Old 06-08-2009, 01:52 AM   #556
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by B18C Turbo View Post
show me the team bomber blade
team bomber blade
Give the best while u can !
kschu is offline   Reply With Quote
Old 06-08-2009, 11:33 AM   #557
JasonC's Avatar
R/C Tech Charter Subscriber
Trader Rating: 120 (100%+)
Originally Posted by YLLIB View Post
Hello everyone, SpeedWorld Raceway & Hobbies is in the process commuicating with Yokomo Japan right now becoming a USA importer. I hope to have everything finalized in the next 3 weeks if possible to move fowards.
Thank for your support
Billy Bowerman Jr.
Hey Billy any updates
#60 of the Original 100
If your not part of the solution
Your part of the problem !
JasonC is offline   Reply With Quote
Old 06-09-2009, 09:09 AM   #558
kschu's Avatar
bd5 ball diff bearing is 3/32 ???
Old 06-09-2009, 01:02 PM   #559
Originally Posted by kschu View Post
I remember these blades were released for Team Bomber spool for the BD.
It is a good news if they fit the BD5 diff.
Ralf is offline   Reply With Quote
Old 06-09-2009, 03:58 PM   #560
YLLIB's Avatar
Helo everyone. Just received a e-mail from Yokomo today and they are going over the prices and shipping to give us and will get back with me middle of next week or sooner.
Thanks Billy
YLLIB is offline   Reply With Quote
Old 06-09-2009, 06:52 PM   #561
kschu's Avatar
i think need to file abit the diff outdrive inorder for the blade to fit in...
use the bd5 diff till it's wear out then only file it...
Old 06-10-2009, 08:15 AM   #562
Toughbeard's Avatar
yes the drive pin fits flush on the out drives. the original outdrives need to be filed.
Serdar Aytemiz
Racing since the 20th century
Toughbeard is offline   Reply With Quote
Old 06-10-2009, 08:51 AM   #563
Originally Posted by JimmyMac View Post
I've had 009 and 416..... maybe I'll let ya know next weekend.
A-ha!
Isaac is offline   Reply With Quote
Old 06-10-2009, 03:15 PM   #564
I also remember they are brittle,...
I prefer XRay blades personally.
Old 06-10-2009, 06:12 PM   #565
JimmyMac's Avatar
Originally Posted by Isaac View Post
A-ha!
LOL ssshhhhhhhhhhhh
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 06-10-2009, 10:50 PM   #566
hey all,
ive got a indoor carpet race comming up soon, and i just wanted to know what would be a good setup(mainly camber+suspension) for the track. and also what would be a decent gear ratio.
the track is pretty small, and quite tight with alot of quick direction changes(2 right-lefts, and 1 left-right), and a small straight.
i have a CC brushless 5700kv, running off 2s 500mah lipo. and im using kawahara 30sh foams. the springs are rayspeed white.
ive already balanced the chassis.
thanks,
total3d is offline   Reply With Quote
Old 06-11-2009, 12:04 AM   #567
niznai's Avatar
I have aquestion about the aluminium diff outdrives. I am using these and have found that the diff plates have a little bit of play, is this the case with everybody? These diff plates are used on the SD too and they fit perfectly without any play on the plastic diff joints. Part number for plates is ZS506, diff outdrives BD500A.
Thank you for your help.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 06-11-2009, 07:21 AM   #568
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
use diff lube on the backside of the diff plate
this will cause a stickslip effect and keep the plate from moving under preasure
indoor setup below
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 06-11-2009, 07:14 PM   #569
thanks martin
i also have a small problem with braking(asphault, old used rubber tyres) where the rear spins around under braking.
not sure if i need to adjust something on the car, my ESC, or its just the grip levels.
my esc braking is set to 100% i think...
ive heard that a one-way front can solve this.
Old 06-11-2009, 07:58 PM   #570
kschu's Avatar
Originally Posted by total3d View Post
thanks martin
one way front cant solve your problem as you cannot use brake at all....
i think your brake is set too high....try to reduce some in your esc or your gun.....
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
