Old 06-06-2009, 12:37 PM   #541
RC MARKET's Avatar
can use teambomber or tech blade in bd-5
RC MARKET is offline   Reply With Quote
Old 06-06-2009, 10:48 PM   #542
JimmyMac's Avatar
Originally Posted by B18C Turbo View Post
Thank Jimmymac, and thanks kschu. It looks like there is plenty of space to file the outdrive and retro fit an Xray CVD blade.
That team drivers car looks slick, Ti screws and Alum rear CVD's. All he needs are the alum suspension parts and the Team bomber belts!
Why not just run them. Then when they wear out, you can then dremel them down to fit your XRay blades. This way, you can see how bad they wear/if they wear. Also, you have to measure how thick the pins are, and how big the ball end is. I posted a pic of a Tamiya 416 axle ball/pin end vs an XRay. XRay was much larger. So the blades would not work properly on a Tamiya. May be true with a Yokomo as well.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 06-06-2009, 11:05 PM   #543
SammyZ's Avatar
Trader Rating: 138 (100%+)
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 06-07-2009, 01:15 AM   #544
Default diff rear
Hello I made with blades and top that fit very well and solved the problem, we need to iron out the rear diff
manchu is offline   Reply With Quote
Old 06-07-2009, 01:23 AM   #545
Default diff rear
Old 06-07-2009, 03:16 AM   #546
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
i also would like to see how u do it for the rear diff too....i also worry if the rear diff will wear out fast as i use alots of braking....
i saw team bomber did produce a front solid spool for BD which have a blade for it....i think this will last longer than d current alum bd5 spool...
Give the best while u can !
kschu is offline   Reply With Quote
Old 06-07-2009, 04:08 AM   #547
Kajman's Avatar
Has anyone had chance to compare himself bd5 to 008 or 009 and 416? I am thinking which way to go... Always have been yokomo fan...
XXX-S G+, XXX-S, TRF 415MS, SCTE 2.0, SCTE TLD, Kyosho DRX VE
Kajman is offline   Reply With Quote
Old 06-07-2009, 05:24 AM   #548
RC MARKET's Avatar
yes ,
i'm not have photo now,
tomorrow update in our web site !
Old 06-07-2009, 08:19 AM   #549
JimmyMac's Avatar
Why not just use a TC5R spool?
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 06-07-2009, 08:21 AM   #550
JimmyMac's Avatar
I've had 009 and 416..... maybe I'll let ya know next weekend.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
Old 06-07-2009, 08:56 AM   #551
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
Yes, run them till they have alittle wear then mill them for blades. I have done this and it works for the BD. I have used the corally blade as it is the best fitting blade on the BD, If the BD5 bone size is the same as the BD then a corally blade is the one to use.
Shopkeeper is offline   Reply With Quote
Old 06-07-2009, 04:43 PM   #552
kschu's Avatar
where to find this ?? i live in malaysia.....
Old 06-07-2009, 07:08 PM   #553
kschu's Avatar
team bomber blade should fit w/o a problem i think....
Old 06-07-2009, 10:27 PM   #554
RC MARKET's Avatar
yes !
Old 06-07-2009, 10:28 PM   #555
SammyZ's Avatar
show me the team bomber blade
Hotbodies USA
SweepRacing USA
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
