Old 03-01-2012, 03:33 AM   #3466
A Ilievski's Avatar
Trader Rating: 39 (100%+)
Originally Posted by JordanC View Post
Alex PM me your phone number. I need to talk to you
PM'd my number
Alex Ilievski
*INFINITY * R1 WURKS * PLAIG BEARINGS* SPEEDY RC
A Ilievski is offline   Reply With Quote
Old 03-01-2012, 12:11 PM   #3467
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
Anyone have tips for low speed and highspeed steering on low grip outdoor asphalt? Mostly off-power is needed. Running Sorex 32 tires. Silver HPI springs front and rear or pink in front. Have also tried Yokomo Pink Pink with the same result. Shocks in the #3 hole front and rear. Have also tried #4 in the rear. That was a tad better. Just seem to have no front end grip. Blocks are flat on the chassis and 2mm washers on the inner camber link. .5 on outer c-hub in front for added camber gain. have tried Much More 500, 450 and losi 32.5. The car feels very flat and floaty. 1.3 and 1.2 sway bars. Perhaps I need to raise the roll center to get the car to roll more, gaining more grip? I'm thinking that might be better. 1mm shims under the blocks all around? What do you guys think? The track surface is eroding slightly and seems to be a bit loose. The car just seems to skate on the surface instead of rolling over and biting when cornering resulting in understeer. 80wt shock oil in the gear diff as well.
The best I can explain it is this: To get the steering I need, I have to over-drive the car, essentially drifting the car into the corner to achieve the rotation and proper entry angle/line into the corners to compensate for the understeer.
My feeling is that I need to raise the roll center 1mm and go to a silver/blue HPI or Yokomo pink/blue with a 400-450 oil. Shocks #2 front #3 rear or #3 front #4 rear.
How have you guys solved a similar issue?
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 03-01-2012, 12:49 PM   #3468
fpart's Avatar
Trader Rating: 40 (100%+)
Send a message via Skype™ to fpart
What are you running for rear toe in? I have had better luck with the 46.4 setting.
teamTrinity.com Sweepracingusa.com
スクービーは私のヒーローです!
Why is Scooby so slow, you might ask?
fpart is offline   Reply With Quote
Old 03-01-2012, 01:48 PM   #3469
RAL
RAL's Avatar
Same. Do you run at Jackson R/C? How did you do at the Nationals? Do you mind emailing me your setup?
Old 03-01-2012, 06:18 PM   #3470
fpart's Avatar
Im sorry I did run at Jackson but I ran an XRAY. I just now came back to the BD5.
スクービーは私のヒーローです!
Old 03-01-2012, 06:43 PM   #3471
mikeygar's Avatar
Trader Rating: 14 (100%+)
Try running HPI blue or Yokomo Pink all around, 300 much more shock oil (roughly equal to AE40) and droop 5,4. Shock position 3,2, camber -1 F/R inner and outer camber link shims .5mm. Your setup is too stiff to allow the car to roll. It'll be floaty because of the F/R weight transfer due to the droop but you'll get your grip
mikeygar is offline   Reply With Quote
Old 03-01-2012, 06:47 PM   #3472
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
KS do you have any in stock?
hi, i have wx and wxi in stock
Give the best while u can !
kschu is offline   Reply With Quote
Old 03-01-2012, 10:52 PM   #3473
sizheng's Avatar
KS,
I think a stiffer lower chassis is needed for tracks like RC ADDICT. I tested WX and W chassis this time, 0.3s lap time slower if use WX .
I hope YOKOMO will release a new lower chassis soon. The W without the 2nd servo mount hole is really inconvenience.
TEAMHOBBYWING CHINA
sizheng is offline   Reply With Quote
Old 03-02-2012, 12:30 AM   #3474
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Anyone have a good starting set up for medium grip asphalt?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 03-02-2012, 02:17 AM   #3475
kschu's Avatar
Originally Posted by sizheng View Post
KS,
can you share your setup for titc race at rc addict??
Old 03-02-2012, 02:50 AM   #3476
Hugh Jazz's Avatar
There are some good setups here http://www.petitrc.com/reglages/yoko...YokomoBD5.html
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 03-02-2012, 02:04 PM   #3477
Originally Posted by Hugh Jazz View Post
I grabbed a few from there. Thanks!
Does anyone want to sell me a 46.4 toe block? Made a order from HK and they sent the wrong one. And I dont really wanna pay shipping again for a little toe block lol. Used or new, doesnt matter.
Old 03-02-2012, 02:48 PM   #3478
RAL
RAL's Avatar
KS,
I've heard someone is working on one with the second servo hole...
Old 03-02-2012, 02:51 PM   #3479
RAL
RAL's Avatar
I'll give it a go. Yokomo pink, pink and much more 450 was too stiff. Your recommendation sounds like it might work but AE40 is rated at 500cst... Hpi Blue and more droop could be good.
Old 03-02-2012, 03:58 PM   #3480
masterhit's Avatar
Trader Rating: 15 (100%+)
I've heard someone is working one one...
Please, please be true..... For us mere mortals the stock BD5W chassis can get sketchy on high-bite carpet.
Mike Slaughter
masterhit is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
