Old 08-08-2011, 01:31 AM   #3136
defcone's Avatar
Trader Rating: 15 (100%+)
Originally Posted by vitomon View Post
hi guys, after numorous tries i am still fighting understeer with the car. i am using ronalds basic outdoor setup on VTEC 30x wheels. however, the car would not generate good front grip. the rear of the car is planted.
i tried to reduce toe to 2.5° and some other stuff but nothing would bring the desired effect. any ideas what to try to get more steering in the car??
cheers
What additive are you using? You tried an LTCR? Front geardiff?
defcone is offline   Reply With Quote
Old 08-08-2011, 02:08 AM   #3137
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
might try running harder spring ? hpi gold n hpi pink
Give the best while u can !
kschu is offline   Reply With Quote
Old 08-08-2011, 02:09 AM   #3138
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
i tried the ltc-r but it made the car more unstable and worse to drive and the effect on steering was very little compared to the speed6. will try the front gear diff on the weekend (however, i tried the frontgear diff in 0-boost class and it didnt help; this is modified though now)
additive was tyretweak
what about the shock lenghts?
tried pink/silver after i drove silver silver for the most part. but it had only little if any more steering and caused the tires to overheat more quickly.
unfortunately we have to use the 30x tires.
Infinity -- Orion ESC -- Sanwa M11x
May the grip be with you ... always!
vitomon is offline   Reply With Quote
Old 08-08-2011, 06:50 AM   #3139
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
Hi is there charts for suspension blocks out there.would like to now what blocks to get cheers
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Old 08-09-2011, 09:51 AM   #3140
Who can explain me the difference between all BD5 version??
BD5 normal
BD5 World Spec
BD5 WX
BD5 WR
Thanks!
nicoo2k4 is offline   Reply With Quote
Old 08-09-2011, 10:15 AM   #3141
defcone's Avatar
http://www.teamyokomo.com/jpn/partsl..._bd_301ff.html
BD5 normal
BD5 World Spec
BD5 WX
BD5 WR
Thanks!
http://www.teamyokomo.com/jpn/product/products.html
Old 08-09-2011, 07:13 PM   #3142
kschu's Avatar
i was running 62mm shock length and also using the Black bladder.
maybe u should try move your bodyshell 2mm to the front and move 2 mm wing to the front...it's did help to gv u alittle more steering
Old 08-11-2011, 01:06 AM   #3143
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
anyone have any idea what the part number is for a yokomo "paper" 0.5mm shim is?
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 08-11-2011, 03:24 AM   #3144
defcone's Avatar
Have a look through the parts list I linked above, do u mean the paper gasket which go in between the two gear diff halves?
Old 08-11-2011, 05:49 AM   #3145
rx7ttlm's Avatar
I really don't know which one it is, Hara said he used a yok paper shim so I was just trying to narrow it down.
Cheers,
Old 08-11-2011, 08:56 AM   #3146
defcone's Avatar
Cheers,
What did he use it for?
Old 08-13-2011, 02:18 PM   #3147
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
Does anyone know the part # for the tear drop shape washer used for the wing mounts? Its blue with a countersunk top for use with a flat head screw. Look how the wing is mounted in this picture to see what I'm describing.
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Old 08-13-2011, 10:57 PM   #3148
Shopkeeper's Avatar
Trader Rating: 35 (100%+)
BD-110
Shopkeeper is offline   Reply With Quote
Old 08-14-2011, 12:37 AM   #3149
RAL
RAL's Avatar
Thanks Mr. Jenson!
Old 08-15-2011, 05:22 AM   #3150
rai
What is the difference using between steel universal shaft and the aluminium universal shaft? I know both are different in weight and material wise but are they any other differences between these two like performance wise, durability and reliability maybe? Just for the sake of curiousity.
I noticed that Ronald uses the aluminium rear and front uni shaft...
Thanks...
rai is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
