New Yokomo TC, the BD-5
#3781
Steering problems with my BD-5
Hi BD-5 owners.
I am looking for some advice, about my BD-5. I have the problem, that I think it is very lively, when accelerate out of a cornor, and I have to correct the line after hitting the straight. Overall it seems very nervous.
The track is a very thight carpet track with super grip, so I need the full steering EPA.
Also I run D/R at 80 on my Sanwa MT-4.
I am begining to think that it is over steering, and what to do about it.
Would it be for some use, to change the TOE, I run the standard parts now ?
Any help will be greatful, because as it is now, I am struggling holding the car straight.
#3782
BD5 shock upgrade
Hi.
Any one who knows if these o-rings are better to use
http://www.fast-webshop.com/yokomo-b...h-Grade-O-Ring
#3784
Is it only to replace the original o-ring, ore is there some other thing that will improve the shocks on the BD5 ?
#3786
Anyone have tried to run the AME T-SHOX on there BD5 ?
#3789
Hey guys, I have a super clean bd5 for sale if anyone's interested.
http://www.rctech.net/forum/r-c-item...bd5-parts.html
#3790
hello everyone, I'm in need of some measurements. I just picked of a BD5 off of ebay, and the gear diff looks suspect. I believe it may be the wrong diff or an aftermarket. Just from doing some searches of pictures...it possibly looks like a spec-r?
If someone happens to have their gear diff out, could you measure the distance between the bearings? Like I have in the picture below?? Thanks so much for the help. I've learned my lesson buying from ebay
I'm getting 20.9-21.0mm...I'm thinking it is supposed to be 23-24mm????
#3791
You're right, that's a Spec-R... Could you please count the teeth? I think the Spec-R diff for Yokomo should have 40 teeth... But this model also exists in 39T for TCXX and 38T for Xray...
#3793
#3794
The associated diff is actually quite nice. I don't think that's what you've got there, though.
EDIT: Spec-R does make a bd-5 diff: http://www.spec-r.com/default/index....roducts_id=137
And one for the TC6: http://www.spec-r.com/default/index....roducts_id=240
Maybe it's a spec-r for tc6. Or is that what you meant?
-Mike
-Mike
#3795
Quick update on my BD5WXi with the BD7 servo mount installed:
Been running it lately since I've been rebuilding my BD7 and it's been awesome! Last race, during qualifying and in one final, everyone was 1 lap down with the 2nd placer in a 417v5. In that heat, fast lap was .45 faster than 2nd placer with average laptime within .3 seconds of each other!
Tried replicating the low traction BD7 setup of Umino (plastic parts instead of graphite, etc) and the BD5WXi has never driven so good! Had to play a bit with the rear roll centers to get even tire wear, but other than that, the car is quick!
Will be using the BD7 for big races and my BD5 as a basher during club races from hereon. Car is still definitely competitive!!!
