Old 07-21-2011, 04:19 PM   #3121
yumlailai's Avatar
Originally Posted by Electro-MAX RC View Post
Hi, I just took delivery a BD5-WX (I believe this is the latest iteration of the car). Before I break the factory seal, can somebody who purchased the kit tell me if there's also a ball diff included (it says it comes with a gear diff and spool) or any other extras. Chassis weights, aluminum spring retainers, different spring sets etc? Thanks.
Only Gear Diff and Spool and it only comes with 1 chassis
yumlailai is offline   Reply With Quote
Old 07-21-2011, 06:38 PM   #3122
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Originally Posted by transplantlife View Post
who sells the BD 5 WX in the states?
not sure, but if u wan order oversea, u can check here
Give the best while u can !
kschu is offline   Reply With Quote
Old 07-22-2011, 01:22 PM   #3123
Default BD5-BX
Hi, thanks for the response on the contents of the BD5-WX kit.
Does it come with the chassis weights, the box shows weights on the chassis.
Wasn't sure if they came with them.
Electro-MAX RC is offline   Reply With Quote
Old 07-22-2011, 06:47 PM   #3124
rai
Yes, they do come with weights. The kit comes with one hi-traction chassis, one solid spool, one gear diff, weights and the rest are as usual. All you need to have is your preferable gear diff oil and shock oil because the gear diff oil came with the kit is #700 & of course you need your electronical units too.
rai is offline   Reply With Quote
Old 07-23-2011, 03:22 AM   #3125
can we use T3 axle or driveshaft...?
http://www.teamxray.com/teamxray/sho...625c85e9203063
The Dark Force of Racing
- EP Dungeon -
zamrioo2 is offline   Reply With Quote
Old 07-23-2011, 06:59 AM   #3126
defcone's Avatar
Trader Rating: 15 (100%+)
The ball is too big to fit inside the diff outdrives.
defcone is offline   Reply With Quote
Old 07-23-2011, 08:28 AM   #3127
the T3 axle can be used? i found the yok bd5 axle not so last... even roche not so smooth...
- EP Dungeon -
Old 07-31-2011, 04:11 AM   #3128
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
Hi guys where can I find Ronald volker basic outdoor set up.cheers
Vbc wildfire D06
clinton livingstone
P.I.M.P is offline   Reply With Quote
Old 07-31-2011, 05:25 AM   #3129
defcone's Avatar
http://www.petitrc.com/reglages/yoko...508/index.html
Old 08-02-2011, 09:48 PM   #3130
kschu's Avatar
keff, post out your winning setup...
Old 08-02-2011, 10:39 PM   #3131
defcone's Avatar
I just use that one, the only change I make is shock oil and ride height. More aggressive car= lower rideheight, more smoother= higher.
Old 08-05-2011, 06:24 AM   #3132
dameetz's Avatar
Default front arm sweep
If I want to set front arm sweep, which front block do I need?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 08-05-2011, 06:57 AM   #3133
defcone's Avatar
I think you can only get a narrow Front rear one. Then use the stock front front one.
Old 08-08-2011, 01:09 AM   #3134
Send a message via ICQ to vitomon Send a message via Skype™ to vitomon
Default understeer!!!
hi guys, after numorous tries i am still fighting understeer with the car. i am using ronalds basic outdoor setup on VTEC 30x wheels. however, the car would not generate good front grip. the rear of the car is planted.
i tried to reduce toe to 2.5° and some other stuff but nothing would bring the desired effect. any ideas what to try to get more steering in the car??
cheers
Infinity -- Orion ESC -- Sanwa M11x
May the grip be with you ... always!
vitomon is offline   Reply With Quote
Old 08-08-2011, 01:23 AM   #3135
RAL
RAL's Avatar
Trader Rating: 60 (100%+)
cheers
Maybe you can play with shock length, adjusting the pack of the shocks for more front grip and less rear grip. Also have you tried .5 shims under both rear blocks?
TEAM ARAI GRIP ● J★STYLE ● P1 BRAND ● RÄLDESIGNWERKS ● EXOTEK
RAL is offline   Reply With Quote
Team Losi JRXS Kenshin Electric On-Road 13263 06-13-2016 04:39 PM
Yokomo MR4TC-BD mr.ng Electric On-Road 9094 02-05-2013 02:10 PM
Hey all, new to R/C Stin83 Electric On-Road 12 11-05-2005 10:29 AM
Is EP TC racing dying? Edwin Lee Malaysian R/C Racers 221 04-28-2005 12:46 AM
New 1/10 Touring Car ttektek Electric On-Road 63 03-21-2005 02:56 PM
