Old 06-14-2009, 07:03 AM   #586
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by snoopyrc View Post
Hey Serdar! How have you been? Are you running a BD-5? The price has been keeping me away from it. I actually am really happy with my serpent, but parts aquisition has been a bear.
im serpent owner before....but the lack of parts make me turn my way into Yokomo....yokomo kits might be a lil expensive but the parts is quite cheap....
Give the best while u can !
kschu is offline   Reply With Quote
Old 06-14-2009, 07:07 AM   #587
kschu's Avatar
Martin, how to make the bd5 steering super sensitive without losing the rear traction???
i notice those marc, hara driving..they only turn alittle bit their steering when going into corner.....how they do tat ?? softer oil ? softer spring ? droop ??
Old 06-14-2009, 07:50 AM   #588
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
I turn on my steering wheel very little too
it's partially driving style I guess along with a rather aggressive setup
what usually improves things really much is to remove excessive slop in the ballcups / the steering system
as far as setup goes I already posted some setups and you might notice they don't differ too much
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 06-14-2009, 08:28 AM   #589
kschu's Avatar
how u remove the slop in the ball cup ???
i has a question here...how u measure your car droop ?
u put your car on 10mm droop block and then measure front the C-Hub pin ?? as im not sure how to make d droop to 9mm, 9.5mm, 10.5mm ??
thanks
Old 06-14-2009, 09:02 AM   #590
niznai's Avatar
use diff lube on the backside of the diff plate
this will cause a stickslip effect and keep the plate from moving under preasure
So should I understand the plates are indeed a re-used part from previous cars rather than BD specific?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 06-14-2009, 09:03 AM   #591
I set the droop on fine hudy blocks (6.0 front, 5.2 rear)
which results in a hingepin height of 9.5/8.7
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 06-14-2009, 09:13 AM   #592
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 06-14-2009, 05:56 PM   #593
kschu's Avatar
thanks martin...will try it out tonight....
what spring do u recommend me to use on technical track with some small n tight corner n medium grip surface ??
will the standard spring Pink and Blue good enough or i need to use HPI Silver & Gold spring or others spring????
i did notice you remove the steering post for certain track setup..your purpose is to give more flex for the front ??
another question is what is the purpose of the low and high Diff placing ??
thanks
Old 06-14-2009, 06:16 PM   #594
kschu's Avatar
Originally Posted by Shopkeeper View Post
Yes, use some good anti-wear grease on the bones and it will last a bit longer. If you are not running mod, the old plastic diff is very good and last's along time also.
Let us know what you think of the new bd5 when you get it running.
my first impression when driving BD5, it's has better steering than my previous car S400.....but im still trying to learn more setup for this car...
Old 06-14-2009, 06:35 PM   #595
makes 2 of us...
i had a decent run on carpet the other day. i still used the standard rayspeed white springs, and just adjusted the droop. front end felt great, and turned in well, but the rear seemed to slide/drift too much into turns.
not sure if this was because im running 40s foams...
day was cut short due to my servo teeth stripping(i should get a good servo!). otherwise it was pretty damn good to drive.
total3d is offline   Reply With Quote
Old 06-14-2009, 09:27 PM   #596
JimmyMac's Avatar
Raced the car for the first time today. Over all it did pretty good. The new spool held up with no problems or wear. The rear diff seemed to hold up. I do see some signs of wear on the right side. But it is still super smooth. I think the car is pretty good. Only gripe is the slop in the steering rack. I had to use some of my small Tamiya shims to take out a lot of it. Car has TONS of room for electronics. Especially if you use a short servo. I could install a jacuzzi between the rx and esc if I wanted to. Car is also pretty balance and drives good. Next weekend I'll put it through it's pace with some tough competition on a fast track. Plus I can see how laps times were vs the 009 I sold.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 06-14-2009, 11:52 PM   #597
drperry's Avatar
Send a message via AIM to drperry Send a message via MSN to drperry Send a message via Yahoo to drperry
How do y'all figure it'll do for ashpalt racing? Durability wise, when it comes to flying rocks inside the body, lol, are the diffs well covered?
On my MR4TC, you can barely even see the bearings for the diff through the diff cases...
RC18MT - Tekin FX/Stock motor
Yokomo MR-4TC SD CM Novak GTB/LRP X-11 13.5 brushless
E-Jato - Diff still unloads in corners, with 100k weight oil in it!
drperry is offline   Reply With Quote
Old 06-14-2009, 11:54 PM   #598
kschu's Avatar
the bd5 diff is well covered by the outdrive. you cant see anything......
Old 06-15-2009, 12:30 AM   #599
thanks
I always start with yokomo pink/blue (kit springs)
And only if it does not feel 100% I try hpi silber/blue
If with that the frontend feels to soft, I use hpi pink/blue
But that is a rare occasion
I never use the steering post. With it the car is way too hard
Low diff placing is in the correct place!
For me that is fixed and I don't mess around with that
Note: front/rear
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Old 06-15-2009, 12:40 AM   #600
drperry's Avatar
Good to hear!
I can keep my SD for the 13.5, and get the BD5 for silver can racing
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
