Old 10-10-2012, 12:42 AM   #3766
mikeygar's Avatar
Trader Rating: 14 (100%+)
Couldn't sleep last night so I did this to my BD5WXi :-)
mikeygar is offline   Reply With Quote
Old 10-11-2012, 12:21 PM   #3767
G-rem's Avatar
Oh damn, didn't know that one piece servo mount could be used on the BD5WXi...how do you make it possible? Have you had to drill additional holes in the chassis?
Is that the only modification you do that we can see on the pics?
Regards,
G-rem
G-rem is offline   Reply With Quote
Old 10-11-2012, 10:02 PM   #3768
mikeygar's Avatar
Regards,
G-rem
had to drill a 2.2 mm hole to fit the dowel of the servo mount.
Servo is offset around 2 degrees since holes in the bottom are not lined up. You can see the dowel right below the original servo screw. The other hole used for mounting is the antenna hole. More on this on the next pic.
Pic isn't too clear but I used a 2mm spacer in bet chassis and the servo mount. Also used a long screw with a nut that is thread locked to hold it down securely. Servo mount is rigid, won't budge at all
Old 10-12-2012, 07:56 AM   #3769
G-rem's Avatar
So nice, I'm gonna try it
Is it not possible to fit the antenna tube in the original hole of the one piece servo mount? Maybe in this case, we have to drill another hole...
Do you mean your drilled hole and the original one in the chassis are not perfectly aligned, so the servo is mounted a bit crooked?
Thanks a lot,
G-rem
Old 10-12-2012, 10:18 AM   #3770
mikeygar's Avatar
not possible because I used the original hole with a long screw and bolt to hold down the rear part of the servo mount. The hole I used for the antenna is the forward hole of the 20g weight which I don't use with antenna mount reversed.
the hole I drilled was aligned with the original hole for the servo mount and the antenna mount. The hole for the original mount is the only one that is not inline with the rest of the holes. Get a ruler and check bottom of chassis and line up the holes of the screws in the centreline. You will see what i mean clearly
Old 10-13-2012, 01:29 AM   #3771
G-rem's Avatar
Souds good, thanks for the explanations
I was thinking something: what about the same mount you did like in the pictures above, but using a longer screw and put the antenna support above the nut? Do see what I mean?
Cheers,
G-rem
Old 10-13-2012, 10:20 AM   #3772
mikeygar's Avatar
Cheers,
G-rem
Possible but antenna mount might hit top deck. Worth a try though! Post pics :-)
Old 10-15-2012, 07:02 PM   #3773
im looking for rear out drives or diffs for mr4tc. belt drive car. would like metal ones if they were ever made...
pm me if you have some or direct me where to get them. i have tried ebay etc...
turbo scorpion is offline   Reply With Quote
Old 10-17-2012, 08:43 PM   #3774
snoopyrc's Avatar
I would like to try this BD7 bell crank on my 2004 SD but I am afraid the holes for the old bell crank will be in the way. You can't really undrill old holes. What is the distance between the center of the bell crank holes on the BD7?
www.battlefieldraceway.com Racing videos at http://www.youtube.com/snoopyrc
snoopyrc is offline   Reply With Quote
Old 10-22-2012, 06:45 PM   #3775
mazmo's Avatar
Hi All,
Would anyone know whether the Yokomo DJC will fit the TOP Photon EX? (Pic below). Part No. BD-010FW
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 10-22-2012, 08:25 PM   #3776
rai
How is it in terms of drivability? Is there any noticeable difference with and without the floating servo mount?
rai is offline   Reply With Quote
Old 10-23-2012, 03:24 AM   #3777
Hugh Jazz's Avatar
Originally Posted by mazmo View Post
Hi All,
Hi Mazmo.
If they did fit I would not use the Yokomo ones. In stead use the spec R or TRF if that is the size you are after. The Yokomo ones are a bit weak. Alex broke one at the titles first run. didn't hit anything and George was running spec R in mod
Dan Maher
Hugh Jazz is online now   Reply With Quote
Old 10-23-2012, 03:41 AM   #3778
mazmo's Avatar
Originally Posted by Hugh Jazz View Post
Hi Mazmo.
Thanks Dan. In that case will probably go with spec R.
Cheers
Alan
Old 10-23-2012, 11:14 AM   #3779
mikeygar's Avatar
can't really say yet, ran the car in less than optimal conditions, but steering response did feel enhanced. I'm guessing it should shine in high traction. Will update as I am able to test.
Old 10-23-2012, 06:48 PM   #3780
rai
Mikeygar,
That's good news..Please update more once the car is tested to full condition...Thanks..
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
