Old 12-08-2011, 11:12 AM   #3316
Trader Rating: 20 (100%+)
Default BD5 vs BD5W upgrade
I am looking at buying a used BD5. I want to upgrade it to a BD5W lipo chassis, other then the chassis what parts would I require for the upgrade?
trailblazer04 is offline   Reply With Quote
Old 12-10-2011, 12:48 PM   #3317
Thanks Phillipp,
Your set-up was alot better,thanks .I found the spool can get a bit grabby( sort of torque steer) out of corners but quite controllable,is this normal?
Originally Posted by H4gI View Post
Try my one from the ets
http://www.petitrc.com/reglages/yoko...030/index.html
Caster is 4 not 2
Or for tight corse use more ackerman (2.5mm) springs hpi (silver/pink) or yokomo (pink/blue)
Greetz
retro_ryan is offline   Reply With Quote
Old 12-13-2011, 10:13 AM   #3318
hello yokomo fans i have a yokomo yr4m2pro i was wondering where i can find parts for this wonderfull car i run in it in 17.5 blinky rubber
crash_master is offline   Reply With Quote
Old 12-13-2011, 10:17 AM   #3319
Trader Rating: 30 (97%+)
hi where can i purchase a yokomo bd5 wxi thanks
zaraz is offline   Reply With Quote
Old 12-27-2011, 08:16 PM   #3320
haywood's Avatar
Trader Rating: 49 (100%+)
Default Yokomo Bd5
Any support in the U.S.A. for these kits?
Calandra Racing Concepts/ Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 12-27-2011, 09:28 PM   #3321
Hugh Jazz's Avatar
http://www.driftspeed.com/index.php
Dan Maher
Hugh Jazz is offline   Reply With Quote
Old 12-28-2011, 01:35 AM   #3322
OZDC's Avatar
Trader Rating: 16 (100%+)
Default Spec r Swing Shaft
Hi,
I have purchased a set of the spec r universal swing shafts version 2 part number SPR001-bd2
http://http://www.rc-mushroom.com/pr...mo-bd5-p-23318
I am having trouble getting them to fit.
If i use the supplied bearings there is a lot of play, but if i use the original bearings I can't get the pin in. I have ended up shimming them out.
Also when in place it hits the back of the C-hub.
Are these the right ones for the BD5W?
Any hints on getting them to fit?
Dave
OZDC is offline   Reply With Quote
Old 12-28-2011, 05:18 AM   #3323
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by OZDC View Post
Hi,
Dave
I am using these and the supplied bearings fit without slop, where is the slop at? You have to file down the c hub a tiny bit.
defcone is offline   Reply With Quote
Old 12-28-2011, 07:01 AM   #3324
rai
Part of curiosity, are the team drivers using the original yokomo dcj or is it an aftermarket dcj like specR? Would love to convert my wx into wxi.
rai is offline   Reply With Quote
Old 12-28-2011, 07:04 AM   #3325
Pro Models's Avatar
i used the supplied narrow bearing and used a shim up front just below the pin hole.
As regards to the shaft hitting part of the c-hub all u have to do is remove some material with a surgical blade. 1 min job :-)
Hope this helps.
Gus
Hi,
Dave
Pro Models is offline   Reply With Quote
Old 12-28-2011, 03:35 PM   #3326
OZDC's Avatar
Thanks guys.
The slop is between the pin and the Bearing which I shimmed.
I will attack the c hub. I just thought that They would fit without needing any mod.
DC
Old 12-28-2011, 04:18 PM   #3327
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
The team drivers are using the Yokomo DCJ cvd in the front. It will become available later this week or next week in Japan. There is no part number or price as of yet.
THe other parts required to convert a WX to WXi are:
1 x DCJ cvds (frt)
1 x Plastic Blades (new white plastic material - lasts heaps longer, especially when running mod)
1 x Harder Chassis (has less flex than WX chassis)
HTH,
Leonard.
:::Smokem Racing:::RCMaker.com.au:::Speedy RC.com.au:::
"It's more fun to drive slow cars fast, than fast cars slow"...
DirtyDog3375 is offline   Reply With Quote
Old 12-28-2011, 05:18 PM   #3328
rai
1 x DCJ cvds (frt)
HTH,
Leonard.
Thanks for the info. Cant wait for the parts to release esp. for the dcjs. Thanks mate.
Old 12-28-2011, 06:32 PM   #3329
hacker's Avatar
Trader Rating: 141 (100%+)
1 x DCJ cvds (frt)
HTH,
Leonard.
first of all, not doubting you, but I thought the wxi was designed for carpet. Wouldn't the chassis be stiffer than its predecessor?
hacker is offline   Reply With Quote
Old 12-28-2011, 11:36 PM   #3330
rai
True, it would be stiffer than its predecessor. However, we can just change between chassis in accordance to the surface raced on as almost all parts are interchangeable. In my case, we have like one race on carpet a year and most of the time racing on asphalt so i would only used the dcjs for my wx.
Im not that sure about the wxi was designed for carpet race but looking from previous posts it sounds like it is designed for carpet. Not 100% sure.
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
