Old 01-09-2012, 09:13 PM   #3361
Trader Rating: 18 (100%+)
Originally Posted by kschu View Post
i have but used if u dun mind..
Hpi Blue Spring.
thanks for the offer mate.
but i'm looking for the yokomo blues.
I'm having issues with traction rolls with this car on carpet.
The biggest class at MSI is 17.5 blinky.
I'm looking for a setup that will be suitable for med-high grip blinky low-turn.
The setups from the pro drivers work great when the traction is super low but slow the car down until it eventually flips. a temporary solution i've found was to extend the width of the front of the car. 4.2ff and 4.2fr with xray +.75 hexes. this makes the car boaty but it won't flip.
I'm at the end of my rope trying to find a high grip setup for the bd5wx.
for those of you who run 17.5 with the bd5, what sway bars, springs and roll center blocks do you use? any shims on the wheel hexes? shock oil rates?
Thanks for the help
johnny lee is offline   Reply With Quote
Old 01-12-2012, 12:18 AM   #3362
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
Originally Posted by CraigM View Post
Are the DCJs available separately yet? Anyone have a part number?
here Craig.
http://www.teamyokomo.com/jpn/news/o...1_bd_010fw.pdf
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 01-12-2012, 07:30 AM   #3363
defcone's Avatar
Trader Rating: 15 (100%+)
Thanks for the help
If anyone is after a 17.5t boosted setup, what I've ran the whole year is pretty much Volker's Aniche EC setup. But with following changes:
rear shocks laid in one hole
5mm ride height all round
dot 1 rear gear diff oil (600cst equiv.)
Inner steering block hole, with 4mm worth of shims behind steering rack ballstuds
Short front wheelbase
DCJ's
What this does is gives more turn in which I found I liked a whole lot more in Stock racing.
That was what I posted a while back. I ran 450 oil with 1.1mm pistons and 2 o-rings. But this was on low-medium traction asphalt.
defcone is offline   Reply With Quote
Old 01-12-2012, 07:58 AM   #3364
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Thanks for the help
i have them in stock too...Yokomo Blue spring...
Give the best while u can !
kschu is offline   Reply With Quote
Old 01-12-2012, 09:59 AM   #3365
hotdognobun's Avatar
Trader Rating: 31 (100%+)
rcmushroom has some bd5wx!!
hotdognobun is offline   Reply With Quote
Old 01-12-2012, 12:06 PM   #3366
mikeygar's Avatar
Trader Rating: 14 (100%+)
just got hold of my BD5WXi thanks to Elwyn of Hobby Haven! Can't wait to run it and try out the DCJ's!!!
*Not much difference from the original BD5W except for the gear diff, DCJ's, white outdrive protectors and the FF4.2 suspension block (should it be FF and FR 4.2? Mine comes with a FF4.2 and FR3.5 and arms are swept). As posted by someone earlier seems to be running the same chassis as the BD5W.
mikeygar is offline   Reply With Quote
Old 01-12-2012, 10:16 PM   #3367
RAL
RAL's Avatar
Has anyone tried the Zeppin chassis?
http://www.rc-mushroom.com/product_i...or-bd5-p-23731
Old 01-12-2012, 11:13 PM   #3368
kschu's Avatar
i think it's should have same characteristic like WX chassis? both offering more flex.
Old 01-13-2012, 09:58 PM   #3369
SammyZ's Avatar
Trader Rating: 138 (100%+)
i ordered it...ill let you guys know what i think of it compared to the OEM chassis
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 01-16-2012, 11:12 AM   #3370
Trader Rating: 20 (100%+)
Default Manual, parts list
Can anyone supply me with a link for a manual or parts breakdown for the BD5WXi? I am ordering a kit and would like to order spares as well and find a manual helpful for part numbers etc.
trailblazer04 is offline   Reply With Quote
Old 01-16-2012, 10:01 PM   #3371
rai
Please do give us feedback on this chassis.
rai is offline   Reply With Quote
Old 01-18-2012, 10:00 AM   #3372
RAL
RAL's Avatar
Cool Sammy! Let us know. Who has the new DCJs (part#BD-010FW) in stock?
Old 01-18-2012, 11:43 AM   #3373
mikeygar's Avatar
anybody running the DCJ's of the WXi have an issue with the fat end of the dog bone hitting the inside of the C hub? I can't seem to get full travel of the knuckle without the dog bone hitting the c hub first. It starts to hit at about 85% of the steering throw.
I'm using the thinner axle bearings on the inside btw...
Old 01-18-2012, 01:41 PM   #3374
Hugh Jazz's Avatar
Some o e mentioned that you have to file the back of c hub to get full travel
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 01-18-2012, 02:03 PM   #3375
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
In the amended instructions (incl. with the new DCJ cvds) it states you must chamfer the inside edges of the c-hub.
Once done, you should be able to get full lock and the DCJ wont touch the c-hub at full lock.
Also, make sure you take apart the DCJ (as they are assembled) and grease up using Yokomo High Protect Grease or similar and loctite the grub screws when reassembling.
HTH.
Leonard.
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
