Old 04-04-2012, 09:49 PM   #3526
jono1982's Avatar
Just got my new beast cant wait to run it
|Hearns Hobbies|ORCA Electrics|
jono1982 is offline   Reply With Quote
Old 04-07-2012, 06:02 PM   #3527
Nico''s Avatar
Hi,
I would like to buy Yokomo BD5 double cardan joint set ( [YOK-BD-010FW]) , do you know if there are more strong than Spec R C.V. Universal Swing Shaft, I had Spec R and they broke quickly...
Is there something to increase life of Yokomo double cardan joint set?
I heard to use X-ray pins? is it usefull? what is the size of pins to buy please?
thanks a lot,
Nico'
Nico' is offline   Reply With Quote
Old 04-07-2012, 06:41 PM   #3528
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Originally Posted by Nico' View Post
Hi,
thanks a lot,
Nico'
How are you breaking the spec-r dcj's? Both are as good as each other, all you need to do is rebuild them often to get the slop out of it and you will be fine.
Also are you using the version 1 spec r or version 2?
Alex Ilievski
*INFINITY * R1 WURKS * PLAIG BEARINGS* SPEEDY RC
A Ilievski is offline   Reply With Quote
Old 04-07-2012, 06:50 PM   #3529
Nico''s Avatar
I was using version 1 of Spec R DJ's and broke them when happened a very little crash.
version 2 is better please?
Old 04-08-2012, 12:44 AM   #3530
Hugh Jazz's Avatar
Yes Version 2 is much better than the V1
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 04-08-2012, 02:10 AM   #3531
Nico''s Avatar
thanks a lot
Old 04-08-2012, 01:46 PM   #3532
Default Yokomo BD5 WXi
where do i find the cheapest supplier of this model, and where they are on stock ?
Shock Tower is offline   Reply With Quote
Old 04-11-2012, 02:56 PM   #3533
Send a message via MSN to Emil
Depends on where you are from but if from Europe try http://www.teamyokomo.eu/
- Emil
Emil is offline   Reply With Quote
Old 04-11-2012, 04:58 PM   #3534
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
Bump for a good car. Next round of ETS is here... Good luck to Team Yokomo!
By the way I solved my steering issue. It all came down to the the length of the yoke on my servo saver. It was a bit too short. Switched it out for longer one and I have regained my steering. IDIOT!!!! 15 years of racing and I still make stupid mistakes. When I broke the original stock arm I had switched to a servo saver. The control tire at the race was so soft and had so much steering that I didn't notice it. But since then, using a "normal" tire, (Sorex 32-36) I had no steering. The arm swap did the trick and now peace has been restored in my world. LOL!!
So I advise to measure the distance from the center of your servo spline to the center of the hole on the stock servo arm and make sure your replacement is of VERY similar length.
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 04-12-2012, 06:04 PM   #3535
jono1982's Avatar
Do many people use the bump foam in the shocks alot of people i spoke to dont use them I just wanted to make sure with a few more befor i completly get rid of them
thanks
Old 04-12-2012, 07:46 PM   #3536
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
thanks
Nope no one uses them, 98% of the time they arent required on call cars
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 04-14-2012, 09:14 AM   #3537
Trader Rating: 25 (100%+)
Two question need help with. Can anyone advise what the part numbers are for a spool that uses blades that work with the WXI? Also what chassis does Volker use for asphalt?
Thanks Fred
www.teamkellner.com
fred kellner is offline   Reply With Quote
Old 04-14-2012, 01:35 PM   #3538
masterhit's Avatar
Trader Rating: 15 (100%+)
The TC6/6.1 spools work well and use blades. Just takes a few shims.
31337 for the slipper spool and 31339 for the new 6.1 spool.
Generally it looks like they use the standard W chassis although there has been mention of longer chassis etc...
Mike Slaughter
masterhit is offline   Reply With Quote
Old 04-15-2012, 11:54 PM   #3539
jono1982's Avatar
Thanks Anthony are you comin to Much More Masters
Old 04-16-2012, 04:22 AM   #3540
Yep ill be there
Antoni Caretti
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
