue it just means you only have to have one arm and that covers you all around. SD-008H and 008HG come in pack with one front and one rear arm, so that covers you too but as soon as you replace one of them you have to buy another pack to have another spare for the arm you just replaced.
Our track has a number of hairpins after long straights so that means I am more likely to break a front arm when entering aggresively in these hairpins (and this happenned to me quite a few times) and the inner front wheel clips the barrier (which is heavily loaded with lead to make it impossibile to move it in crashes). This means I need more front arm spares than rears, but I have to buy twice the number of packs to have the same number of spares.
Team Greasy Weasel
Old 06-16-2009, 09:30 PM   #620
JimmyMac's Avatar
What about these?
http://www.speedtechrc.com/store/ebp...nid=237&id=941
or these?
https://www.ssl-stormerhobbies.com/c...=ns&pn=YSD008G
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 06-16-2009, 09:37 PM   #621
niznai's Avatar
That's it! Just one pair though, dang! Got four form Stormer though.
Team Greasy Weasel
Old 06-16-2009, 09:47 PM   #622
JimmyMac's Avatar
Or this...
http://rcmarket.com.hk/product_info....oducts_id=1300
Just takes a little looking.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 06-16-2009, 11:00 PM   #623
snoopyrc's Avatar
I completely understand. I like the fact that they are the same identical arm for all four corners. I thought it was very innovative. When you order a set or pair you are still ok even if you keep breaking the right front arm. I still love this old car. But I tend to have a knack for buying TC's that you cant get parts for. (S400)
Old 06-16-2009, 11:16 PM   #624
JimmyMac's Avatar
I still wish I had my SD with the RaySpeed chassis. I miss that thing. My 04 Stock Region 3 winning car.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 06-17-2009, 01:13 AM   #625
Originally Posted by Ralf View Post
2mm and 1.5mm Metric
Thanks!
just have to find a way of getting the stripped screws out...
dont have a small enough 'easy-out' drill bit
total3d is offline   Reply With Quote
Old 06-17-2009, 01:50 AM   #626
niznai's Avatar
Originally Posted by JimmyMac View Post
Or this...
Double dang!
I searched yesterday all day on google and ebay (which is sometimes better than google at finding things) and simply didn't find any shops with SD-008 at all whatsoever, otherwise I wouldn't have panicked.
If you think that's difficult, try racing a Kawada Sigma2 every week for a change.
Team Greasy Weasel
Old 06-17-2009, 08:25 AM   #627
SammyZ's Avatar
Trader Rating: 138 (100%+)
wow jimmy! that damper stand is trick!
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 06-17-2009, 11:02 AM   #628
JimmyMac's Avatar
Hey.... I didn't quote/say anything about buying cars that are hard to get parts for!
Damper stand, you mean the Tamiya one? I use it as my tool holder. My two favorite companies are Tamiya and Yokomo! I always have at least one car from each company! I think for that race back in 2004, I had to decide to either run the original 415 or my RaySpeed SD. The SD proved to be quicker on the layout. So I used it for that race. Now I have a choice between my Yok BD5, and one of my Tamiya's (sold the 416 ) but I still have my 415MRE, Evo IV, and TA05. I just got the BD5, and so far I'm liking it. Reminds me a lot of when I had my 416. The BD5 does not have as many adjustments as the 416, but it has the core adjustments that are needed for rubber tire racing. It's a keeper.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 06-17-2009, 07:58 PM   #629
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Checkout the CREST Chassis for BD5.
Here
Give the best while u can !
kschu is offline   Reply With Quote
Old 06-18-2009, 05:14 AM   #630
Default 5-cell balanced chassis
Hi Martin, you could say, as has the 5-cell balanced chassis, the weight being used, and seen a picture and it takes 5 grams below Piņon engine thanks
manchu is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
